Is IPOD Supposed to Work with 430 Radio? - Page 6 - Dodge Challenger Forum: Challenger & SRT8 Forums
post #51 of 207 (permalink) Old 07-27-2011, 06:54 AM
Hello JoeCanadian, Yes I would say it would be okay to try the update on your Avenger. If you did want to look at the module to verify the SW level, the module is located behind the HVAC control head. Remove the center stack trim panel and "using a magnetic" screwdriver remove the screws holding in the HVAC control head and you will see the module. Even if you just tried the update you wouldn't brick the radio or do any daamage at all, if the SW is the 43.1.30 level all that will happen is about 5 minutes or so into the re flash you will hear an error message saying "archive is not compatible with this module". However I have an update that I am testing for the 43.1.30 SW also. I should be done testing it in the next day or two and if all goes well I will have mrjeep post it for people to access.
Originally Posted by JoeCanadian View Post
xsdbs - thanks for your help in providing all this good information.
I know this is a challenger forum, but I recently purchased a 2011 Avenger (built March 16 2011). The TSB 08-036-11 issued on June 29, 2011 seems to indicate that my RBZ radio in my 2011 Avenger should be covered in this update. Problem is, I can't find the HFM to verify the either the part number (as described in the TSB) or the software version as described earlier in this thread.
So, is it safe to just try the update without verifying the HFM part or software numbers? I don't care if I waste 30 minutes trying it. The radio as it is now is SO incredibly frustrating to use with my iPhone 3GS (running iOS 4.3.5) that I'm willing to give it a try. I just don't want to damage or brick my radio.
xsdbs is offline
post #52 of 207 (permalink) Old 07-27-2011, 07:23 AM
Thanks! That is what I wanted to know. I was ok opening up the glove box because it was pretty easy. Opening up the HVAC control head sounds a bit more involved!
I'll give the update a try using the small car file since the Avenger and 200 almost the same car. I'll be sure to let you know if it works or if I will be helping you test the 43.1.30 update! :-)
Thanks again to you and mrjeep for all your help!
JoeCanadian is offline
post #53 of 207 (permalink) Old 07-27-2011, 08:17 AM
Good news and bad news
The good news is it worked. The bad news is I won't be able to help you test the 43.1.30 update.
The bluetooth streaming now works well without the skipping and with the iphone screen on. I can now play tracks on the iphone, and choose to route the audio though the phone or through uconnect. I can change songs on the iphone and it continues to route it though uconnect. Very slick integration.
The other problem I was experiencing was when I plugged the iphone into the USB port under the HVAC controls (vs the one on the 430 (RBZ) radio itself). 99 times out of a 100 after displaying the message "Reading" for about a minute, it would say "Error Encountered" and the 'ipod' would not be usable via the radio.
Now, it still takes longer than I would expect to get past the "Reading" message, but it appears to now always connect to the radio. This allows me to look through my play lists, play tracks, see the ID3 tags of songs playing etc.
I'll keep playing with this part of it over the next few days to see how reliable it is. But already it seems "more complete" then it did before.
In case you need to know, I'm using an iPhone 3GS running the just updated iOS version 4.3.5 (8L1). The Avenger is a 2011 with a MDH of 031613 and the 430 unit is a RBZ radio running the following software versions (application 20.02.01, audio CPU 081910).
Thanks again for your help.
post #54 of 207 (permalink) Old 07-27-2011, 11:04 AM
Well that's all good news. I'm glad it worked out for you. The reading of the information is time relative to the iPhone and not the Uconnect. Apple send Uconnect the information to use and the timing can be different depending on the how much material that you have in the iPod section. I have also seen where if it seemed longer at times than others, if you do a soft reset of the iPod / iPhone by pressing the sleep button on top and the wake button on the lower face (round impression) at the same time till the Apple shows up this sometimes helps. Thanks again for help.
xsdbs is offline
post #55 of 207 (permalink) Old 07-27-2011, 11:51 AM
Heminator's Avatar
I had the dealer to the update for me (before I read this thread). Everything works well now in my 430N, except for the following:
If I link Bluetooth UConnect for my iPhone and ALSO connect my iPhone to the USB jack to play songs over the iPod, it will not allow both to occur at the same time.
I believe this is a limitation of the iPhone (or I have a setting wrong) because I can connect my iPod Nano to the USB port and have my iPhone linked Bluetooth to Uconnect, and the 430N plays nice with both of them.
Can anyone verify that the iPhone 3GS cannot be connected to Bluetooth (Uconnect phone) and USB (iPod streaming) at the same time?
Thx
2011 SRT8 392 IE #88 DWB: M6, 430N, Group II, Mopar Appearance Package
  • Arrington 'AJ' PCM tune
  • Airaid CAI
  • Speedlogix '392' catch can
  • Modern Muscle 85 mm TB
  • Jet 180 stat
  • Barton shifter
  • Corsa Xtreme
  • Hop Not I & II
  • REM front strut brace
  • REM rear strut brace
  • REM rear tension arms
  • Petty's safety loop
  • MirrorTap - Escort Passport Max
  • Speedlogix parking brake pedal cover
  • Mopar gas cap cover
  • BFG g-Force Sport Comp-2 (275/40 & 245/45)
Heminator is offline
post #56 of 207 (permalink) Old 07-28-2011, 08:25 AM
Hello Heminator,
This does not sound correct. I will look into it and get back to you. May I ask what SW is on the iPhone?
Also please let me fully understand what you are doing. My understanding is that you have:
1) paired the iPhone 3 to the Uconnect system and would like the BT connection to be used for calls,
2) After had paired the phone you now want to plug the iPhone into the USB / iPod cable for your music. The reason probably for this method is to keep your battery charged and also better sound quality. (is this correct)
3) You now can only do 1 or the other, use the phone for calls or the iPod section for audio?
Can you explain to me what does happen when you try to use both?
Thank you
Thx
xsdbs is offline
post #57 of 207 (permalink) Old 07-28-2011, 08:31 AM
Okay, I have had good luck with the 43.1.30 SW update and will have mrjeep post it on the hosting site later today. The instructions will be the same as they were for the previous update for TSB# 08-036-11. You are actually receiving this update before the dealerships are because if they got the update first, they would have to wait to find the time to validate it and then put it on the Dealer Connect system. So if you have the 43.1.30 SW level don't even bother asking the dealers about it.
xsdbs is offline
post #58 of 207 (permalink) Old 07-28-2011, 11:47 AM
The Uconnect Update How-to has been updated. This will now work with 43.1.10 as well as 43.1.30
mrJeepR44 is offline
post #59 of 207 (permalink) Old 07-29-2011, 06:51 AM
Heminator's Avatar
Hello Heminator,
Thank you
Thanks for the reply.
You are correct - I wanted the BT UConnect phone, the USB dock for charging, and the USB dock for highest quality digital streaming (and it is by far the best audio quality of any available option).
When I enter the car, the iPhone 3GS automatically pairs via BT with Uconnect. And hands free calling works just fine.
When I connect the iPhone 3GS to the USB dock, it reads the iPod menu and all of the songs and tracks/titles load properly. But when I hit play, it starts to play a song and then freezes after 2 seconds.
Disabling BT on the iPhone 3GS (which disables UConnect of course) then allows the iPhone iPod to play just fine over the USB dock.
So I can't have iPhone paired to UConnect via BT and have the iPhone iPod USB dock connected at the same time. It seems the iPhone isn't capable of doing both and the BT connection seems to have precedence/priority.
I don't think this is a 430N issue, because if I connect my iPod Nano to the USB dock, it works fine while my iPhone 3GS is paired via BT to UConnect. The 430N will mute and pause the iPod Nanao audio track when making calls, and then it will resume playing after the call is completed, so it's behaving exactly as I would have expected.
The firmware on my iPhone 3GS is up to date: 4.3.4 (8K2)
post #60 of 207 (permalink) Old 07-30-2011, 07:43 AM
This is weird, I thought I posted back on this issue yesterday. MAybe I didn't hit the submit button. It was 1 of those days at ork.
Have you tried a soft reset of the phone? (hold down the power button and the wake button below on the face of the phone till the apple comes up and then release).
Also, how old is the iphone3? If it's not a new one then, when you plug the iPod cable into it and the "accessory connected" screen comes up, right below it, is there a message showing "dock connector", if so tap on it and a menu box should come up giving 2 selections:
1) dock connector
2) Uconnect
select Uconnect. If this is what you see and you made the "Uconnect" selection does it work the way you want it too.
Thanks
xsdbs is offline
Installing an Aftermarket Head Unit ceri Audio, Video and other Car Electronics 28 12-27-2015 09:46 AM
Need Help to Transfer Music from IPOD to Radio 2BLU4U Challenger Issues & Problems 12 04-25-2013 11:55 PM
Radio volume doesn't work 910RideSmooth Challenger Issues & Problems 7 11-08-2012 07:40 PM
I want more VOLUME from my ipod touch in my base model radio. Possible? super8man Audio, Video and other Car Electronics 12 10-22-2012 10:52 AM
History of Car Radios GreatAmerican The Garage: For OTHER car talk 5 10-03-2012 01:54 PM
