Squeaky Clutch Pedal? - Dodge Challenger Forum: Challenger & SRT8 Forums
Old 11-29-2011, 03:35 PM
So I've had the car for a day now and I've noticed that the clutch pedal seems to make a squeaking sound (kind of like a spring sound maybe?) when I depress the pedal or when I let the pedal out. I wasn't sure if this was normal, if it was due to the car being new (only 33 miles on it when I bought it) or what. Anybody else hear this or have any advice? Thanks!
Old 11-29-2011, 03:50 PM
PRoBLeMz's Avatar
My left rear brake was squealing, I wasn't happy about it, but now after an extra 1000 miles, it has stopped. Maybe just give it sometime or some WD-40 can work some magic down there
Dodge Challenger 392 SRT8(Green w/Envy) Mods in order: oil catch-can, K&N air filter, Petty's Strut brace front/rear, tran brace, Escort 9500IX(can't stop going fast), ARH LT[Catless]/Catback Exhaust, B&G ECU Tune.
© © All names changed to protect the Innocent
Old 11-29-2011, 04:01 PM
Yeah, I was thinking that it might be because it's new and it's not been driven much. It doesn't seem like there's anything wrong with the clutch at all. It is working perfectly. And it doesn't squeak every time either.
Old 11-29-2011, 04:41 PM
blackberrychallenger11's Avatar
Photos: (5)
my clutch pedal started to do the same when the weather started to cool down before i put car away for the winter!
Old 01-30-2012, 03:00 PM
Anyone find a fix? My car did not do it during the test drive with 12 miles on car. It does not do it when you 1st drive the car, but after it warms up it does. Squeaks when you depress or release the clutch pedal. Feels like something is rubbing or a bushing.
Old 01-30-2012, 03:15 PM
Mine squeaks as well, it started @ about 5K miles in the late Fall. I'll have my dealer take a look at it under warranty once the salt is off the roads around here.
Old 01-31-2012, 06:30 AM
Guys I don't know where your clutch is squeeking from but my 65 Vette did the same thing and it was at the clutch pedal connector linkage. I used a little graphite on it and it solved the problem. I guess it just depends on what is making the pedal squeek.
Old 02-17-2012, 10:21 PM
Mine does the same thing. I have been told by 2 shops it's the throw out bearing. It has 16,000 miles and is not under warranty. They recommend turning up the radio and ignoring it until I need a new clutch.
Old 02-19-2012, 05:39 PM
Dealer fixed it. All they said was they lubricated something. I sprayed wd40 everywhere i could with no change. At least it is normal now.
Old 02-24-2012, 01:24 PM
I had this problem with my R/T, I bought it new and thought the pedal either needed to break in or the grease needed to spread. After 1500 miles of squeaking, I took it to the dealer who greased both pivots, it worked for a little but the squeak came back. It was temp dependent and only did it half as much, but it was still there. I think they just used spray lube and didn't actually take it apart and grease the pivots. This is something I figured I could fix myself, but I didn't want to fiddle with it because it has a warranty so I took it back to the dealer. They ordered a complete new pedal assembly and installed it. I thought that was a little overkill, but it worked. The mechanic said although this is the first lx manual trans he has had to work on, he said it appeared that the upper bushing was never greased from the factory, he said the new assembly was greased. I have put about 3000 more miles on it now, not one squeak!, it really makes the driving experience more pleasant! Keep up with your dealer, it may be possible there was a run of pedal pivots that left without grease.
Drake Billet Aluminum Pedal Covers 08-12 Challenger 6-Speed/Automatic SRT8U Speedlogix 8 03-31-2013 04:18 PM
Driving a Manual Transmission omen omega How-To, DIY and Tips & Tricks 11 08-21-2012 11:44 AM
Is a vibrating clutch pedal common on all 6 speeds? Carbon Hog General Challenger Discussion 4 08-04-2012 12:28 AM
Rattle/Squeak in Clutch Pedal fontaine23 General Challenger Discussion 1 07-04-2012 03:52 PM
Dealer Fixed My Sticking Clutch Crush General Challenger Discussion 10 06-25-2012 02:12 PM
