I don't see a wheel/suspension section, so I hope this is the right section.
I understand offset, but don't know what Backside and Bolt Circle means.
The 5 bolt circle means that the wheel has 5 lugnuts.The 4 3/4 is the diameter of the circle that passes through the center of all 5 holes. The rear spacing,or back spacing, is how far the wheel sticks in (i.e., the distance from the back edge of the wheel to where the wheel contacts the hub). If you lay the wheel down on the floor with the back side up,it would be the distance from the back lip of the wheel to the surface that has the holes. This matters because there is stuff that the wheel or tire can hit if it sticks into the wheel well too far.
Front side is the distance from the front edge of the wheel back to where it contacts the hub. These two dimensions added together will be approximately 1" wider than the designated wheel width.
My wheels will be Intro Vista 2. They are similiar in design to the SRT/8 wheel with a more nostalgic feel. Would be nice to see a set on a Challenger. Someone steal my idea and post some pics.
Intro Vista 2:
Dude...let me tell you, You have excellent taste. They remind me a little of a modern version of the classic 60's Radir wheels. Do they make them in the 115mm bolt pattern??
...I called Cragar the other day to see if they had wheels to fit the Challenger(I figured they did since they do for the Charger etc etc)...I have the first set on a Challenger ANYWHERE according to Cragar...they were very happy I chose Cragar S/S for my car, me too
