I got to log a drag run today. There were some interesting finding. First off, I can verify that the ESP off mode, does not really disable anything, at least it doesn't feel like it. My car fell on its face during the launch. I can see that timing advance was down a few degrees across the board. It was interesting to see that full throttle shows up as 86%. I will see if I can do a throttle re-cal. I am going to disable all ESP based torque management switches. Namely ESP based spark, fuel cut and throttle control. I added a few PID's to monitor expected vs. actual on a few parameters. I also moved WOT throttle delay MPH to 127.5, and lowered the rpm max for throttle delay to 992, hopefully this helps with rollout on the launch.
What software you tuning with. Torque mgmt is not in no hand held tuner why I asked. EDIT> I just seen on another thread your using HP. Cool. I have been looking at what there doing myself. Interesting.
FT
Yes, I am using HP Tuners; and torque management is everywhere. The only big drawback so far, is that there is no support for knock retard in their scanner, yet. Infinite tables though...
