Pennzoil Ultra vs. Mobil 1: MY OPINION!!! - Page 3 - Dodge Challenger Forum: Challenger & SRT8 Forums
post #21 of 60 (permalink) Old 12-30-2012, 12:16 PM
us1champ's Avatar
Feedback Score: 10 reviews
I know its not penzoil/mobil one related but i have seen some like amsoil quakerstate and a few others that state the add zinc. I know zinc was more for flat tappet cams but wouldnt that also be benifitial to roller systems as well?
Sent from my SCH-I535 using AutoGuide.Com Free App
2009 SRT
CUSTOM HEAD RESTS
us1champ is offline
post #22 of 60 (permalink) Old 12-30-2012, 12:16 PM
There is nothing wrong with Pennzoil or any other API certified oil that meets the Chrysler requirements for our cars. (synth or not)
When I used to be a t3ech (20 years ago) for the State Police we used low bid oil no name brands that you never heard of but all were API certified and met GMs specifications. We changed the oil every 5k miles which was about a month or so. The cars life span was 2 years or 120k which ever came first. Working on these cars for 13 years we never had an engine failure due to oil, rather sucked valves (not oils fault) or head gaskets (not oils fault) or low oil and the engine blew.
Today's oil no matter synth or not blows away the oils of yesteryear and if those oils could stand the punishment troopers give those engines, you will never see (ever) an engine related problem caused by todays oil. Use what you want as long as it meets the specs and be happy.
FWIW, I only use Mobil 1 in the SRT8 because 0w40 does not exist other than Mobil 1 and Pennzoil and Pennzoil 0w40 can only be purchased from dealers (in my area) so Mobil 1 wins.
sitedrifter is offline
post #23 of 60 (permalink) Old 12-30-2012, 01:44 PM
Yahooligan's Avatar
Originally Posted by sitedrifter View Post
Working on these cars for 13 years we never had an engine failure due to oil ... or low oil and the engine blew.
Interesting take on things, I wonder where the oil went and why. Low oil caused engine failure within 5000 miles of an oil change, that's either a pretty big leak that should've been caught or the engine was burning it due to rings or valve guides. Not sure how you can conclusively say oil wasn't a factor.
I agree, proper maintenance with proper fluids and parts is the most important thing you can do for your car, but that doesn't mean there are no advantages to better lubes. There's a reason synthetic oils are called for by the manufacturer, be it for the engine, transmission, or diffs.
ATF+4 is synthetic
Our rear diffs call for synthetic gear oil
SRT vehicles come with synthetic engine oil from the factory
If conventional lubes worked just as well then they wouldn't be specifying synthetics. Fact is, our vehicles see higher internal operating temperatures and in many cases conventional oil would break down and not be able to protect at those temps.
My car gets Mobil 1 in the engine and diff, trans gets whatever ATF+4 is the cheapest since they're all the same.
2016 Challenger R/T Scat Pack, B5, 6-speed, SPAG, WRTs, sunroof, SGII, Convenience, Tech and Leather; UPR catch can, skip-shift eliminator, Mopar splash guards.
2006 Jeep Grand Cherokee Laredo, Inferno Red, 4.7L V8
RIP 11/2/14 - 2011 Challenger R/T Classic GWE 6-speed
Yahooligan is offline
post #24 of 60 (permalink) Old 12-30-2012, 02:01 PM
2BLU4U's Avatar
[QUOTE=Yahooligan;1223204]Do you have a link to the VOA showing how much moly the Pennzoil has? Choosing an oil because of a single component is like buying a car because you like how the tires look.
Mobil 1 0w40 has consistently been the benchmark oil with healthy levels of moly, but also healthy levels of zinc and phosphorus (Help reduce wear). The 5.7s also have VVT, haven't heard of issues with cam wear or scuffing with them...
Data is part of my job. The VOA and UOA for Mobil 1 show time after time that it's a great oil. The fact that my engine, as well as others' here, sounds happier with Mobil 1 confirms that. I've yet to see any VOA or UOA for Pennzoil Ultra 0w40, but I have heard plenty of complaints about Pennzoil Ultra and not just here on CT.
Apparently some Pennzoil "engineers" had a Q&A session over on the SRT forums. Based on the responses given by Pennzoil, they weren't engineers but instead were people from Pennzoil's marketing department as they could give no technical answers about the product. Their responses were always in marketing speak.
Pennzoil Enginners Q&A Session - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
You guys are 100% correct.....and I am 100% ill informed! Please forgive me for posting such utter nonsense....& for purchasing & utilizing Pennzoil in my 392. Unfortunately there is no way do totally delete my post. However, I will bring the 2 cases of Pennzoil to my local recycling center first thing in the morning. Again, my apologies....and thank you for helping me make my decision on motor oil....& to leave this Forum. Happy New Year!
Stripes Make You Faster!
2011 SRT8-392 IE #262 DWB
2004 C5 Z16 CE #2017 LMB
2014 Charger R/T AWD
1995 Impala SS
2BLU4U is offline
post #25 of 60 (permalink) Old 12-30-2012, 02:25 PM
Yahooligan's Avatar
Really, that's what you took from my post?
BITOG has numerous VOA and UOA results, but so far I've been unable to find a single one on Pennzoil Ultra 0w40. What I do find out there are marketing responses from "engineers" and people complaining about the oil and people making statements about it, positive and negative, without any sort of reference or data. The point of my post wasn't to say you're doing the wrong thing, but simply that there are very few useful facts and data about the oil so I don't know how people can make a truly educated choice or say definitively that one oil is better than another without the data. I know my engine doesn't like Pennzoil and I won't use it again.
If you or anyone else can find VOA or UOA on Pennzoil 0w40 then please post it up. Without this I don't see how anyone can make factual statements about how well it protects or compares to other oils.
post #26 of 60 (permalink) Old 01-06-2013, 11:05 PM
the sko's Avatar
Don't mean to derail the conversation here but 2 quick questions. First the manual says to use 5-40 but you all keep mentioning 0-40, should I be using 0 vs the 5? Car only has 250 miles so plenty of time before first OC. Second, the manual also calls for synthetic oils, are any of you using conventional oils? That doesn't sound right if you are.
Thx
the sko is offline
post #27 of 60 (permalink) Old 01-07-2013, 03:32 AM
Toxic11's Avatar
Feedback Score: 2 reviews
Thx
The manuals have been revised. Most of us run 0-40 Mobil-1, those that run the Pennzoil are running 5-40. Either meet the warranty requirements. Both the Pennzoil 5-40 and Mobil-1 0-40 are Euro Car Spec Full Synthetics.
.................Brett DiMichele 2011 Toxic Orange SRT8
Toxic11 is online now
post #28 of 60 (permalink) Old 01-07-2013, 06:13 AM
My take is the 2011 392s (and early 2012s) were spec'd with 5w40 because Pennzoil did not have 0w40 ready for the market and Chrysler moved to Pennzoil for 2011 MY. They (Pennzoil) now have 0w40 and that is the recommended oil fill for all 2012 and up MYs. The 2011s never received an addendum to the manual but most of us moved to 0w40 anyway.
post #29 of 60 (permalink) Old 01-07-2013, 10:00 AM
Yellow Jacket 2012's Avatar
I called Exxon/Mobil last week and was told as long as the API and the weight meet the requirements it would be fine. As far as the MS-10850 vs. MS-10725 he said it's splitting hairs and not to worry. It does meet the MB 229.3 to 229.5 spec.
MB= Mercedes Benz
MS= Material Standard
Yellow Jacket 2012 is offline
post #30 of 60 (permalink) Old 01-07-2013, 11:19 AM
Yahooligan's Avatar
Thx
Have you tried looking for a conventional 0w40 or 5w40 oil? They don't exist.
New Pennzoil SRT "Branded" Ultra 0W-40 Motor Oil JustForFun General Challenger Discussion 24 04-25-2014 09:46 AM
Pennzoil 0w40 Ultra SRT - Anybody switch to it? RobF General Challenger Discussion 65 12-27-2013 08:26 PM
Just got a letter from Chrysler group about engine oil STRONGNUFF 6.4L / 392ci (2011 - ?) 107 10-22-2012 11:18 PM
Pennzoil Enginners Q&A Session - On SRTforums.com Administrator Dodge Challenger News 0 10-22-2012 03:01 PM
Ultra Wheels, what do you think? White RT 2013 Wheels, Tires, Brakes, and Suspension 5 09-16-2012 07:44 PM
