| Performance Modifications Want to talk about performance modifications for your Dodge Challenger? This is the forum for that. Anything from exhaust systems to power adders and everything in between. (Dodge Challenger Performance Modifications) |
Re: Basic mods for the 5.7?
correct, you need to purchase one. But you can use it on other vehicles. The way to do so is to restore your car to its factory settings, then it removes the lock between the predator and your car. Thus allowing you to use it on another car.
i would say any cat back, and cold air intake would be fine without any warranty issues. Probably not much else.
Dodge tends to be leanient on the whole aftermarket thing. The only other issue I'm seeing with my future R/T, is it's a 5-speed Autostick. Which means, yes, I have the MDS. I know I cannot cam the engine without a lot of work, but that's not a problem. All other mods should take alright, shouldn't they? Or will the MDS mess with the tuning? I do plan on modifying the vehicle extensivley. Would a 6-speed straight 5.7 work better for that? Any advice is awesome.
Originally Posted by 09R/T_Semper
If you are dying for the automatic thats fine, you can turn off the MDS.
If you dont care what tranny you get, id say just get the 6 speed and save yourself the hassle of the MDS. That is just something else to go wrong IMO |
We have many customers who had MDS lifters. It is a very easy swap to convert to non-mds. If you are planning on upgrading the cam, you simply install 6.1L lifters and turn off MDS. You will not have any issues and we do this weekly. The reason you need to get 6.1L lifters is because they are able to handle a larger cam then the MDS lifters are capable of. --MDS lifters will collapase under the increased lift and duration.
Again- this is not a deterant to getting a upgraded cam.
