Another Challenger dead battery story. - Page 2 - Dodge Challenger Forum: Challenger & SRT8 Forums
post #11 of 52 (permalink) Old 11-21-2012, 02:55 PM
My 392 sits for 6 weeks at a time and starts right up. Im not sure if my buddy locks the doors or not though. I am currently over seas working and he takes it out every once in awhile to run it around..
RoostKing is offline
post #12 of 52 (permalink) Old 11-21-2012, 03:32 PM
Isaac-1's Avatar
There is something in the faq that says if you use the manual emergency key inside the fobic to lock the door it will not activate the anti theft system and reduce drain on the battery for long term storage.
Ike
2010 Plum Crazy SRT8 with Manual Transmission-------
Mods list: K&N Typhoon CAI, Skip Shift Eliminator , Petty Strut Tower Brace, Diablo Predator 91CAI tune, License Plate backup camera with Lockpick V2, mini spare tire and adapter, Moroso Catch Can, some BT bling, 3rd brake pulser, Larry's mod Hurst shifter, coming soon Web Electric Sequential tail lights and LED under door lights
Isaac-1 is offline
The Following 2 Users Say Thank You to Isaac-1 For This Useful Post:
RoostKing (11-21-2012), USRWDV8 (12-03-2012)
post #13 of 52 (permalink) Old 11-21-2012, 05:42 PM
Originally Posted by Wildturkey1 View Post
Hi everyone. After searching these threads I've decided to come to you for some help
My 2010 RTC sat idle for one week and the battery was dead. I didn't leave the key on and the interior lights were off. After jumping the battery for about 10 mns. It finally started. My volt meter reads 14.2-14.4 volts with the engine running.
I drive it to the dealer and they say that its cranking 730 amps, the battery is good and can find no problems.
I must have a parasitic drain somewhere.
Has anyone else experienced this after just a week of not driving their car?
Any thoughts?
Hey Wildturkey, be sure to get a charger on the battery as the car will never truly charge the battery back to full unless you drive 3 or more hours straight a couple of times in a row.
GlennW is offline
The Following User Says Thank You to GlennW For This Useful Post:
Wildturkey1 (11-22-2012)
post #14 of 52 (permalink) Old 11-21-2012, 07:08 PM
Originally Posted by CHALLENGEmeSE View Post
Are you saying that every time you let your car sit for a week, you remove the 60A fuse?
If so, that's another trick to put in the book.
No, I don't need to do that...mine works without any issues.
I suggested this to see if disconnecting the IOD fuse would eliminate the battery drain and see if that stops his battery from draining.
If it did, then it would be a matter of tracing down what may be causing excess drain.
If it doesn't then it points to a fault of the battery itself - possibly a weak cell or internal short within a cell.
Hal H is offline
post #15 of 52 (permalink) Old 11-21-2012, 07:17 PM
MoparOhio's Avatar
In talking with a shop that I trust and the AAA guy that jumped my sons car when the battery was dead both told me that a typical battery really only has three years of life. Hot and cold temps wear on a battery greatly. Once a battery is dead it harms the battery quite a bit and you must charge it for 3 hours in order to restore it. SImply driving the car to recharge a dead battery won't do the trick. I typically replace car batteries at 4 year sold as a precaution.
Either the battery in your car really does have an underlying issue or there is something electrical draining your battery. It should hold a charge for much longer than a week. I have gone a month without driving my car and it fires up fine.
TorRed SE Model purchased: 2/05/09 (gone but not forgotten)
TorRed R/T Classic ordered: 4/06/13
R/T Classic born on: 6/04/13
R/T Classic delivered on: 6/21/13
Mods installed:
Mopar CAI
RiderGraphix spoiler graphic
Skip-to-shift eliminator
Cursive Challenger on grille
Engine Cover air brush painted
Billet under the hood stuff
MOPAR door sills
Member of Frederick Scat Pack
MoparOhio is offline
post #16 of 52 (permalink) Old 11-21-2012, 07:34 PM
Feedback Score: 3 reviews
This information is from a 09 SRT but I doubt the other models are different.
Parasitic draw after everything powers down is about 30 mA (0.030 Amp).
With the alarm activated, the parasitic draw is about 35 mA so the alarm is not a concern.
At 30 mA after 60 days, a good battery will be weak but should start the car. After 90 days, the battery will likely be "dead".
Question for the OP - do you have ANY aftermarket equipment installed?
Trinity or other tuner?
Anything plugged into the OBDII port? Gauges, etc
Cell phone charger, etc?
A Trinity without the sleep timer set to 30 sec will keep the CAN bus awake and kill your battery in a day or so. With the sleep timer properly set, my Trinity still draws almost 100 mA when dormant so I don't leave it plugged in for more than a few days.
A cell phone charger I checked drew 200 mA even when the cell phone was charged.
Some things to check.
2009 Challenger SRT8 - gone
2010 Jeep GC SRT8
11 GMC Sierra Ext Cab, LB
69 Pontiac Grand Prix 428
waumo is offline
post #17 of 52 (permalink) Old 11-21-2012, 08:33 PM
Redliner's Avatar
wow! I have gone for over 3 months of not even starting the engine on the original 09 battery and "RMMMMMMM"...........it starts right up, no hesitation. Parasitic is right. My Eclipse on the other hand has a parasitic loss similar to what you are experiencing. My charging system on the Eclipse is all perfect. When running, it puts out 14.6 volts, but if I let the damn thing sit for 6 days...........dead. I've pulled each and every fuse and tested voltage across the contacts with the engine off of course and on an instrument that can detect .001 volts accurately, I can't find the dang problem! It will drive you nuts! I hope that this is NOT your problem!
2009 Dodge Challenger R/T Deep Water Blue 20" rims Cool as Hell
1995 Mitsubishi Eclipse GSX 2.0 Turbo Automatic........with 99 front end and rear facia.
1995 Toyota T-100 SR5 Best Truck I've ever owned
2005 Kia Sorento Great car but everybody keeps doorbanging the poor thing.
1975 Mustang II V-8 Highly Modified to 400+ HP, nothing stock except the radiator cap
Redliner is offline
post #18 of 52 (permalink) Old 11-22-2012, 06:09 AM
'11 Challenger R/T
Had same issue when i but a new stereo system in it. I upgraded to a new battery with a larger cca and have not had any problems since. You need to watch out that only a certain size battery will fit in the rear trunk of the car. Went with an Odyssey deep cell battery, #PC1350, cca-770, mca-960, phca-1350. Fit right in. For traveling should disconnect positive cable from terminal, that should help
thegnat is offline
post #19 of 52 (permalink) Old 11-22-2012, 09:17 AM
You need a clamp on meter that will read low current DC. I clamped it around the battery ground cable and measured the currents. You can actually watch as the car's bus shuts things down and eventually gets to the sleep current of about 30 mA with no aftermarket equipment attached. It can take a few minutes to get there.
I also checked some other (GM) vehicles from 1998 to 2011 and the parasitic draw of all of them was in the 20-40 mA range.
This is the meter I have. http://www.extech.com/instruments/pr...d=26&prodid=77
I got it for about $100.
waumo is offline
The Following 2 Users Say Thank You to waumo For This Useful Post:
driller (01-01-2013), Wildturkey1 (11-24-2012)
post #20 of 52 (permalink) Old 11-22-2012, 09:47 AM
JeffsGonePlumCrazy's Avatar
Send a message via AIM to JeffsGonePlumCrazy
Originally Posted by OrangeR/T View Post
The dead battery situation happend to me once not long after i bought my 2010 Challenger. Mine had sat for a couple of weeks (it's not a daily driver) in the garage, i go out one day and she was dead. I was told that it was becuase i left my doors locked which activated the security system, which in turn drained the battery dead. Where your doors locked Wildturkey1?? Might be something to that myth, i have left my doors unlocked ever since while sitting idle in the garage and i have not had another dead battery, been 1-1/2 years now since it happend. Hope that helps!!
Hell my car has sat in the garage for over a month with the doors locked and its not ran the battery dead, I just believe chryslers electronics are starting to get like fords was in the 90s. I stated in a previous thread about my step mothers 2011 300c is plagued by electrical problems including running the battery dead. I also had my passenger side window roll down a bunch of times by itself when I hit a bump in the road last year when I went to Gatlinburg, I could also bump the door panel with my fist to get it to do it as well. This is why I like old cars better, you don't have to have a $20,000 computer to tell you that the reason your radio don't work is because you are low on washer fluid.
2010 Dodge Challenger R/T Classic, 6 Speed, Plum Crazy Pearl, White R/T Stripes, SRT Airbox, Mopar Hi-Flow Drop-In Filter, MBRP Cool-Duals Exhaust, Jet 180' T-Stat, BT Catch Can, Custom Dyno tune from Henson Performance w/Predator, and a 392 IAT sensor
When the Tires break loose..... STAY IN IT!!!!!!!!!!
Untuned Dyno Numbers 340.3rwhp 372.8rwtq
Tuned Dyno Numbers 359.8rwhp 397.8rwtq
JeffsGonePlumCrazy is offline
The Following User Says Thank You to JeffsGonePlumCrazy For This Useful Post:
2013 Dodge Challenger ResumeSpeed General Challenger Discussion 8 09-02-2012 10:26 AM
Story About Getting My Challenger AmericanMuscle14 General Challenger Discussion 32 08-22-2012 12:33 AM
Muscle car is reborn: Dodge 'Challenger' is back Mr.DJ Dodge Challenger News 1 06-30-2006 08:27 PM
