Performance ModificationsWant to talk about performance modifications for your Dodge Challenger? This is the forum for that. Anything from exhaust systems to power adders and everything in between. (Dodge Challenger Performance Modifications)
Safety s always a primary concern when racing any vehicle. With the 6-speed, you need to monitor your RPMs to make sure one shifts at the appropriate shift point when "getting it on". I don't like to take my eyes off the road when doing so and wonder if anyone is using a shift light to help determine when to shift. I would like to hear from anyone that uses a shift light, does it help, what system you use and whether it is easy to install.
It definately helps. I've used the MSD light with the rpm pill before. Installed it in the ac vent so it was out of sight. Not sure where you would wire it in on our cars.
__________________ 2009 SRT8: TorRed, 6 Speed & Loaded Under The Hood: Forged shortblock (9:1 comp),Street Heat heads,
Kenne Bell style!
Generally I would love to have a shift light which is connected to the oil temperature of the engine and comes on very early as long as the engine is cold.
I really take care to drive it warm - but it would help even more. Especially early in the morning when I'm driving but aren't really awake.
09 Challenger SRT8 6speed
KW Stage 2, Hotchkis Sways, Front & rear Strut Bars, Catch Can, MBRP, Vortech V3, Hurst Shifter, Magnaflow Catted Mids, 8-Piston Brembos, OZ Wheels (front 10x20, rear 11x20) w 285/35 Toyo R888 all around, Pedders Bushings, Custom Oil Cooler, and much more...
Thanks for the information and useful part numbers as this is a good start for me to look into obtaining additional information. I think it is a nice idea to place the shift light in the aircondition tunnel.
Later
Shift Lights by Raptor Performance Gonna a shoot these dudes an email. My buddy ran one on his Mach. I see one listed for an srt 4 neon.
09 R/T 27J Brilliant Black Crystal Track Pack
3 Car Seat Mod!
The way it should have been delivered package:sills,scoops & hood struts.
85mm throttle body
MAGNAFLOW 16516 cat back
K&N Drop in Filter
These work really good as a stand alone shift light. I have one installed on my 07 VMax. The light is self contained and you can select the RPM level to have it light up. The one on my bike isn't much bigger in diameter than a pencil and half as long. It would hide in an air vent really well and could be seen good because it is bright. It even has a colored plastic cover to shield the light.
Figureing out where to wire it into the ignition system would be the trick.
