Originally Posted by raVenX
The problem is that the encryption software (Keeloq) doesn't do well with cheap electronic parts. I spoke to one of the architects behind KeeLoq a few years back when we first encountered this problem, and he told me that Chrysler decided to use cheap, foreign, electronics parts, so that's the cause.
The fix is to re-flash the WIN module. The new programming is believed to knock the encryption to a much lower level and thus leaving the car less secure. Presumably, the car communicates with the key fob better with lighter encryption.
Still, if the WIN module (behind the dash next to the steering column) heats up, i.e., the car sits in the hot sun for a long period of time, then you're going to experience the problem again, regardless of whether or not the car has been re-flashed.
My 2010 SRT8 just started doing this today. Went to the dealer and thought I'd solved the problem by purchasing a new battery for the key fob but filling up my Chally 15 minutes later it quit on me again (oh bother). Going home and restarting the car using the remote push button it started up fine for me so after all this reading I've concluded this is another intermittent problem.
1) Have any of y'all tried using a better (more expensive) remote as a possible solution? If so then what fob make did you chose to use & why? I ask because the above referenced response says the Dodge key fob as "cheap" and may not be up to the task at hand.
2) Is this issue related in any way to tuning issues or emission testing issues?
3) What common tactics are the dealers using in order to solve the problem? I do have a good dealer at my disposal but I still would like to "nudge them" in the right direction if possible.
Any & all advice is greatly appreciated. Thanks in advance!
