So I've read a lot about part throttle boost and I have a question. Under part throttle, my car will shudder, as if the bypass valve is rapidly opening and closing. It's very rapid, as if it were a machine gun. There's no real way to avoid it unless you back off the throttle or increase throttle and go 100% into boost.
This was an annoyance when I was at 6 psi but now that I am at 13 psi it can be a rather violent experience.
I've had my tuner make adjustments, thinking it may be a tuning issue but got nowhere. I'm left to believe that it's the bypass valve trying to decide wether to be open or closed, but I don't know for certain.
I talked to Magnuson and they were no help. I asked if they had a stronger bypass that kicked in later and the answer was no.
Has anyone else had this issue and solved it? I have a hard time believing that every other Magnuson owner has the same issues and is just living with it.
Edit: Just to clarify, the shuddering happens when I am in semi aggressive part throttle. When I am at a lighter part throttle (accelerating up a grade on the highway) it is much milder. The surging feels like I am pressing the gas once per second and then letting off. The more throttle I give it, the quicker and harder the surging gets, until it eventually has the machine gun feel.
No answers for you but I believe I have the same thing with mine. Whipple at 9psi. I thought it was something to do with the variable timing switching.
That's an interesting theory I haven't heard yet. One other thread I read was saying it might be the computer sensing power too soon and closing off he throttle body.
It's in the tune. There are 2 different ports on a Maggie to hook to. One is more aggressive then the other. try switching it..or you can get a black box from drag city to keep you out of boost until you want it. Search black box
I had the same problem with my Maggie. Luke got me a new tune from Arrington Performance and it smoothed right out. It took a little time but now that they have it solved there should be no problem.
there is very little you can do with mechanical bypasses, nearly all superchargers use a mechanically actuated by pass that relies on manifold vacuum to open and close, at 6/7 psi, not much issue but at higher boost, a serious issue, until someone designs and builds electronically control by pass that can programmed not a lot you can
what we have done to improve driveability, we have added small spring to the bypass arm making it more difficult to close, requiring more vacuum to close in order to delay the reaction, and to a point have been successful in improving the linear driveability, you do have to get unto the throttle much harder to go into boost
anybody that has been reading my posts from way back will remember that i have stated over and over that there is a fine line between street and race car, once you pass 600+ whps, driveability becomes affected and the pure joy of just driving is affected
Bigred is a monster, but also a monster to drive, parking lot maneuvers are a major pain in the butt
I'll also add a recommendation for Mike @ OST.
He had my 2012 Yellow Jacket with a Maggie at 8 psi. driving better than any other tuner I've worked with.
Same thing, once on the dyno it needed no changes.
You are correct, when I was at 6psi the surging was hardly noticeable and I could live with it. Now that I'm pushing 700whp, that surging is a beast. I'm fabricating a bracket for a spring setup as we speak, to hold that bypass open for a little longer.
Again, thanks for the phone call today.
As far as tuning goes, I had a revision that I installed this morning and it made no difference. I'm thinking this is mostly a mechanical (bypass) issue.
Is this a Maggie issue? I have a similar problem on my Vortech, when in either 5th or 6th, and I'm aggressive with throttle as it passes thru 2400 to 2600 RPM range I get a engine jerk, we have determined it is a lean condition with no knock, then it's gone.
Did you ever get this resolved? Also, forgot to ask if you've modified the bypass valve on the supercharger? Maybe its more difficult to tune that way.
I'm working on belt issues right now. I will probably try and fab up some sort of bracket for a spring next week. The bypass valve hang been modified. I'll post an update as soon as I get a spring on here.
Just as an added bit of info from my own experimentation, the part throttle boost somewhat depends on where the vacuum line to the bypass actuator is connected. I have much more surging and PTB if it's connected to the intake snout than if I have it connected to a port on the supercharger base plate.
what I found was that my car was attempting to go into boost way too easily in part throttle. I initially attempted to resolve it by lowering the voltage in which the car went into PE, thinking it was just going lean and commanding stoich under boost. That didn't resolve the issue. However, I also noticed that it happened that I could stab the throttle into boost and the car was fine. I did back to back scenarios where I went into boost gradually and one where I stabbed it and what I found was that when I went in gradually, the car commanded PE fueling as set up in the tune but the cam position was not following the WOT table. In the attachment you can see that the exhaust cam position is still retarded at 93* where the boost came in gradual. If you look at the white spark line you can see that it's choppy as the car shuddered. In the bottom pick you can see I stabbed the throttle and the exhaust cam position advanced to 120* and all is well.
The fix was to set my throttle % and it's inverse table back to stock as opposed to having it advanced. I think you Diablo guys call it throttle boost. I've since been able to advance some of the early columns so the car is still responsive around town but as it gets up into the 50% + ranges, I let things alone. The reason, I theorize, that this affected things is because the inverse table goes off NVRATIO, which is the Vehicle Speed / RPM. If your car thinks it's moving faster at a given RPM, than it really is, it won't shift (see the trans part throttle shift tables). If your car isn't downshifting early enough, it goes into load / boost too early and at too low of a voltage for your car to flip the cam VVT setting to use the WOT table.
Hope that helps someone. Between that and torque management I figured out the tune on a '14 Charger RT that also has heads, cam and headers with a Procharger. My car has heads, cam and headers with a Whipple. I had to start with no base tune so I figured it all out on my own.
I'll grab a couple screenshots later but the short answer, that I found worked, was to set my exhaust cam position to mimic wot at each RPM range. Now there are not drastic variances in cam position when transitioning from part throttle to full throttle. I did this on my Whipple and my buddy's ProCharger and all stumble went away. We have tried to reproduce it and cannot.
In for the knowledge as well,was curious if this was due to the intake manifold swtching runner length and something the Eddy intake or a 6.1 intake may help.
May boost in the future so always curious since my choice would be positive displacement boost.
