Question is there a fuse for heated seats? I'm asking because In my driver side heated seats only comes on every blue moon and it's been freezing here in Chicago and I can't even enjoy my heated seat but the passenger seat works fine. What number fuse to reset or is there any type of diagram out there for heated seats for our challengers??? Thanks
You might check the connector under the drivers seat and make sure it plugged in tight. hey had an issue with the plug coming apart and the heater not working.
The fuse is for the circuit, not individual seats.
As mentioned above, check the connection under the seat.
Also check the switch in the dash.
It's easy enough to swap switches with the passenger side to try to isolate the problem.
could easily be the switch on the dash, I messed one up when I removed the stereo surround to install the backup camera and lockpic harness. They replaced it and works fine ever since.
