Which catch can to keep engine cover? - Page 2 - Dodge Challenger Forum: Challenger & SRT8 Forums
Go Back   Dodge Challenger Forum: Challenger & SRT8 Forums > General, Performance, and Technical > Performance Modifications > Bolt On's
Bolt On's Anything related to the quick Bolt-On mods. From Intakes to Exhausts. This includes Cams and Heads.
  #11 (permalink)
Old 01-28-2013, 05:59 PM
Yahooligan's Avatar
Originally Posted by Bornin69 View Post
I have the BT catch can with the standard mount and its the hoses that get in the way of the engine cover. I don't use the engine cover... I might get the half covers to protect the coil packs.
(I have the clean air duct too)
I have the BT/Speedlogix catch can and have the engine cover in place using the supplied + factory hoses and fender mount for the can.
I wish I would've done the intake tube first, then I could've used the engine mount. Oh well.
  #12 (permalink)
Old 01-28-2013, 06:35 PM
RWL11's Avatar
Photos: (9)
yahooligan: I have the fender mount too, but have not made the switch to the smooth intake, yet. I am going to swap for the Charger intake tube, then buy the standard mount bracket. Why? I think we will have to unbolt the catch can from the fender mount every time we want to empty it. With the front mount, all you have to do is loosen the bolt, then swing the can until you can unscrew it. What are your thoughts? I'm thinking we will still be able to route the hoses under the cover, it looks like there will be room.
RWL11
PDX, OR
[/url]
Sequentials, Speedlogix Catch Can, Charger Intake, AEM Air Filter, Blastin' Bobs Resonator Delete with Glass Packs, Billet Tech Engine Bling and Interior Bits plus Pedal Kit, MOMO Shift knob, Customized Engine Cover, Drake All-Satin Fuel Door with Billet Tech Fuel Door Insert, Big Worm Side Marker Tints, MGP Caliper Covers, Skene Designs license plate bracket, Lloyd Mats, DRL's:ON!
  #13 (permalink)
Old 01-28-2013, 07:51 PM
Yahooligan's Avatar
Re: Which catch can to keep engine cover?
I've had my can on for over 20k miles, cleaning the can only takes a hex key to remove the bolt that holds the can to the mount, then unscrew the bottom and empty it out. Not a pain at all.
Sent from my SCH-I535 using AutoGuide.Com Free App
  #14 (permalink)
Old 01-29-2013, 09:26 AM
RWL11's Avatar
Photos: (9)
I ordered my Speedlogix catch can with the fancy silver fittings, which have a larger than expected diameter. When I installed it, those fitting are right up next to the structure, and when I remove the hex bolt, and try to reattach the can, the holes don't line up well, and I almost stripped out the threads in the fitting. Moving the assembly to the front will allow me to get the can in and out easier. I want to remove that bulbous looking resonator anyway.
Thanks for your input!
  #15 (permalink)
Old 01-29-2013, 11:06 AM
Yahooligan's Avatar
Attachment 61090
I'm not sure I understand, are you saying you remove the lines when you empty the can? I don't get how you're almost stripping out the threads in one of the fittings, I don't touch the fittings or lines when I empty mine. I remove the hex-head bolt that mounts the can to the fender mount, lift the can up, unscrew the bottom, empty, and so on.
Re-attaching the can is just as easy, I have no problem lining up the holes to screw the bolt back in. I would like to move the can to the front of the engine just to clean things up a bit, but I can't seem to find just the mount.
  #16 (permalink)
Old 01-29-2013, 07:20 PM
RWL11's Avatar
Photos: (9)
see those big ass silver fittings? They make it so the can assembly itself barely fits in there. I have only just installed it, and right away I knew this wasn't gonna work longterm. If I had no fittings like in your situation, I think I would be in the clear like you. I paid for the darn fittings, I like how they look, so I don't want to ditch them.
  #17 (permalink)
Old 01-29-2013, 07:30 PM
Yahooligan's Avatar
Yes, but I lift the can straight up after flipping open the windshield washer cap, even if I had the fittings they wouldn't hit anything. All I have to do is slide the hoses over the opening of the washer fluid cap and then I can unscrew the bottom. Sorry if I'm missing something obvious, I just don't see what the fittings will hit if you lift the can up.
  #18 (permalink)
Old 02-17-2013, 02:00 PM
RWL11's Avatar
Photos: (9)
yahoo: here's a close up shot of my can: Which catch can to keep engine cover?-img_0989.jpg
The big a$$ fitting give me no wiggle room to take it out and re-install.
I bought a Charger intake, and ordered a new front engine mount for it. When I get that mount, I am moving my can to the front.
Catch Cans - I'm a Believer rayzazoo General Challenger Discussion 142 03-02-2013 04:41 PM
SOLD: Hemi Orange Engine Cover UltimateChallenger Parts For Sale/Wanted/Trade 7 01-26-2013 11:27 PM
Painted engine cover TB632 Dodge Challenger SE/SXT Specific 9 12-29-2012 08:22 AM
LMI True CAI and Moroso Can installation on 5.7L w/ pics (messed up the can) fishgoh0nk Bolt On's 4 12-08-2012 05:45 AM
57 HEMI Engine Cover Centerpiece Removal ?? HEMIChallenger426 How-To, DIY and Tips & Tricks 5 09-08-2012 09:16 PM
