Oil catch can - Page 2 - Dodge Challenger Forum: Challenger & SRT8 Forums
Bolt On's Anything related to the quick Bolt-On mods. From Intakes to Exhausts. This includes Cams and Heads.
post #11 of 25 (permalink) Old 01-09-2017, 08:21 AM
Nuke's Avatar
Originally Posted by Bobbyswiz View Post
So, I posted awhile back about how I was looking into getting one of these and then I read that people were getting warranties voided and having VIN's flagged for even the slightest changes...kinda made me nervous so I stopped and didn't buy one. Any clarification on this?
IMO, that sort of behavior by the dealer's service dept. should only be considered as a 'con' when evaluating the pros vs cons of any modifications to the car, not the catch can in particular.
In other words, the service department that is willing to treat their customer that badly because of a catch can is likely to treat them just as badly for any modification. They are an exception and not the rule when it comes to service departments in my experience, and you shouldn't be deterred from installing a catch can for fear of that treatment because if you run into that one bad apple, they'll gig you for something else you've done even if you don't have CC.
Nuke is offline
post #12 of 25 (permalink) Old 01-09-2017, 08:46 AM
Originally Posted by Cuda340 View Post
The absence of a catch can will not damage your engine. The issue is engine efficiency. It prevents a build up of oil residue that can result in a loss of power to your engine, over time, due to PCM-pulled timing.
During normal operation, a small amount of that ignited air/fuel mixture leaks past the piston rings and ends up in the crankcase. This leakage is called “blow-by” (leakage past the piston rings), as well as oil mist. Some of the oil mist and other products settle along the engine intake and over time form a “gunk.”
The oil catch can collects the oil mist and condenses the fuel vapors while allowing “cleaner” gases to be passed back into the intake. The OEM system does a great job of meeting emission standards and removing the harmful contaminants, but the unintended consequences are the oil that is drawn into the intake charge. For an engine to produce the maximum amount of energy per explosion (of the A/F in the combustion chamber) you want air & fuel only- any amount of oil in this mix will hamper the explosion resulting in less energy released, detonation, and carbon buildup.
Trapping and removing this oil before it gets into the combustion chamber is the only solution to maintain maximum engine efficiency and prevent excessive carbon buildup. (Note- This is especially critical on turbo cars).
Great explanation Cuda!
mikesrtclassic is offline
post #13 of 25 (permalink) Old 01-09-2017, 11:23 AM
Nuke's Avatar
Yes, that was a very good synopsis of the most common use-case scenario for the CC, but he neglected to go into detail about another, just as important IMO, reason for running with a CC - they prevent having to pay for PEEs (Paranormal Entity Extractions)!
Let's say you're drag racing within earshot of a cemetery, and earlier that day there was a burial of an old gear-head from way back. Well once his ghost hears all that noise and smells the burning rubber, he's gonna waft over to take a look. Then BAM, he ventures a little too close and gets sucked into one of the car's engines as it's making a run down the track. Now what?
Well, the normal fix for that problem is to pay the local mechanic to perform a PEE by tearing down the engine and manually extracting that old gear-head's ghost with whatever fancy machine they use to do such tasks. But I've heard that can run north of $2K on some cars, depending upon how stubbornly entrenched the ghost is and intent on staying put.
But by running a CC, you can avoid that hassle and expense. As the ghost circulates through the running engine, doing whatever it is they do inside there, they'll eventually end up in the CCV system and get sucked through the PCV line and into the catch can, where they will be trapped until you can empty out the can and set them free.
I don't know about you, but I don't have an extra $2K laying around to be paying for PEEs, so I'll be running the CC on all my cars instead!
Nuke is offline
post #14 of 25 (permalink) Old 01-09-2017, 02:28 PM
Cuda340's Avatar
Originally Posted by Nuke View Post
Yes, that was a very good synopsis of the most common use-case scenario for the CC, but he neglected to go into detail about another, just as important IMO, reason for running with a CC - they prevent having to pay for PEEs (Paranormal Entity Extractions)! Let's say you're drag racing within earshot of a cemetery, and earlier that day there was a burial of an old gear-head from way back. Well once his ghost hears all that noise and smells the burning rubber, he's gonna waft over to take a look. Then BAM, he ventures a little too close and gets sucked into one of the car's engines as it's making a run down the track. Now what? Well, the normal fix for that problem is to pay the local mechanic to perform a PEE by tearing down the engine and manually extracting that old gear-head's ghost with whatever fancy machine they use to do such tasks. But I've heard that can run north of $2K on some cars, depending upon how stubbornly entrenched the ghost is and intent on staying put. But by running a CC, you can avoid that hassle and expense. As the ghost circulates through the running engine, doing whatever it is they do inside there, they'll eventually end up in the CCV system and get sucked through the PCV line and into the catch can, where they will be trapped until you can empty out the can and set them free.
Do you mean something similar to what happened to this poor girl?
Cuda340 is online now
Nuke (01-09-2017)
post #15 of 25 (permalink) Old 01-09-2017, 02:55 PM
Nuke's Avatar
Yep, as long as he's running CC, extracting her from the engine should be a breeze!
Although I do hope his CC bowl is of the extra-capacity type, cause based on the size of those sweater kittens, she'll need all the room she can get!
Nuke is offline
post #16 of 25 (permalink) Old 01-09-2017, 07:46 PM
DeSimoni's Avatar
Just did another oil change yesterday, I do a lot of LA Driving (stop and go) and my Catch Can was full, yes full... aaarrrgghh. Not sure how long it's been full but I wanted to kick myself in the ass for letting it get to this point.
2016 SXT Plus - Blue Bella
DeSimoni is offline
post #17 of 25 (permalink) Old 01-09-2017, 10:42 PM
ElPasoBob's Avatar
Originally Posted by DeSimoni View Post
Just did another oil change yesterday, I do a lot of LA Driving (stop and go) and my Catch Can was full, yes full... aaarrrgghh. Not sure how long it's been full but I wanted to kick my self in the ass for letting it get to this point.
I would think that letting it get full to where it's pulling liquid oil is a lot worse than not having a can at all. I'd be pissed at me to
How many miles did it take to fill it up with oil?
El Paso Bob
ElPasoBob is offline
post #18 of 25 (permalink) Old 01-10-2017, 12:45 AM
DeSimoni's Avatar
I am running Amsoil full synthetic. The car is having it's first birthday soon and I just turned 20k miles. I changed the Amsoil last time at about 12k miles and I checked the catch can then and again at about 14k miles. So it had about 6k miles on it. Im going to add it to to my monthly todo.
DeSimoni is offline
post #19 of 25 (permalink) Old 01-10-2017, 05:46 AM
Cuda340's Avatar
Besides the cost, the maintenance factor is one of the main reasons why car manufacturers don't install catch cans. It's easier just to burn the oil.
post #20 of 25 (permalink) Old 01-10-2017, 06:03 AM
steve37887's Avatar
Sent from my SM-S975L using Tapatalk
steve37887 is offline
  Dodge Challenger Forum: Challenger & SRT8 Forums > General, Performance, and Technical > Performance Modifications > Bolt On's
Mystery Grey IAT Sensor Connector - SOLVED! rayzazoo Articles - Engine, Other 130 10-11-2016 03:37 AM
UPR Plug and Play Catch Can 2011-2016 5.7L and 392 Challenger/Charger/300 Speedlogix-Sales Speedlogix 2 09-27-2016 03:17 PM
Dropped and can't find oil catch can drain plug... Doug444UT General Challenger Discussion 2 04-02-2016 07:54 PM
Would a catch can cooler help to promote oil condensation in the can? 15RT Bolt On's 6 02-26-2015 11:57 AM
She's a Smokin chalngd 6.4L / 392ci (2011 - ?) 27 09-26-2013 08:26 PM
