Sunroof Stopped Working - Page 2 - Dodge Challenger Forum: Challenger & SRT8 Forums
post #11 of 26 (permalink) Old 07-11-2013, 01:04 PM
Rainmaker1984's Avatar
This happened to me when I first got the car and again today. Tried the holding the "close" button and it seemed to free itself up. Also cleaned the gasket and body. Fuse would probably have resolved as well. This forum is great for learning and correcting issues. Thanks to all!
Mopar Splash Guards; Lloyd Custom Floor Mats; Turn-Signal Delete; Mopar Wheel Locks; Tinted Windows; PVC Piping Trim; Skip-Shift Eliminator; Billet Cup Holder; Mopar CAI; Chrome Hemi Half-Covers; Hurst Pistol-Grip Shifter; Diablosport Tuned; GTS Rear Windshield Deflector; Mopar Billet Tech Nose Badge
[/B]
Rainmaker1984 is offline
post #12 of 26 (permalink) Old 07-11-2013, 02:36 PM
This may sound mean But that one of the reasons I did not get a sunroof just wait till the car gets old more problem with it and the other reason you lose head room and if you are tall that is not good. Good luck with the people that has sunroofs HEMIB5BLUE
hemib5blue is online now
post #13 of 26 (permalink) Old 07-13-2013, 07:48 PM
SRT Wasp's Avatar
Ok now this just happened to me and I knew I had read something about sunroof problems.
It stuck wide open and would not shut. I found that by constantly pressing the middle button it would inch forward until it was finally closed. Then... like the wise guy I am, I press it again and it sticks in the open vent position - argh - and will not close -argh!
I relaxed, had a cold one, and checked CT where I found this thread. The recalibration using the middle button for 30 seconds seemed to do the trick. Now it works as expected.
I love this forum. Thanks all.
Sent from AutoGuide.com App
SRT Wasp is offline
post #14 of 26 (permalink) Old 07-27-2013, 12:04 AM
RonsSRT's Avatar
Happened to me this morning . I opened the sunroof and then decided to close it and put the AC on. The sunroof got stuck in the open position and wouldn't close unless I kept hitting the venting button in the middle. But then it got stuck in the venting position and wouldnt close. Less then 430 miles on my car and it's only been home for 1 week and problems already. I went inside to cool off a bit, came back out, hit the switch again and it closed. Wentout later on and opened the sunroof again only for it to get stuck open once again. First thing in the morning I too will be trying that recalibration trick.
2013 Plum Crazy SRT8, 1 of only 340 and #1 of 33 with my options built for 2013:
Ordered: 5/8/13
Status:
D: 5/9/13
D1: 5/14/13 (VIN Assigned)
E: Frame 6/13/13
F: Paint 6/13/13
G: Trim 6/13/13
I: Built, pending final inspection 6/13/13
J: Built, OK'd: 6/17/13
KZ: Released by plant, invoiced 6/18/13
KZM: First rail departure 6/20/13
KZX: Delivered 6/27/13
Taken Home: 7/15/13
RonsSRT is offline
post #15 of 26 (permalink) Old 07-29-2013, 12:33 PM
walnetto's Avatar
The only time mine sticks is when I hit close and then turn off the key. It doesn't operate like the windows do. They work until you open the door, even when turning off the key as they are going up. I have to turn on the key and then the roof will start working again. I'm sure your problem is different.
2010 Torred SE, 25G, Heated leather, MyGig 430 w/ Sound Group, Sunroof
Mods -Magnaflow 16500 (dual quad tips) - Chrome Clad 20" wheels - Mopar Wheel Caps - Body Color Spoiler - Chrome Fuel Door - Locking Gas Cap - Hood Struts - Functional Hood Scoops - K&N DIF - Mopar Nose Badge - Fender Extensions - RPI Splash Guards - Mopar T-Handle - Stainless Pedal Kit - HomeLink - Hands Free uconnect mic - Lockpick - Boyo rear camera - Relay on plate light - DRL activated - WebElectric Sequential Signals.
walnetto is offline
post #16 of 26 (permalink) Old 07-29-2013, 12:54 PM
diver88's Avatar
I've opened and closed mine just a few times but it seems when I close the roof it sometimes pops up
to vent instead of closes. try to close the vent and it opens, I figured I was just not familiar with it
and wasn't hitting the correct button.. but it's not gotten stuck so far.
Plum Crazy 2013 R/T Classic Challenger
Auto, Super Track Pac, Anti Spin, Sunroof, Classic II Wheels
diver88 is offline
post #17 of 26 (permalink) Old 07-29-2013, 01:29 PM
You can pull the fuse in (rear power dist center/by battery) that is a blue color 20A fuse for the sunroof in cavity #44 - that will re-set the sunroof. When you re-power it, put it vent position by holding button, then cycle close, open and then it should be back to normal.
2016 392 Hemi Scat Pack Shaker 23Y pkg (6 speed MT) ordered 8/28/15, born 10/23/15, home 11/20/15
Hal H is offline
Onemanop (10-02-2013)
post #18 of 26 (permalink) Old 07-29-2013, 02:18 PM
motomoto's Avatar
happened to me in the first week while driving-got home turn off the car and restarted and it worked again.. werid
2012 SRT-8
white stripe delete
hurst shifter upgrade
cervani functional ram air
3 inch cat back flowmasters
87mm arrington throttle body
22 inch custom 5 spoke rims on toyos
3.92 rear end
hi-flow mid cats-
150 shot N.O.S
motomoto is offline
post #19 of 26 (permalink) Old 08-05-2013, 12:25 PM
SRT Wasp's Avatar
Well it happened again - got stuck in the vent open position and did not want to respond after that. Holding the center button for 30 seconds seems to have cleared it and I was able to close it. Time to let the dealer know I guess.
SRT Wasp is offline
post #20 of 26 (permalink) Old 08-19-2013, 06:57 PM
Powerstick's Avatar
This happened to our 2012 just a few days ago. My wife was driving it & opened it, then it would not close at all - wide open. I told her to shut off the car, restart, & try again - to no avail - no action at all. Then later she was driving down the road, tried to close it, still no response. Driving down the road a little more, she tried it again & it closed. THERE MUST BE A TSB ON THIS!!!
I also agree with a previous poster - I really DON'T want the dealer pulling trim & the headliner to start tearing into this problem unless it's a LAST resort. Trim goes on at the factory & it never comes apart again & back together without issues! Rattles, fits, etc. all start rearing-up after taking things apart!
  • 2016 Scat Pack Shaker PCP
  • AAR Cuda from NM.
Powerstick is offline
Cruise Control Stopped Working? Blackbird Challenger Issues & Problems 36 05-02-2016 10:19 PM
HELP! Front Speakers Stopped Working Hollywoodagogo@gmail.com Audio, Video and other Car Electronics 4 10-20-2013 07:09 PM
2010 Furious Fushcia SRT Owners Build Thread 6SPD4ME General Challenger Discussion 67 06-27-2013 12:55 AM
uconnect stopped working with my iphone ? mtsmello Dodge Challenger R/T Specific 1 09-20-2012 06:09 AM
Speedo Quit Working DFW GTS Challenger Issues & Problems 0 09-16-2012 01:35 PM
