Click/Tick Reduction with Fuel Additive - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 4 (permalink) Old 06-14-2013, 08:23 PM Thread Starter
hewilson's Avatar
Just also posted this in reply to my own original quest but thought a new thread might be appropriate as well.
After my question about the hemi click or tick, I read on this site about products from BND Automotive that are supposed to help ameliorate it: Aces IV gasoline formula and Quantum Mineral Synthesis Base Oil. They are somewhat expensive but I decided to give it a try. They arrived today. I put in the fuel additive right away. No time for an oil change today. And it works! An immediate reduction in click/tick by - in my estimation - 75-90% Its still there but it is significantly reduced. Enough that it now doesn't bother me!
Haven't had a chance to opne in her a bit to see if there is any performance improvement - its supposed to boost octane to 102. But I'll be sure to let you know if it does.
I'll follow up and let you know if the oil produces any additional benefit to the click/tick.
hewilson is offline
post #2 of 4 (permalink) Old 06-14-2013, 08:24 PM Thread Starter
hewilson's Avatar
To my own original question that is.
hewilson is offline
post #3 of 4 (permalink) Old 06-14-2013, 08:44 PM
Redliner's Avatar
I have to ask......How the heck can a "fuel additive" have anything to do with a valvetrain noise? If it were pre-detonation, I would understand but I thought the clicking noise was due to the bleed-down of the valvetrain compnents to serve the MDS system. Has this not been identified as such?
2009 Dodge Challenger R/T Deep Water Blue 20" rims Cool as Hell
1995 Mitsubishi Eclipse GSX 2.0 Turbo Automatic........with 99 front end and rear facia.
1995 Toyota T-100 SR5 Best Truck I've ever owned
2005 Kia Sorento Great car but everybody keeps doorbanging the poor thing.
1975 Mustang II V-8 Highly Modified to 400+ HP, nothing stock except the radiator cap
Redliner is offline
post #4 of 4 (permalink) Old 06-14-2013, 10:59 PM Thread Starter
hewilson's Avatar
One explanation I read...copied earlier post
On the chargerforums web site there was a interesting discussion about what causes the "ticking' sound in modern Hemi engines and how it can be quieted. Here is the post:
Many here know what we do to stop the Hemi Tick, but we figured that since there are so many new faces here, they may not have heard that you don't have to have it in your engines.
We have discussed previously that there are 3 culprits that cause the "Hemi Ticking" that is heard in idle and just off idle.
1) Intake and exhaust valves do not have any kind of cushioning from the fuel. Fuel usto have higher amounts of sulfur and tetra ethyl or tetra methyl lead to lubricate and cushion intake and exhaust valves in the old days. When EPA decided to go to unleaded fuels, hardened valves and seats were produced trying to deal with the lack of lubricant. This was adequate at best, but did allow engines to live longer than if they had soft valves and seats. However, when they went to ethyl alcohol, that all changed. Alcohol absorbs moisture and strips lubricity. That was bad enough, but when they reduced the sulfur content from 130 parts per million (ppm) to 30 ppm, it really produced a perfect storm. Both the intake and exhaust valves are now hitting against the valve seats with no cushioning at all. This causes wear, and then of course....noise or TICK.
2) Fuel injectors depend on at least 70 ppm of sulfur to stay alive. When EPA went to the ethyl alcohol and less than 30 ppm, they have no cushioning allowing them to click or tick also while building up gum and varnish. This restricts the flow of fuel and turns the vaporized spray pattern into an atomized spray pattern. Atomized fuel doesn't burn as well, and helps wash down into the cylinders and wipes out the detergents and dispersants much faster. This is the second part of the Hemi Tick.
3) Because the Hemi has a very short skirt and thin rings with virtually no land area, the piston wants to rock in the bores. This is another reason for the moly piston skirt coatings. It is designed to cushion the short skirt. The problem is that as miles rack up, the moly is worn off and a louder engine or tapping noise begins to occur. This is the third part of the Hemi Tick. This part actually contributes to more aluminum in your oil analysis. An oil analysis is always important to do on any engine you want to take care of as a baseline, and then every 3rd oil change, do one just to be sure nothing is leaking or causing problems.
hewilson is offline
Goodbye, V-8s, the Engines That Could GreatAmerican General Challenger Discussion 111 03-08-2015 07:26 AM
Pulling Fuse #2 Q8Chally Performance Modifications 67 09-04-2014 08:06 PM
The Challenger and I 09R/T_Semper General Challenger Discussion 20 06-23-2008 02:16 PM
Goldman Sachs fuel futures/Dodges new Gas Card incentive. NOT EVEN REMOTELY SURE General Challenger Discussion 14 05-09-2008 08:21 AM
