Getrag 226 MM with Richmond 3:55 gears? - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 33 (permalink) Old 02-27-2012, 02:49 PM Thread Starter
hashmaker's Avatar
Now that Richmond has offered 3:55 gears for a few months has anyone made the change? I don't find anything in a search for the 226MM. I am interested in doing this. Any ratio changes made doing the ring & pinion vs. the whole differential in a 226 Getrag?
Thanks in advance.
2009 Challenger SRT8 Auto, TorRed
Mods: Mac's Cold Air Intake, BBK 85 MM TB, 17% Throttle boost, MAPerformance ported intake, 180 stat., ARH Long tubes & High flow cats, Solo Mach 3 cat back, Paramount Valve body, Predator custom Dyno Tune, 420 RWHP, 450 RWTQ, Stack Performance catch can, Front & Rear Razors Edge strut bars, Nitto Invos, Carbon Fiber pistol grip shift handle. BT engine bling.
hashmaker is offline
post #2 of 33 (permalink) Old 03-12-2012, 07:10 AM
SwiftSRT's Avatar
SRT Gears
Thanks in advance.
I just now saw a write up dated 2/28/2012 that says U.S. Gear has come out with 3.23 and 3.55 gears for our 226mm getrags! I plan to be one of the first in line for the 3.23's. I'm going to call Unitrax today and try to set up an install for my 09 Challenger SRT. Here's a link.
http://www.unitrax.biz/?tag=dodge-challenger
SwiftSRT is offline
post #3 of 33 (permalink) Old 03-12-2012, 11:18 AM Thread Starter
hashmaker's Avatar
That is good news. I would rather have 3:23s. It does not appear anyone has changed just a ring & pinion yet as there were no replies about it.
Luke did send me the instructions out of the factory manual, it does not look as easy as other differentials I have worked on but it can be done. Thanks for the update.
If you get it done before me keep in touch.
Thanks
post #4 of 33 (permalink) Old 03-12-2012, 03:21 PM
flen2000's Avatar
How to identify the Getrag H266 aluminum
How do you identify the Getrag H266. I want to run the 4.10 gear set. Factory 3.70 now
2010 R/T 6 Speed, Cat Back, CAI, BT Catch can, Skip Shift Eliminator, Predator, Hurst Shifter w/Rod Mod, Stack Performance Springs, Chubby Pro sway bars, Kooks LT's & high flow cats.
flen2000 is offline
post #5 of 33 (permalink) Old 03-12-2012, 03:35 PM
70barcuda's Avatar
Are you asking how do you know if you have the Getrag 226 rear? If that is what you are asking the answer is you do, since all six speeds and SRT's (with the exception of 2008 cars) have it.
2014 SRT Core - 12.091 @ 114.03 mph
2010 R/T - PB 12.87 Traded
I know my car runs 10's because I once beat a guy who said his car runs 11's.
70barcuda is offline
post #6 of 33 (permalink) Old 03-12-2012, 06:53 PM
does anybody know if the predator tuner supports these ratios?
2010 Challenger SRT auto, Brilliant Black Strip delete, Mopar CAI, Mopar Cat Back exhaust, 93 CAI tune, 180 t-stat , T shift handle
uscbrave is offline
post #7 of 33 (permalink) Old 03-12-2012, 09:12 PM
Doesn't matter as long as you don't change the size [diameter] of the tires. Speed pickup is via the anti-lock brakes wheel sensors.
Not sure how the TCM will react, a 6spd won't care since it has no way of knowing what gear you're in.
CaptnCrash is offline
post #8 of 33 (permalink) Old 03-13-2012, 07:37 AM Thread Starter
hashmaker's Avatar
Yes, The Predater does allow for these ratios.
post #9 of 33 (permalink) Old 03-13-2012, 09:42 AM
Here's what the Getrag 226MM center section looks like - it has ribs cast into the aluminum case: (the 215MM has a smooth cast-iron case)
2016 392 Hemi Scat Pack Shaker 23Y pkg (6 speed MT) ordered 8/28/15, born 10/23/15, home 11/20/15
Hal H is online now
post #10 of 33 (permalink) Old 03-13-2012, 06:56 PM
auto's will go into " limp mode " unless you adjust for the gear change and / or tire size changes
uscbrave is offline
