Front driver's side suspension noise - Dodge Challenger Forum: Challenger & SRT8 Forums
Old 07-29-2012, 06:48 AM
peanuts-nuts's Avatar
Not sure what this is but it seems to have started today.. I don't know how to properly describe noises but whenever I go over a speed bump and relatively slow speed, I hear a noise on the front driver's side suspension.
It's not a grinding noise, maybe sounds like something's loose? Don't know really. Before I take it to them and they waste my time again, I'm wondering if anyone has a similar issue.
FYI - it's about 2 weeks old and has 1600 km on it only.
Reply With Quote Quick reply to this message
Old 07-29-2012, 04:44 PM
hizootiemizark's Avatar
It could very well be just that something loose since its so new. Sometimes stuff just doesn't get torqued properly at the factory. I would have it looked at so there isn't any further damage done. Good Luck
Old 07-29-2012, 07:23 PM
Let's hope you're right! I'll take it to them this weekend and see what the deal is. I hate the inconvenience of being car-less, so let's hope it's a weekend job.
Old 09-27-2012, 11:03 PM
BlackRT2011's Avatar
I'm having a creaky front driver's issue too with 13k miles. Did yours get resolved?
2011 Pitch Black R/T Plus
528 rwhp / 503 tq
11.7 @ 119
2010 PCM Swap, 8lb Magnacharger, Arrington 85mm Thottle Body, Arrington CAI, Arrington heads, American Racing long tubes, 6.4 Cam, Tuned by AJ
Speedlogix Strut Tower Brace - Zoomers Cat-Back - SRT8 Struts, Shocks & Springs - Lexani Staggered 20" - Nitto INVO 245/295
Old 01-13-2013, 12:18 PM
Front end Clunking noise
Did you guys get any answers on the front end issues? Seems like this is something common in the Challenger and I have a case of it too.....mine is a 2009 with 8k miles ????? Sounds like the damn thing is coming apart when I run on a ruff surface!
Old 01-13-2013, 12:45 PM
B&R Challenger's Avatar
Photos: (7)
I had a noise coming from the front drivers side as well on my 2013 SRT. I realized that it wasn’t the suspension and that it was the aftermarket CAI tube/snout sliding in and out of the CAI box as the car flexed. I called Arrington about the issue and they instructed me to wipe white lithium grease around the intake tube where it slid in and out of the box. I have not had any other noise from the front end since.
Good Luck
Old 01-13-2013, 05:21 PM
Glenn's HC's Avatar
Has anyone resolved their issues since this post?? I ask cause i'm starting to have this problem as well, more like a knock sound when going over bumps or speed bumps when the front end dips down. Coming from drivers front
Mopar CAI, Arrington ported 85mm TB, Catch can because IT DOES WORK!
Old 01-13-2013, 06:06 PM
Noise
Mine sounds like a broken shock ????? As common as it sounds with Challenger's, 300's and Charger's you would think someone would have put together a good thread with photo's and some answers (maybe the answer is out there somewhere). It must be something with these Dodge front ends and the majority must be the same issue or I guess these front ends are made of crap!
Old 01-13-2013, 06:33 PM
cannonballcobb's Avatar
Those "clunks" can sometimes be a loose end link nut. If they're not really tight, they'll make a clunk every time the suspension loads/unloads.
Old 01-13-2013, 07:15 PM
Glenn's HC's Avatar
ThANKS Cannonball
If you do not want to register, fill this field only and the name will be used as user name for your post.
How to lower your r/t or se mopar stage one stevewhiteparts Steve White Motors 146 05-28-2014 02:13 PM
Side Marker Lights Question 2BLU4U Exterior Discussion / Modifications 5 09-25-2012 08:00 PM
Drivers side fiberglass sub enclosure Zman6 Parts For Sale/Wanted/Trade 6 09-10-2012 06:58 AM
How do you remove the front passenger side fender? Challenger516 General Challenger Discussion 1 09-03-2012 08:59 AM
Clunky front end noise aarcuda Challenger Issues & Problems 8 06-24-2012 08:48 AM
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
