6.4/392 Cam Swap Drivability Results? - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 24 (permalink) Old 12-18-2013, 08:05 AM Thread Starter
Mike V.'s Avatar
Now that there are quite a few cam swaps out there... With any cam swap I expect general drivability and even mileage to change.
How is the drivability of your car?
How affected is your city and highway mileage?
How is the cam in low speed city driving? Is the responsiveness better at low speeds? How is highway cruising?
While not as aggressive as the Comp VVT cams, the 392 cam is quite a jump from the stock Eagle setup.
Thanks!
Mike
2009 Hemi Orange Challenger R/T 6-speed
bone stock other than a set of 17x9 steelies with some sticky tires.
Best MPG: 32.7 - Hyper-miling a Challenger R/T is quite odd.
Best E.T.: 13.585 @ 103.69
Mike V. is offline
The Following User Says Thank You to Mike V. For This Useful Post:
pacman2012 (12-21-2013)
post #2 of 24 (permalink) Old 12-20-2013, 07:54 AM
C13RT's Avatar
I think the lack of response is because this is mostly answered in the various other 6.4 Cam threads...
I was curious to see if anyone would chime in so we could have a concentrated thread on those questions and answers instead of having to read through 15+ page threads to find the answer.
I to am curious to know if there is any increase, decrease or the same type of MPG in the city/highway as well.
2013 Challenger R/T Classic
External Mod: Cervinis T/A Hood, Seibon CF Grille
Performance: 93 OCT (diablotoona tune), BT Catch Can, Modern Muscle Ported 87mm Throttle Body, 6.4 OEM Cam Swap, Inertia Ported Cylinder Heads, 190 degree Thermostat, JBA Titanium Shorty Headers, Thrush Glass packs (center), Magnaflow mufflers (resonators)
2015 BMW 28i X3
K&N Drop in filter
C13RT is offline
post #3 of 24 (permalink) Old 12-20-2013, 08:27 AM
I did the cam swap, heads, and headers at the same time so I may not be a perfect representation of what you are looking for. My driveability was really no different at lower RPM. The big change happened at 4k. The car just went into beast mode. Which doesn't sound good on paper but if you think about it it kind of works out better that way. If you give your car the beans from a stand still you are fighting for traction. So from idle to 4k you are driving pretty much normally without any or much added power. But when you hit the the 4k range, where we play when we race, you feel a 60hp difference.
My MPG only dropped by an average of 1MPG.
I'm finding that increased power at lower RPM is not really that fantastic. I have a E-Force which is a screw type SC and while fun to spin the wheels as I please. I liked how my car was set up NA a little better where it was normal driveability down low and whoah up high. In retrospect maybe I should have went turbo or centri type SC. We'll see how my final tuning goes and if it smooths out some of the dislikes I have about the driveability of the SC.
2009 R/T Trak Pak(M6 3.73)-SRT Functional Hood Scoops-SRT Suspension-SRT Alcoa Wheels-2011+Long IAT Sensor-Skip Shift Eliminator-JET 180 Tstat-RPI Acrylic Side Marker Blackouts-20% Window Tint-Diablo Trinity-Hurst Billet Shifter-PWR Eagle Mean Street Heads-392 Cam-JBA Titanium Coated Long Tube Header-JBA Catless Mids-DynoMax VT Cat Back-Arrington CC-Zeitronix ZT2-Edelbrock EForce 3.25"-Brembo Brakes w/SS Braided Brake Lines-Arrington 90mm TB-Hotchkis SRT8 Sport Coil Springs
jaelliott is offline
The Following 2 Users Say Thank You to jaelliott For This Useful Post:
salvy59 (12-20-2013), Triz (12-20-2013)
post #4 of 24 (permalink) Old 12-20-2013, 08:42 AM
Two words: excellent driveability
Normally aspirated, stock manifolds, CMR tune (Diablo e-mail tune)
MPG: slight drop city ~ 1.25 from stock
hwy - similar, but haven't taken extended drives to explore further
Custom tune brought out more low end power (over canned 91 CAI tune), mid and extended upper end power output.
The only other 'side effect' is the EVIC shows lower MPG than actual...the tune may throw off how the system calcs, but its no biggie...
Hal H is offline
Flat Top (12-21-2013)
post #5 of 24 (permalink) Old 12-20-2013, 08:48 AM
salvy59's Avatar
Hal H
>>> is this Exhaust or intake manifold or both? I would like 60 to 80 HP more in the future..
"You may be disappointed if you fail, but you are doomed if you don't try"
salvy59 is offline
post #6 of 24 (permalink) Old 12-20-2013, 10:21 AM
Originally Posted by salvy59 View Post
Hal H
Both - the add'l 12hp from changing the exhaust vs. the cost of parts (I'd favor the clamshell SRT manifolds for mitigating heat in engine bay vs. aftermarket shortys), mid-pipes, labor, its not worth $1k to me for the small gain.
Time and again most of the guys (local shop that works on a lot of Hemis) recommend pull the heads when changing out exhaust...now that's a lot of work, even if doing it yourself.
Paying for someone to that, you can imagine the $$ for that.
Hal H is offline
19johned53 (12-20-2013)
post #7 of 24 (permalink) Old 12-20-2013, 12:02 PM
My ride was already s/c'd but I did not notice any gas mileage decrease from before aside from flooring it. The main thing I noticed as well as others was the sound idling and driving. Which now sounds more like a muscle car.
Very pleased with the results it also idles well not really lumpy.
2010 RT Classic, auto, Eibach Pro Kit, JBA shorty, Serious Metal Catch can, 180 T-Stat, Magnuson 8 Lbs boost, BBK 90mm Throttle body, Carbon fiber CAI, Magnaflow Catback, SMF Strut Tower Brace, SMF Big brake conversion, some other goodies and a custom tune by Johan
Toddsmith is offline
post #8 of 24 (permalink) Old 12-20-2013, 02:53 PM
salvy59's Avatar
Gotcha on the clam shell, but do you change the intake manifold, and replace it with A 6.1 aluminum one from the 6.1?
salvy59 is offline
post #9 of 24 (permalink) Old 12-20-2013, 06:50 PM
One could do that - but I'd imagine the composite 5.7 (and now the 6.4) would run cooler compared to the AL manifold of the 6.1. It certainly is more to look at from the aesthetic point of view.
Hal H is offline
post #10 of 24 (permalink) Old 12-20-2013, 11:49 PM
salvy59's Avatar
so normally when people do cam swaps and ported heads and clamshell exhaust they stick with the 5.7 composite manifold?
salvy59 is offline
6.4 cam swap in 2010 RT Classic Toddsmith Bolt On's 84 12-14-2014 02:43 PM
Need help cam swap TheLeadSled Performance Modifications 3 11-16-2013 07:39 PM
My dyno charts before and after cam swap DaltonR/Tclassic Dodge Challenger R/T Specific 23 10-11-2013 01:32 PM
E-mail tune for 5.7 with 6.4 cam swap? Al Bundy Performance Modifications 2 07-28-2013 09:13 AM
Cam swap plumcrazyfast 6.1L (2008 - 2010) 8 09-15-2012 03:21 PM
