2012 Challenger wont start - Page 2 - Dodge Challenger Forum: Challenger & SRT8 Forums
  #11 (permalink)
Old 07-31-2012, 04:22 PM
Hate to bump my own thread...but challengers back at the dealership. 3x within 2 week period. Is there anything that says the car can be returned within 90 days of purchase?
  #12 (permalink)
Old 07-31-2012, 04:41 PM
you are probably missing an ignition feed from the win module to the tipm I've had one that came to our dealership from the train yard and what was happening ins that the win module was not powering up an ignition feed to the tipm they should be able to monitor the ignition voltage and see proper voltage with a meter at the back side of the tipm
  #13 (permalink)
Old 07-31-2012, 05:23 PM
Todays problem is a bit different. My Car started up. As i was reversing it went apes**t. Said Power steering needed to be serviced, ABS was off, i was losing traction and then It kept jerking my steering wheel making it very difficult to turn. After about 2-3 minutes of this all the errors went away and the check engine light came on. No more ECO mode since that point; the car still starts up.
  #14 (permalink)
Old 07-31-2012, 05:54 PM
have you made the m10 recall complete there is a mini fuse it is 25 amp in the UPC in the engine bay what has to happen is the fuse needs to be relocated to a bigger fuse I belevie it's moving fuse 14 into fuse 6 location what happens is the power feed gets lost due to back cone tion and your ESP and abs will light up and then it will come back
  #15 (permalink)
not UPC the ipc fuse box
  #16 (permalink)
Old 08-01-2012, 05:55 AM
Doesn't this recall only affect the Charger/300c? I found the guide on how to do this.
  #17 (permalink)
Old 08-01-2012, 09:39 PM
Photos: (1)
Feedback Score: 2 reviews
Won't start - Brake Lights Drain Battery
Originally Posted by magnumforc View Post
Mine wouldn't start and after all the diagnostics at the dealer, they said nothing was wrong. I told them the brake lights stuck on and they said there was nothing wrong with the switch etc. Came out of a restaurant today and viola, the brake lights were on. Backing into the garage, took my foot off the brake and the brake lights stayed on. Lift the pedal with my toe and they go off. Just as I told them. Another danged trip to the dealer for something they should have fixed three weeks ago! This time I have a photo to prove it!
Took it in today, first tried to adjust switch and found that wouldn't work, plunger kept activating lights. Discovered could not be adjusted and the brake light switch faulty and replaced. No longer makes "clicking sound" when brake pedal is pressed. Hope this solves dead battery issue. Becoming much too friendly with this dealer, although they are the best around. Jack Powell Dodge in Escondido, CA
  #18 (permalink)
Old 08-02-2012, 08:07 AM
Haha...yeh man im feeling the same way with the dealer, I come in and they know me by name, im not liking it
  #19 (permalink)
Old 08-16-2012, 06:59 PM
3 Weeks after initial problem started, i finally received my car today. They tech said that there were some loose connectors between the ECU/and Wire harness. Don't know why it took them 3 weeks to figure this out and i hope this issue doesnt come back.
  #20 (permalink)
Old 12-14-2012, 03:44 PM
Shads Challenger's Avatar
I am going throug this right now. Had car at dealer almost 2 weeks with no start. They are replacing tipm on monday.
Sent from my SCH-I500 using AutoGuide.Com Free App
2013 Challenger Information Thread ResumeSpeed General Challenger Discussion 1279 05-24-2013 07:16 PM
I love my new 2012 Challenger!!! CURAMEN New Member Introductions 22 04-28-2013 12:50 PM
West Coast Challengers Car Club 2012 raVenX California 126 01-07-2013 06:58 PM
2012 charger sxt seat in 2012 sxt challenger gcook67 Interior Discussion / Modifications 0 07-11-2012 07:47 PM
