Any tips on headers install? - Dodge Challenger Forum: Challenger & SRT8 Forums
Go Back   Dodge Challenger Forum: Challenger & SRT8 Forums > General, Performance, and Technical > Performance Modifications
Old 08-06-2009, 01:39 PM
Stumpy's Avatar
My Kooks headers with the high flow cats should be coming soon and I figured I would see if there was any tips to make my install easier.
I have the R/T with Corsa catbacks already installed.
Andy <--- excited!
2009 Black Challenger R/T
MODS:
Corsa cat-back exhaust
Roto-Fab CAI
Predator custom tune
180 Tstat
85mm Modern Muscle Throttle Body
Kooks headers with hi flow cats
Old 08-06-2009, 04:42 PM
Pacience, plan for 6+ hours, have 2 people help, read the directions before starting and get all needed supplies, like silicone sealent, etc. Get the proper torque specs, and locking bolts.
07 3.5L Charger K&N CAI, Magnaflow Cat back, JBA shorty's, DS 93 tune, sold, 2010 Challenger R/T 5 speed. 180 degree Thermostat, fan settings lowered, CC, ceramic brake pads, slotted rotors, red and black caliper paint, Challenger label for calipers, Corsa Cat back, functional hood ducts, and hood struts, 93 DiabloSport tune, Mopar drop in filter, JBA Shorties, Wideband O2, custome tweaked tune, Anti-sway bars front and rear, end links, strut brace, 12" subwoofer with amp.
Old 08-13-2009, 04:46 AM
alamochally's Avatar
If you don't already have one, get a 10mm combination wrench with a flex, ratcheting head. It will be your best friend for four hours!
Just put mine on, took eight weeks for them to arrive. There are lots of posts about them being a waste of money (mine is a SRT), but they look awesome, and the sound is even better!
Old 08-13-2009, 08:11 AM
DCSDawg's Avatar
And don't you have to turn off your rear O2 sensors with a Predator?
MBRP Exhaust/Jet T-Stat/Mattico Tint/Hurst Short Throw/BT Catch Can/Hawk Performance Ceramics/3.0L Techco QD Twinscrew
"Walk SOFTLY and carry a BIG stick...."
Old 08-13-2009, 08:51 AM
Yes, rear O2s will have to be turned off or you'll get a CEL for cat inefficiency.
Old 08-13-2009, 11:06 AM
Stumpy's Avatar
I feel like your speaking another language, what does all that mean?
Old 08-13-2009, 11:08 AM
Yeah, the thing holding me up with my Kooks headers is being unable to get anyone motivated to help. I don't really wanna be under the car wrestling with that **** all by myself - though where's a good place to locate the torque specs?
And any particular brand of silicone sealant better than the rest?
And Stumpy, go get Mopar SRT8 gaskets for your headers from your local Dodge dealer. Only like $8 apeice and all the needed bolts will run about another $8-9. Prettymuch everyone I've spoken to has said SRT8's are the proper fit. Also, don't bother using the Kooks gaskets. They make good metalwork but their gaskets are crap. Lol. =/
Performance: 180 T-stat, MBRP Cat-Back, Diablosport Tune - Kooks Headers/Mids pending.
Appearance: 5% rear, 35% fore tint.
Old 08-13-2009, 11:25 AM
You may wanna read up some. Lots of discussion on the issue I've described, but in a nutshell the high flow cats will cause a check engine light.
Old 08-13-2009, 03:57 PM
Any notice in performance change? Do any 0-60 testing before and after, dyno testing, or just seat of the pantce feal?
Old 08-13-2009, 04:17 PM
If you are using long tube headers you may occassionally get a check engine light, because the O2 sensor throwing a flag to the comptuer. You can turn them off with the DiabloSport Tuner, but with short tubes it shouldnt be an issue.
For my 3.5L I just used the highes heat available from the auto parts store and am not aware of any issues. For the torque specs, you need a service manual. I dont have one yet for the Challenger, but from the 2007 Charger manual the following is from the install part to re-install the factory exaust manafold on the 5.7L
1. Install manifold gasket and manifold.
2. Install manifold bolts and tighten to 25 N·m (18 ft. lbs.).
3. Install heat shield and tighten nuts to 8 N·m (70 in. lbs.).
CEL = Check Engine Light.
cat inefficiency, means the catalitic converters must be able to eleminate the majority of the emmissions, and with them being high flow and farther from the engine it may not get hot enough to blast off all the emmissions, so because it isnt as good at getting all that stuff cleaned out as with short headers and restrictive stock cats, you get a check engine light sometimes when it goes pass a threshold. (This may be a bit off, but more in lamems terms, and close enough to answer what he wants)
JBA Long Tube Headers for 5.7L/6.1L/6.4L LX- Awesome Sale @ MarylandSpeed! MarylandSpeed Maryland Speed 4 04-04-2013 04:07 PM
Sequentials install tips threads ? LETSJET Audio, Video and other Car Electronics 7 11-05-2012 04:02 PM
Kooks LT Header Install....tips? OChallenger Bolt On's 9 08-30-2012 09:50 AM
