Hurst install - Dodge Challenger Forum: Challenger & SRT8 Forums
Go Back   Dodge Challenger Forum: Challenger & SRT8 Forums > General, Performance, and Technical > Performance Modifications
Old 06-26-2010, 03:48 PM
eecom's Avatar
Photos: (9)
Hurst install
I installed the Hurst shifter I bought with my Mopar bucks this morning. Install took less than two hours, and that was allowing for a trip to the hardware store to replace a nut that decided to disappear in my garage after I dropped it. The install kit came with additional instructions and pieces to help with the noise complaints we've all heard about. All it consisted of was several small pieces of Dynamat and 2 rubber isolaters that go between the shifter and the stick if you use the straight stick with the white ball that is included with the shifter. I used my Gunslinger pistol grip lever so the rubber pieces were not installed. The Dynamat simply wraps around the shift rod clevis ends where it bolts to the tranny and shifter. A short test drive proved no noise or vibration complants from me, but then I expect a racing piece with tight tolorances to transmit some type of mechanical signals. To me, that's a plus, as long as it's not a constant buzz or drone that drives you crazy. I never had any complaints with the stock shifter until I installed the Hurst piece....now I see (feel?) the stocker's shortcomings. The lever moves with just the right amount of force and goes from a perfectly designed stop to another stop in the next gear, in the blink of an eye. There is no play at all....crisp, tight, and defined.
Old 06-26-2010, 09:37 PM
Really glad you're happy with it, eecom. They're nice pieces and really improve the enjoyment factor for the car. Throws are much shorter and crisp.
I'm on my second one, and that one has imploded as well. Chews up the o-rings that reside in a couple of places: small pin with three grooves that runs parallel to the ground through the shifter block (black part) and the three larger o-rings on the shifter rod.
With some luck, you won't have any problems with yours. Some do and many don't.
HemiSam
Old 06-27-2010, 01:42 PM
eecom's Avatar
Photos: (9)
Yeah, Sam I'm well aware of your plight as well as your fix. I read that thread front to back. Wish me luck. BTW How big is your right arm? LOL!
Old 06-27-2010, 02:35 PM
LOL! Not that big eecom... Odds are you'll be fine. There's a bunch of guys running them w/o problems. I really love the darn things. MUCH better than the stocker.
HemiSam
Manual Hurst Pistol grip shift handle (OEM) installed into HURST assembly Rudedog Interior Discussion / Modifications 13 09-01-2012 05:11 AM
Hurst Short Throw....definately worth spending the extra dough! Roshambo Interior Discussion / Modifications 4 08-31-2012 03:27 PM
Just finished an install, 2.8L water cooled kit on a 2010 SRT-8 Hreagle Kenne Bell 8 08-31-2012 01:04 PM
Hurst Roll Control Installation Kit help? SpudRacer General Challenger Discussion 5 08-20-2012 08:44 AM
