resetting tps - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 19 (permalink) Old 01-23-2011, 10:01 PM Thread Starter
resetting tps
im not sure what you call this. but i read somewhere in a thread i think called tips and tricks about reseting tps. you have just the ignition on only and wait for most of the lights to go out then push throttle slowly to wot then let all the way off. i did this and swear the car runs and shifts better. anyone else tried this?
2010 RT silver jba mids with magflows 59956 cats flowmaster catback predator 180tstat cai mopar shifter and a lead foot..
high line is offline
post #2 of 19 (permalink) Old 01-23-2011, 10:06 PM
Is this what your talking about?
ETC Throttle Calibration/Characterization:
Late LX/LC Model (5.7LTR HEMI) Charger/Challenger Throttlecalibrationprocedure. It basically does a zero/span characterization
for PCM on fly-by-wire throttle system. This procedure if followed correctly will hold until battery power is cycled again.
PCM Zero/SpanThrottleCalibration
Throttlecalibration can substantially improve throttle responsiveness over "factory standard." Many people notice what appears
to be sluggish throttle response or a "dead area" at initial accelerator depression.
Throttlecalibration can take care of these.
Procedure steps:
1) Insert ignition key and turn to "ON" (not start).
2) Wait for all idiot lights to go out. Check Engine Light may remain on.
3) Slowly depress the accelerator pedal all the way to the floor.
(HOLD to the floor for about a three second count.)
(On some PCM versions, Engine Check light may start flashing here)
4) Slowly release the accelerator pedal until it's all the way back up.
5) Turn the ignition key to "OFF".
6) Start the engine.
Most drivers notice an immediate change in throttle response, but depending on your driving style, you may need to repeat this
procedure periodically due to the computer's adaptive programming.
NOTE:
You will likely need to repeat this procedure any time the battery is disconnected.
itzrick is offline
post #3 of 19 (permalink) Old 01-23-2011, 10:16 PM Thread Starter
thats the one rick, found it here http://www.challengertalk.com/forums...-tricks-20759/ everyone should try this
post #4 of 19 (permalink) Old 01-23-2011, 10:19 PM
There's a web site that has alot of good things about challengers. anyone that hasn't read it should. it's
100 Challenger Tips and Tricks
itzrick is offline
post #5 of 19 (permalink) Old 01-23-2011, 11:53 PM
raVenX's Avatar
Feedback Score: 2 reviews
Yeah, the guy who created that started with the post I put on ChallengerTalk and has been plagiarizing everyone's info since then.
raVenX is offline
post #6 of 19 (permalink) Old 01-24-2011, 07:17 AM
Well thanks for giving it to him. It's great info and It's alot easier to go to the site and click on tip # and it go there than looking thru 100 sheets of paper.
itzrick is offline
post #7 of 19 (permalink) Old 01-24-2011, 09:19 AM
I doubt that does anything.The chrysler scan tool has an ETC (electronic throttle control)relearn procedure.The scan tool puts the pcm in throttle relearn mode and syncs the throttle sensor(on gas pedal) with the ETC.I doubt it is in learn mode at every key on!
RICHSRT8 is offline
post #8 of 19 (permalink) Old 01-24-2011, 10:29 AM
pwr2tow's Avatar
Don't feel bad man, we are being plagurized every time some one relays information.
09 R/T
pwr2tow is offline
post #9 of 19 (permalink) Old 01-24-2011, 10:32 AM
pwr2tow's Avatar
The scan tool, predator, and TPS key trick can all recalibrate the TPS/APPS.
pwr2tow is offline
post #10 of 19 (permalink) Old 01-24-2011, 11:05 AM
I put a new pcm in a car today and the throttle would not work.Had to do the learn procedure with the scan tool, to get it to work.Stepping on the pedal slowly once or 10 times didn't work!Why would they have learn procedure at every key on,someone could accidently press halfway on the pedal.I can see the lawsuits coming!
RICHSRT8 is offline
