For the Best Fitting, Highest Quality, Custom Stripes for your Challenger!!! We Make & Install what we sell so we know it fits right!!! Adding New Designs Soon!!...Check our Site by clicking Logo above!!
Can you post installation instructions? I would like to know details on alignment and technique to avoid bubbles. Thanks.
We send detailed installation instructions with every order.
They are installed wet, and we include a squeegee with the kit as well.
They are an exact duplicate of the factory decals, and install in the same position.
We will send dimensions for alignment as well.
Basically what you do is trim the excess surrounding material from the decals, position them according to the dimensions, and use masking tape to mark the position of the decals. This is done prior to removing the backing paper. Once everything is marked, you can remove the decals from the car, remove the backing paper, wet the car and decal, and this allows you to position the decal on the car in the pre marked position. You then squeege out the application fluid from the center out towards the edges. Once the decal is installed, you can spray addditional fluid on the pre mask to soften it, and then slowly peel the mask paper off the decal being careful to not lift the decal off the car.
These Hood Decals are installed in two or four pieces depending upon the design you choose.
Most of our customers do their own installation. Those who do not, either have a window tint shop or body shop do the install for them.
Hope this helps.
No Problem. Let me know if you need anything else.
__________________ My Challenger Home Page http://www.cardomain.com/ride/3089456
"People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf."
Auto Guy, if you know ? Can the factory hood to fender stripes on a 2009 R/T Challenger be removed without hurting the paint ? The salesman said no problem as long as I use a heat gun on medium to soften up the decal and pull slowly at an angle. What do you think? Thanks, Locomotion
