Should I lock my VVT cam? - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 14 (permalink) Old 04-27-2014, 10:58 AM Thread Starter
Supporting Vendor
Modern Muscle's Avatar
Exclamation Should I lock my VVT cam?
No one good answer for this and here is why.
The cam phaser has more to do with emissions than performance on the new engines. The amount the cam is moved is ridiculous for a performance engine especially for the RPM we are running these engines at(35 degrees from factory). The Comp phase limiter is more of a safety device to mechanically prevent the cam from being moved so you have a piston to valve collision when installing a larger than factory cam. When these installs are being tuned properly most or all the cam sweep is taken out of the cam control tables. Then you have the fact that everyone wants to pick cams that are too large for their application because it lopes (that requires a different post). The aftermarket cams are already installed so late in the engine to have enough intake piston to valve they do not want to be retarded. The cam phaser can only retard the cam from the install point.
When do I want to keep my Phaser?
If you are doing a build and adding a piston with a valve relief now is when we can use this to make some power. BUT we can only use this if the engine builder/designer does not use an off the shelf cam that is meant to go in an engine that has no reliefs. Now that we have intake valve clearance we can install the cam advanced enough to take advantage of sweeping the cam with the phaser.
276-663-1555
Modern Muscle is offline
The Following 5 Users Say Thank You to Modern Muscle For This Useful Post:
Geno22 (01-29-2016), Madcoder (01-29-2016), O_Racing (01-29-2016), PaVaSteeler (01-29-2016), Pector55 (01-25-2016)
post #2 of 14 (permalink) Old 01-28-2016, 11:33 AM
Pector55's Avatar
So even if we use the physical limiter, do we still need to lock down the tables to a limit of 14*? HP Tuners has unlocked access to these tables now and from what I read, the computer does a sweep at start-up.
____________________________________________________________ ____________
2013 RT Plus | RC2 CAI, Ported 392 intake, JG Stage 1 high lift cam, JBA Long tubes and catless mids, 3" Heartthrob exhaust, HP Tuners, IM LC-2, 3.91 gears and FTI 3000-3200 = 12.09 @112.42 - 1.62 60ft
Pector55 is offline
post #3 of 14 (permalink) Old 01-28-2016, 11:45 AM Thread Starter
Supporting Vendor
Yes you need to match the sweep with the tune or else you will get a cel
The Following 2 Users Say Thank You to Modern Muscle For This Useful Post:
Geno22 (01-29-2016), Pector55 (01-28-2016)
post #4 of 14 (permalink) Old 01-29-2016, 09:29 AM
Pector55's Avatar
I appreciate MM stepping up and sharing information. I've been hesitant to pursue a cam upgrade because I am not one to simply drop my car off at a shop and have other people do my work but the VVT piece is new to me. I have been on the fence about staying NA vs adding a blower. While I know there are plenty of people adding a blower to stock internals I can't get past adding forced induction to our compression.
Seeing that you were able to hit over 420 whp with the blower cam and supporting mods, while staying NA makes that a great incremental option and addresses my concern about forced induction on our compression. A cam just makes this setup a much safer system in my opinion (moving more air, less detonation probability, more timing).
I really want to add a blower cam and head upgrades this year (already have long tubes and 3" exhaust) and then add the blower next year. I just prefer to do the install and tune on both.
Pector55 is offline
The Following 2 Users Say Thank You to Pector55 For This Useful Post:
Geno22 (01-29-2016), PaVaSteeler (01-29-2016)
post #5 of 14 (permalink) Old 01-29-2016, 09:43 AM
Frank Julian's Avatar
ok so I put a cam in an older "LA" engine (piece of cake). So if I get a "274" cam, which is most popular when I search for cams. So I install it just like my factory cam is installed or do I need to "limit" it? Also if I throw this cam in my car in my garage, I have heard it will not run without a tune. It is a '15 so I presume I need to get the unlocked PCM and a tuner and a "canned" tune for my application before I change cams. Is this correct? I know on the older engines you lined up the timing marks and stuck in an "offset key" to advance the cam 4 degrees and you were done. (well my Cloyes set was 4 advanced, straight up or 4 retarded). This whole VVT and MDS crap makes me feel 10 degrees retarded.
Frank Julian is offline
post #6 of 14 (permalink) Old 01-29-2016, 09:49 AM Thread Starter
Supporting Vendor
Is this a 5.7?
Sent from my SM-G928V using Tapatalk
post #7 of 14 (permalink) Old 01-29-2016, 10:08 AM
After degreeing cams and seeing its effect on performance, I don't believe phasing the cams is just an emissions idea. It absolutely creates power at various RPM's and is better to have it than not. By disabling it, you will give up power somewhere in the rev band.
2015 SRT
Red-line red triple pearl w/silver stripes
Auto
Harmon Kardon/Nav
Laguna's
Technology group
Bone stock other than:
HC air box and inlet
AEM air filter.
ScottG is offline
post #8 of 14 (permalink) Old 01-29-2016, 10:08 AM
Is this a 5.7?
no that was an old 360 "LA" engine (Small Block).... Things were so much easier then.... You could put an engine together over a weekend.
post #9 of 14 (permalink) Old 01-29-2016, 10:32 AM Thread Starter
Supporting Vendor
You mentioned a 274 cam that is why I was asking, 274 cam for a 5.7 is a not a good option
post #10 of 14 (permalink) Old 01-29-2016, 11:35 AM
O_Racing's Avatar
i thought comp cam was already grinding in 4 degrees of advance like other makers; who cares about idle...lol... lopey lopey is how we like 'em, 106 LSA in da house
i doubt this one is 106, but it is definitely lopey
https://www.youtube.com/watch?v=B5YKvVA0N9s
at this point VVT is really for the mini van driver; if you are serious about using the car from 4 to 6.5 or 7...
MM seems to be driving the Cam shaft talk on this Forum! a good move for a very critical and difficult part of the engine to define and decide on
ODP
13 Chall,SRT8,6sp,Hurst,DiabloTune,Whtline cradle bushings,REM A/TensionArms+Camber Lks+Tower Braces, Progress Swaybars w/adj. end lks,EIBACH Multi Pro R2’s,C Can, 84FastmanTB,AFE MagForce Stage2,MF CompExhaust,frt RB floating rotors ,ATE200Fluid,StoptechLines,Hawk/Stoptech Pads,WretchedMotorsportsPrep’d,AprCFWingGTC300,CFSplitter,BB S CHR 20x9w/275/35AdvanSportA/S,Trckset 18x9 BravadoTribute w/275/35FalkenAzenisRT-615K, 0w40 SRT Pennzoil/Amsoil, SRT Filter, RP rear diff, MoparATF,180Tstat
O_Racing is offline
  Dodge Challenger Forum: Challenger & SRT8 Forums > Supporting Vendors > Modern Muscle Performance Group
VVT Cam Install Question / Timing Mark Help Moparth Performance Modifications 16 07-01-2014 02:20 AM
HOT DEAL: Cam Install Package For 11+ 6.4 VVT Hemi (IN STOCK!) Modern Muscle Vendor Deals 2 04-16-2014 12:57 PM
HOT DEAL: 5.7L VVT Cam Swap Spring Package In Stock! Modern Muscle Vendor Deals 0 04-04-2014 08:09 AM
Finally went ahead and ordered the 274 VVT cam! Ahmed's 392 6.4L / 392ci (2011 - ?) 184 03-11-2014 12:20 AM
MY GiG lock kit & rear cam NOT EVEN REMOTELY SURE General Challenger Discussion 2 05-28-2008 02:16 AM
