392 motor forged internals - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 35 (permalink) Old 04-20-2012, 05:38 PM Thread Starter
Anyone know if the 2011-2012 (392) comes with forged internals?
Phil
2012 SRT Challenger
Phil is offline
post #2 of 35 (permalink) Old 04-20-2012, 05:48 PM
PRoBLeMz's Avatar
Lower end should be forged.
Dodge Challenger 392 SRT8(Green w/Envy) Mods in order: oil catch-can, K&N air filter, Petty's Strut brace front/rear, tran brace, Escort 9500IX(can't stop going fast), ARH LT[Catless]/Catback Exhaust, B&G ECU Tune.
© All names changed to protect the Innocent
PRoBLeMz is offline
post #3 of 35 (permalink) Old 04-20-2012, 06:05 PM
Toxic11's Avatar
Feedback Score: 2 reviews
Crank is Forged Steel, rods are "Cracked Cap" Forged Powder Metal and pistons are Hyperutectic.
.................Brett DiMichele 2011 Toxic Orange SRT8
Toxic11 is offline
post #4 of 35 (permalink) Old 04-20-2012, 07:06 PM
Toxic - excellent post
Could you compare what the 392 internals are like to, let's say, an 03 Cobra or any other forged internal vehicle ??
For example "the 392 has stronger pistons than XXXXX car because they're hyperutectic but not as good as the XXXX car because they're XXXX"...
I guess I'm requesting that you put it into perspective for people that don't know the terminology
Litos is offline
post #5 of 35 (permalink) Old 04-20-2012, 08:10 PM
STRONGNUFF's Avatar
Hyperutetics are not very forgiving with detonation
Andre
2012 SRT8 Challenger 392 6-speed
Bright Silver Metallic w/Black Stripes
LMI 4" Carbon Fiber CAI
SpeedLogix Catch Can
Resonator Delete (Now it sounds like a Hemi)
DRL's Activated
Webelectric sequential tail lights
STRONGNUFF is offline
post #6 of 35 (permalink) Old 04-20-2012, 09:27 PM
Toxic11's Avatar
Hyperutectic is a term that denotes a high silicon content cast aluminum alloy. A Hyperutectic piston is "technically" cast, but has more resiliency than a typical cast piston. The thermal expansion is well controlled and they are lighter than a typical out of the box forged piston.
As Andre said, Hyperutectic are not forgiving with detonation, at their core, they are still cast, so detonation can cause them to fracture and crack. Forged aluminum while being more dense (and more heavy) is also more malleable, which means the piston can handle deformation without fracturing. That is not to say a Forged piston won't fracture, they sure will! But they are more forgiving in boosted and nitrous fed applications where there is the possibility of detonation.
The Fractured Cap Powdered Metal rod technology is nothing new. Basically what they do is they take a measured amount of powder that meets the specification for the material properties and it is forged under pressure and heat in a mold. The rod comes out of the mold with a very consistent finish and a very close weight tolerance. The rod is then finish machined, the rod and crank journal areas are finished and the finished rod is put onto a machine that "cracks" the cap off the bottom of the rod rather than cutting the cap off. This ensures that the cap will always be 100% aligned because the fracture is unique to each rod/cap.
Steel Forged cranks are old school time tested tech. Forged Steel is dense, strong and somewhat malleable before fracturing occurs. It's the strongest crank you are going to see in a factory engine, unless that engine is some high end, hand built exotic that is running a "Forged Billet" crank.
Here is an example of a Forged Steel modern Hemi Crank. The crank pictured is from a 6.1 Hemi, note the wide "parting line" on the ends of the counterweights. Cast Crank's will have a very narrow, very sharp parting line.
To put things into perspective.. Here is an excerp of the materials in the new ZL1 Camaro LSA.
Components and design elements that contribute to the LSA’s performance include:
■Balanced, lightweight reciprocating assembly
■High-strength hypereutectic pistons
Nestled inside the LSA’s deep-skirted cylinder block is a forged steel crankshaft that delivers a 3.62-inch (92 mm) stroke. It features an eight-bolt flange – the outer face of the crankshaft on which the flywheel is mounted – that provides enhanced clamping strength. Other non-supercharged GM 6.2L engines have a six-bolt flange. A torsional damper mounted to the front of the crankshaft features a keyway and friction washer, which is designed to support the engine’s high loads.
Connected to the crankshaft is a set of lightweight powder-metal connecting rods and hypereutectic pistons, which, when combined with the cylinder heads, delivers a 9.1:1 compression ratio. The alloy of the pistons was selected for its strength and heat resistance properties, while the cast design provides inherent quieting advantages over other piston materials, such as forged aluminum."
Source- Camaro Zl1 Exhaust | RoadTest TV
Toxic11 is offline
post #7 of 35 (permalink) Old 04-20-2012, 09:49 PM
Great information, thanks!
RoostKing is offline
post #8 of 35 (permalink) Old 04-21-2012, 11:25 AM Thread Starter
Thanks for the info Toxic11..!!!!
Phil is offline
post #9 of 35 (permalink) Old 04-21-2012, 01:17 PM
X2! Good to know.
Nevs is offline
post #10 of 35 (permalink) Old 04-21-2012, 05:46 PM
So... the LSA's bottom end uses the exact same materials as the 6.4L Hemi's? And the GT500 only adds forged pistions?
Interesting...
gr8srt8 is offline
392 Billet Catch Cans In Stock @ Speedlogix Speedlogix Speedlogix 186 05-27-2013 05:21 PM
2013 Dodge Challenger SRT8 ResumeSpeed 6.4L / 392ci (2011 - ?) 36 11-28-2012 05:44 AM
What's Up With 392 Hemi Owners In Philly Area??? 6SPD4ME North-East 9 08-14-2012 04:58 PM
