ST Knock Issues - Dodge Challenger Forum: Challenger & SRT8 Forums
Go Back   Dodge Challenger Forum: Challenger & SRT8 Forums > General, Performance, and Technical > Performance Modifications > Tuning/Data
Old 03-22-2012, 06:09 AM
shanesrt8's Avatar
Feedback Score: 2 reviews
ST Knock Issues
I was driving up the interstate the other day doing some data logging with my predator. I live in Western MD. Cruising in 6th at 70-75 mpg pulling the mountians, I'm getting anywhere between 0-4 deg of ST knock. The car doesn't struggle. What is causing this? Do I need to add some fuel to the bottom end? I'm running the stock tune with just the fan settings adjusted.
2010 SRT8 6spd Mods: AEM Brute Force Intake, SLP LoudMouth, Hurst Short Throw, 180* Tstat, 93 Oct Tune, Catch Can, Skip Shift Eliminator, 2011+ IAT Mod, 13% Tint, Mopar 10 Grill, H&R Springs
Old 03-22-2012, 06:17 AM
Nothing wrong....the knock sensors are doing their job. If anything you should try a different brand of gas and make sure it's 93 oct.
Old 03-22-2012, 06:19 AM
shanesrt8's Avatar
I always use BP 93 Oct. I'll give Sunoco a try. Thanks
Old 03-22-2012, 10:08 AM
Are you going up hill at all? You may be lugging the engine a little bit if you're in 6th gear. unless you WOT you can't add fuel, The predator only lets you change WOT fuel settings, not through the power band at part throttle. You may consider using the 91 tune with your 93 gas and adding spark untill you see knock retard and then taking the last bit of spark it away. This will let the computer handle the part throttle stuff but max out your WOT power.
[2010]Deep Water Blue Challenger R/T Six Speed.
Mods: 18" Rallye Rims, K&N air filter, Mopar Short Throw shifter,Custom Flowmaster Exhaust, Aeroforce gauge in Vent Gauge pod
Audio: Added 3-1/2" Boston Acoustic Dash speakers, converting from 4 speaker to 6, Parrot Asteroid (Android powered) Single Din Headunit. Swapped in Kenwood speakers in rear deck lid.
My new Car Website: http://ChallengerAccepted.com
Old 03-22-2012, 12:44 PM
shanesrt8's Avatar
Yes I'm pulling hills. Just crusing on a flat or a slight incline there is 0 ST knock. I think I'm just bogging the engine down a little too much. I'm sure if I pull that hill in 5th there will be no ST knock issues.
Old 03-22-2012, 02:00 PM
Yeah, either drop to 5th or really let off the gas, 4th is even a good to quickly burst up and then drop to 6th and coast the rest of the uphill and then give it a bit more gas on the downhill to prepare to carry the momentum into the next uphill.
Old 03-22-2012, 07:20 PM
Flat Top's Avatar
Moderator
Normal, when you see LT knk, then its something to look at. Many dont know they pull part throttle timing while lugging the sled around.
FT
09 5.7 to 392 Stroker, Vortech, Edge 4000 stall TC, Mr.Trinity. Quantum Blue BND oils.
Johan, Diablotoona@gmail.com email Tuned
SHR Viking Trans DSS 1000hp half shafts. Getrag 3:07 rear. SRT springs. Dual fuel pumps. 28x10 Hoosier wrinkle walls.
Posted in 11sec. et club 9-9-11 NEW PB 11:449 @ 118.8 1.58 60ft Tulsa Ok.
9-23-11 Backed it Up MOKAN Joplin Mo.
New PB 11:4446 DA 1650
392 Stroker New 1-29-13 ET unknown.
SPEED cost MONEY How FAST you wanta go ?
Challenger rt transmission and rear end issues derekeh Challenger Issues & Problems 5 03-22-2013 11:28 PM
Answer To Unlocking 392 PCM due In Q4 6SPD4ME 6.4L / 392ci (2011 - ?) 223 01-09-2013 08:37 PM
Any long term issues with 2011 air temp sensor? kwazydave Performance Modifications 10 11-29-2012 09:59 PM
Uconnect issues - voice recognition m_pritchett Challenger Issues & Problems 22 08-20-2012 03:59 AM
A coulpe issues 383rr Dodge Challenger R/T Specific 11 07-18-2012 10:22 AM
