Maggie cooling question??? - Dodge Challenger Forum: Challenger & SRT8 Forums
Go Back   Dodge Challenger Forum: Challenger & SRT8 Forums > General, Performance, and Technical > Performance Modifications
Old 12-13-2010, 06:30 AM
While at the track with John (SRT5939), I watched him turn his ignition on, and seen the coolant flowing through his SC coolant tank. At that time, he was able to put ice in there to help out between runs.
Well when I turned my key on, and opened mine, I did not see anything slowing, it was full, but not flowing. Can anyone else confirm this? Would be nice to have it flow in between runs with the key on like John's does....
09 SRT8 Auto Challenger. Manacharged, Flowmasters, Res Delete, Locpick 497 rwhp
PB 12.07 at 118mph on 20" Street tires-Atco 11/20/10
11.56 @119.81 on 17" Hoosiers -Atco 3/20/11
Old 12-13-2010, 07:03 AM
DRAG CITY's Avatar
Had the same issue during install...Key on no power to pump but start engine and you'll have flow.
HOT ROD ON
Old 12-13-2010, 07:17 AM
HOT ROD ON
Sounds like we need to rewire. It would be a huge advantage to us to be able to get that to flow with the Key on. Perhaps Magnasun can help us out with this. Hopefully they see this thread.
Old 12-13-2010, 07:36 AM
DRAG CITY's Avatar
Should be no problem installing a auxiliary switch to run pump with ignition off on race day or change power pick up location that provides power in the ignition mode.
HOT ROD ON
Old 12-13-2010, 07:38 AM
HOT ROD ON
That's what I was thinking. Just wire it to an ignition hot wire. Probably should be installed that way all the time. AS long as you can still use "accessory", it would be fine. Only have it turn on with Ignition on. I did not install mine myself so I will have to dig around for the wires. I hope they are easy to get to.
Old 12-13-2010, 07:49 AM
DRAG CITY's Avatar
Should be a yellow power wire going to the fuse box on the passenger side in the engine bay.... with a simple fuse tap connector.
HOT ROD ON
Old 12-13-2010, 07:55 AM
Jessika@SuperchargerConnection's Avatar
DC is so smart
Old 12-13-2010, 08:03 AM
HOT ROD ON
Wow, that makes it simple! I am sure there is an ignition hot in that box somewhere. I will look into is today or tomorrow. Funny thing is I did car Stereos and alarms for years! Just had no part in this install. Thanks for pointing out the power feed though. This is a simple fix!
Old 12-13-2010, 08:13 AM
Good thought desant, I'm going to check mine out. I was hoping to be able to get a ice box somewhere easy inside the engine bay but there is not really a big enough spot.
Old 12-13-2010, 08:35 AM
While at the track, we can take some coolant out with a turkey baster or something, and then put ice in there. We can then get some major cooling in between runs. Even just running it with the engine off would help too I would think. I am sure we can come up with something for an icebox eventually if we need to.
Maggie Question Brucer41 Forced Induction 9 11-02-2012 06:43 PM
Magnuson / Maggie Warranty Question diverjose Forced Induction 1 10-25-2012 07:17 PM
Maggie + AeroForce Gauges Boost Question diverjose Forced Induction 1 10-19-2012 09:59 PM
Srt sub install question b1ackjack Audio, Video and other Car Electronics 7 10-12-2012 09:49 PM
new Maggie owner Toddsmith Forced Induction 23 09-30-2012 09:04 AM
