| Performance Modifications Want to talk about performance modifications for your Dodge Challenger? This is the forum for that. Anything from exhaust systems to power adders and everything in between. (Dodge Challenger Performance Modifications) |
Re: 2009 SE to 6.4L
I would just swap the computers (probably $500-$800), drop in a 6.4 stroker from PPP (about $8-9k), drop in the 6 speed tranny and rear end off of the SRT's (probably another $3k or more). That should be strong enough to handle the power. Maybe even upgrade the brakes because you will need them unless you dont plan on using the 6.4L's power lol.
Re: 2009 SE to 6.4L
If you're planning on doing heavy modification (426 stroker engine with all its requirements, 6 spd tranny, brakes, suspension, halfshafts, etc) wouldnt gutting and rebuilding a v-6 be the cheaper/smarter route than doing the same to an SRT? I mean if you bought the 22k v6, thats about 18 grand left over compared to an SRT to spend on mods...and I would bet you could have just as good, if not better end product than just a stock srt. I mean if you buy a stock srt and end up buying all the same upgrades, seems like all you are doing is replacing more expensive SRT parts instead of cheaper V6 ones. Granted you would have to do most of the handy work yourself to make it work. Can anyone else back this up, or is still better to start from an SRT platform?
Re: 2009 SE to 6.4L
Originally Posted by falconma
If you did all of the work yourself this would be the cheapest way to go. The labor costs would add up if you had someone do the work though. So it depends. Thats actually not a bad idea, it would be a killer sleeper. Thats for certain.
Re: 2009 SE to 6.4L
that sounds about right tim. How much is the 426 short block going for right now?
Re: 2009 SE to 6.4L
have you done this conversion on a v-6 yet? this is the way i want to go because I dont want to part with my ride
Re: 2009 SE to 6.4L
A 426 short block ranges from 5999.99 up, depending on what uprades you choose. So if you want to run 15PSI of forced induction, your engine will be an additional $1,500 or more. Also there is a $1,000 core charge if you do not have 6.1 engine block. So 5999.99 + 1,000= $6,999 +
Our PPP Stage 2 Heads are $2,195 with a $1200 core charge. If you do not have 6.1 heads for the core then it would be 2195+1200= $3395 for the heads. Cams are normally $450 Headers: Kooks and American Racing are around $1300-1500 You will need a Intake manifold: Figure $1,000 core + if you want ported it will additional 699. So $1699 for the intake The list can go on and on. Thats $13,843 and there are many, many parts left out and there hasnt been any labor added. A short block install in a V8 car will typically take 20 hours or so, X the labor rate of $90-$125 per hour. Prices vary from shop to shop. The pricing above can be higher or lower all depending on which options you choose for your specific application. If you are really serious about this project, give me a call and we will see what we can come up with. No we have not done a full v6 to SRT/PPP 426 build.
