» Sponsors
» Sponsors
  #71 (permalink)
Old 10-28-2009, 04:34 PM
PWR_Andy's Avatar
Supporting Vendor
HAHA. Thats too funny.
  #72 (permalink)
Old 10-28-2009, 05:00 PM
rubbel's Avatar
Reading this discussion I went to the Calico website.
How long will the coatings last?
Calico's CT-2 ceramic thermal barrier and CT-5 oil shedding, corrosion resistant coatings are virtually permanent.
Calico's CT-1 and CT-3 dry film lubricants are "sacrificial" in nature and eventually wear out. But rather than wearing out the engine part, wearing the coating will save you time and money on expensive engine parts. It is also possible to re-coat and further extend the life of the coated parts at a fraction of the replacement cost (i.e. pistons, etc.
For my build the desire was to try to reduce temperature and have less chance of early detonation as well as reduce measures needed to reduce the chances of early detonation using pump gas. Same reason I went two steps colder on the plugs.
For pistons I chose 2618 alloy for the ductility verses brittleness of 4032 as quoted below:
There are two common alloys used in forged pistons, 4032 and 2618. Silicon-aluminum alloys, such as 4032, have great wear characteristics because the silicon particulate hardens the alloy and reduces the thermal coefficient of expansion. However, silicon-aluminum alloys can turn brittle and become prone to fracturing when subjected to extreme stress. With a piston made of a silicon alloy once a crack starts, it doesn't stop until the piston suffers a catastrophic failure. Low- or no-silicon alloys, such as 2618, may wear a bit faster but provide better strength and durability. In the rare case of a crack in a 2618 piston, the crack will migrate to an area of lower stress and stop. 2618-alloy pistons keep their shape under extreme pressures and high RPM's.
The 2618 alloy grows more with heat and does require added clearance. On my build each cylinder is .0041 larger than the matching piston. I do not expect any softness due to the ceramic coating application. Time will tell.
  #73 (permalink)
Old 10-28-2009, 05:08 PM
PWR_Andy's Avatar
Supporting Vendor
My engine has .0045 worth of clearance due to the extra heat of a turbo application. We have the same pistons although I did not get the tops of mine coated in time so only my skirts are coated. Our cranks are the same, but your rods are substantially stronger than mine. Bill Cardwell assembled mine, is that who assembled yours? It will be in the top right corner of the build sheet.
  #74 (permalink)
Old 10-28-2009, 05:17 PM
rubbel's Avatar
Same man!! I never could post my build sheet as I have no camera but sure is amazing the tolerances they hold. Top aerospace quality. Gives real meaning to "blueprinted" LOL!!
  #75 (permalink)
Old 10-28-2009, 05:39 PM
PWR_Andy's Avatar
Supporting Vendor
Yep. I will post my build sheet up tomorrow.
  #76 (permalink)
Old 10-29-2009, 10:39 AM
PWR_Andy's Avatar
Supporting Vendor
Springs and retainers came in today. Time to assembly the heads.
  #77 (permalink)
Old 10-29-2009, 10:53 AM
70TA-09RT's Avatar
Photos: (26)
This better than porn .... looking good I'm camping out on this one
Build #3 by RDP Motorsport
Very First 09 5.7 VCT STS Twin Turbos' 08/07/09
http://www.cardomain.com/ride/3836977
  #78 (permalink)
Old 10-29-2009, 11:02 AM
Abnmarine's Avatar
Looking good Andy!!!
Kenne Bell style!
  #79 (permalink)
Old 10-29-2009, 11:23 AM
Originally Posted by buckwheat View Post
Looks great Andy U !!!!
Buckwheat
Carlos?
The internet is full of all kinds of information.
Some of it may be good, some of it is truly bad.
But remember one thing, most of this information is free,
and usually, you will get what you pay for.
  #80 (permalink)
Old 10-29-2009, 02:19 PM
Redfox0099's Avatar
Photos: (10)
Looks good Andy
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
lukester
vB code is On
