So my 2010 challenger B5 Blue has had this annoying clunky noise from the front end when driving on a bumpy road or an unpaved driveway.
I did all the normal stuff like removing the washers off the sway bar end links and making sure the cross member in the engine compartment was tight and its still there.
I went and jacked it up and tested the front end components and found play in my lower ball joints. You can feel it with a bar under the tire and lifting up somewhat rapidly- you get a thud and can actually feel the up and down play in both ball joints.
Im taking it to the dealer tomorrow. Still under warranty with only 11,700 miles on it.
Whats the chance they will give me a hard time about this?????
figured they could also deal with the cracked door panel trim and hopefully reconfig my backup camera and daylight running lights.....
