2012 Transmission issue to be aware of... - Page 2 - Dodge Challenger Forum: Challenger & SRT8 Forums
post #11 of 37 (permalink) Old 04-19-2013, 01:54 PM
SRT8Tech's Avatar
Originally Posted by brad View Post
They are gonna put a different grease on input shaft. The grease from factory gums up.
Sent from AutoGuide.com App
Ahhh, so the clutch friction disks are sticking......
2007 Procharged SRT8 Charger..........SOLD
2010 Mopar 10 Challenger.................SOLD
2010 R/T Classic Challenger...............SOLD
2011 392 Challenger.........................SOLD
2012 mid 10 second 1/4 mile GT500.... SOLD
Current ride
100% stock 2013 Plum SuperBee............best of 12.407 @ 114.28
With drag radials, tune and CAI...............best of 12.008 @ 115.74
SRT8Tech is offline
post #12 of 37 (permalink) Old 04-19-2013, 02:16 PM
Supporting Vendor
stevewhiteparts's Avatar
Feedback Score: 6 reviews
Case Number:
S1021000004
Release Date:
2010-11-04
Symptom/Vehicle Issue:
Transmission is hard to shift into and out of any gear when stopped.
Diagnosis:
When the vehicle is running, but at an idle, verify the vehicle condition by depressing the clutch pedal
and attempting to position the transmission gear selector into any gear. If there is difficulty when
attempting to shift into any gear, perform the outlined repair procedure. Excessive grease on the input
shaft splines collecting excessive amounts of dirt which does not allow smooth movement of the
clutch disc on the input shaft.
Parts Required:
1 P/N 05083150AA , (Grease) As required.
2 P/N 06508880AA , (Clutch Pressure Plate Bolts) 6 Required
Repair Procedure:
1 Remove the transmission as outlined in the service procedures.
2 Clean the transmission clutch hub splines and input shaft splines with mineral spirits.
3 Remove the pressure plate and clutch disc as outlined in the service procedures.
4 Clean the splines on the pressure plate with mineral spirits. Be sure to not allow clutch disc
to become saturated with cleaner.
5 Once the residual solvent has evaporated from the splines on the clutch hub, input shaft
and clutch disc, sparingly grease the entire length of the clutch hub and input shaft splines.
6 Install the pressure plate and clutch disc as outlined in the service procedures. Be sure to
use new pressure plate bolts during re-assembly.
Verification:
Bring vehicle to operating temperature. When at an idle, depress the clutch and attempt to move
gearshift into each gear. There should be no resistance and the gearshift should move freely into all
PLEASE VISIT
828-324-4410
800-779-3634
stevewhiteparts is offline
post #13 of 37 (permalink) Old 04-19-2013, 02:16 PM
Supporting Vendor
in our experience has not been effective
Luke
post #14 of 37 (permalink) Old 04-19-2013, 02:30 PM
Crush's Avatar
I had this TSB done about 5k miles ago and it fixed my problem so far.
The 2009s had the wrong grease. It was supposedly fixed in 2010.
2009 HO R/T M6: SOLD
2013 HO SRT8 Core M6 (aka "HELLKITTEN"
Mods: R2C Black Hex CAI, 180 stat, catch can, CDV delete, Magnaflow axle-back
Crush is offline
post #15 of 37 (permalink) Old 04-19-2013, 03:01 PM
SRT8Tech's Avatar
Crossfires had the same problem. I had to pull quite a few trans out of those damn Crossfires for this.......
SRT8Tech is offline
post #16 of 37 (permalink) Old 04-19-2013, 03:25 PM
teddyp's Avatar
Originally Posted by Yahooligan View Post
This is funny, because my dealer and Chrysler Corporate both said that star case only applied to certain years and my 2011 wasn't one of them. Tech also insisted that the problem in the star case wasn't the same as my problem (BS, because my problem was the car getting stuck in 1st gear and the clutch not disengaging fully).
Long story short, the dealer and Chrysler made me pay for a new clutch and labor since I have 23k miles and "clutches aren't covered."
Since you have a new car exhibiting this problem they're more willing to fix it, but as I found out the hard way they refuse to cover it under warranty down the road.
Great. Getting my six speed in a few weeks. I thought this Tremic 6060 was supposed to be an animal. I read in modern MOPAR that the clutch was good for 600 hp and gearbox up to 700. False sense of security I guess.
Black 2013 SRT8 6 speed, dual gray metallic stripes, radar red interior, tinted windows and side markers, Goodyear F1 front tires, (OEM), BF Goodrich g-force sport comp 2 275/40/ZR20 rears, Legmaker "True" fender pull CAI, 87mm ported throttle to match ported intake manifold by Peakspeed, Mishimoto 180* T-Stat, Diablosport H.F. custom 93 Tune, Magnaflow comp series cat back, Speedlogx front tower brace, MOPAR stage ones, Barton shifter, catch can.
teddyp is offline
post #17 of 37 (permalink) Old 04-19-2013, 11:00 PM Thread Starter
It has been solid for me, only this issue which was not much of a big deal, just did not feel right so took it in. Great call on the stick for this car, don't second guess that or have concerns over the 6 sd.
muzza61 is offline
post #18 of 37 (permalink) Old 04-20-2013, 07:51 AM
teddyp's Avatar
Thanks brother. Can't wait to get her.
teddyp is offline
post #19 of 37 (permalink) Old 04-20-2013, 04:05 PM
mattyj724's Avatar
Originally Posted by stevewhiteparts View Post
Case Number:
S1021000004
Release Date:
2010-11-04
Diagnosis:
Parts Required:
Repair Procedure:
Verification:
is this for grinding into reverse as well
2012 Classic 6Spd, Blue Streak Pearl, 430N, Sound Group II, STP
Best quotes
If the ethanol is the light end of the fuel, maybe we could have a metal pot sitting over an open fire, and pour gas in the pot and let the fire heat it up until the ethanol cooks off
mattyj724 is offline
post #20 of 37 (permalink) Old 04-20-2013, 04:23 PM
SRT8Tech's Avatar
The TR6060 is just fine and can handle whatever you want to throw at it. It just takes some getting used to.
SRT8Tech is offline
The Following User Says Thank You to SRT8Tech For This Useful Post:
teddyp (04-20-2013)
Overall Quality of the Challenger? SuBXeRo General Challenger Discussion 109 09-17-2013 12:45 AM
2012 Diablo tuning issue - please help jmcdougal01 Tuning/Data 17 11-16-2012 05:11 PM
Fall 2012 Issue - Input Welcome Modern Mopar Magazine General Challenger Discussion 1 10-16-2012 11:04 PM
Modern Mopar Magazine Summer 2012 Issue ... Cover! Modern Mopar Magazine General Challenger Discussion 3 09-19-2012 11:03 AM
