Someone in Massachusetts willing to help (engine noise)? - Page 2 - Dodge Challenger Forum: Challenger & SRT8 Forums
post #11 of 36 (permalink) Old 11-29-2012, 01:16 AM
My car did that for a while but now it is fine. My guess was it sounded like intermittent re-ignition of exhaust gases. Muffled explosions caused the jerking.
Busamaster is offline
post #12 of 36 (permalink) Old 12-02-2012, 07:41 AM
We now have contact to a Dodge technician with the help of military car sales.
we'll make some tests the 11th December to find out more about this noise.
I will tell you the results.
Bernd is offline
post #13 of 36 (permalink) Old 12-02-2012, 05:14 PM
In for a resolution.
I posted in the rough idle/motor shaking thread but feel this is a better place for my info since me and the OP seem to have the same issue. Mine has the same noise/feel at idle. Its a metallic clunk/crunch from the engine bay that you can feel through out the car. I've also noticed that when it happens there is a drop in rpms from ~650 down to ~570. It almost feels as though its an incomplete combustion, or miss-timed ignition on one cylinder. Problem occurs whether the engine is a cold or hot, although problem becomes more pronounced and frequent when the engine is heat soaked, i.e. after driving for an hour or more. No CEL and no codes pending. Problem also comes back after pulling the #2 fuse. Interested to see what you find out Bernd.
2012 R/T 6-speed Blue Streak Pearl - Gone
2011 SRT8 6-speed Redline 3 Coat Pearl - Gone
2012 SRT8 6-speed Redline 3 Coat Pearl - Gone
2015 SRT A8 Granite Crystal/Silver Stripe
R6snods is offline
post #14 of 36 (permalink) Old 12-03-2012, 07:21 PM
Lets hear it. Plum Crazy...The only one in town, your town. PM me. Sounds interesting. We have a 392 in the family also.
hdsoff is offline
post #15 of 36 (permalink) Old 12-06-2012, 09:46 AM
odiHnaD's Avatar
Originally Posted by Heminator View Post
Can't help you, sorry. The M6 Tremec 6060 sounds like a can of marbles at idle and that's apparently normal from what I can research.
Mine does this too.
, Hüper Optik 30,
, 730N RHR
Mod queue: front and rear strut bars, 2012 SRT steering wheel
2013 Focus ST in Performance Blue w/ST3 package
Steeda short throw shift kit, Cobb AP w/fswerks tune, Beltronics STiR plus, BlackVue DR400G-HD, Gentex auto-dimming mirror
odiHnaD is offline
post #16 of 36 (permalink) Old 12-07-2012, 01:12 PM
Litdog's Avatar
Mine as well. Glad I'm not alone. Very interested in the results.
2015, SRT Redline Tri-Coat, Sunroof, Charcoal Rally Stripes, Technology Group, Sepia, Nav
Litdog is offline
post #17 of 36 (permalink) Old 12-07-2012, 02:57 PM
Mine's been doing it since day 1 as well. Hasn't gotten any worse, hasn't gotten any better. So whatever it is... Must not be too bad. Just an annoying sound and feel.
2011 Dodge Challenger SRT8 Inaugural Edition 0032/1100
Blastin' Bobs, Mopar short throw, custom SLP Loudmouth II
#32 of 1100 is offline
post #18 of 36 (permalink) Old 12-08-2012, 04:27 PM
Litdog's Avatar
I came across this info from www.techauthority.com
2011LCOM1PDF
2011 Dodge Challenger Owner's Manual 1st Edition PDF ( English )
Manual Transmission
As follows,
Due to the high performance nature of your drivetrain, you may hear your transmission. This can be most noticeable when the vehicle is idling in NEUTRAL with the clutch engaged ( clutch pedal released ), but it may also be heard when driving at low engine RPM. Also, this may may be more noticeable when the transmission is warm. This is a normal condition and is not an indication of a problem with your clutch or transmission.
This pretty much sums up what I'm hearing.
Litdog is offline
post #19 of 36 (permalink) Old 12-09-2012, 11:46 PM
2011LCOM1PDF
Manual Transmission
As follows,
The noise we are talking about is definitily not coming from the transmission. It is coming from the engine area. But tomorrow we'll have an appointment with our customer ( by the way Automatic transmission) to make some tests. The results we`ll forward to Dodge.
The noise you are hearing, you can make a simple short test. Press the clutch pedal totally. If the noise is still hearable it is not coming from the transmission.
Bernd is offline
The Following User Says Thank You to Bernd For This Useful Post:
#32 of 1100 (12-10-2012)
post #20 of 36 (permalink) Old 04-05-2013, 06:19 AM
Hey together, we found the solution of this noise. It was coming from the front crankshaft pulley. The rubber damper in the pulley was lose and this made the noise in idle. New pulley is installed and no more noise.
Bernd is offline
Geno22 (02-23-2016)
Hurst shifter throw out bearing noise? NX91Notch General Challenger Discussion 22 11-06-2014 10:16 AM
Penzoil Ultra 0W40 and Engine Noise SRT Wasp 6.4L / 392ci (2011 - ?) 21 12-27-2012 02:37 PM
Torq specs for motor mounts? GR8 PMKN Performance Modifications 3 09-14-2012 12:36 PM
Engine revolutions and AC hum noise JonnyRT Challenger Issues & Problems 2 08-30-2012 12:47 AM
Code P000B kbr577 Tuning/Data 3 07-27-2012 01:56 PM
