Google Links
» Sponsors
» Sponsors
Go Back   Dodge Challenger Forum: Challenger & SRT8 Forums > Dodge Challenger News & Polls > Dodge Challenger News
Dodge Challenger News This section contains news and important information about the new Dodge Challenger. Important site news will also be posted in this section. Only Administrators can start topics in this section. (Dodge Challenger News)
  #11 (permalink)
Old 07-23-2008, 09:37 AM
Points: 1,018, Level: 12
Points: 1,018, Level: 12 Points: 1,018, Level: 12 Points: 1,018, Level: 12
Activity: 0%
Re: Supercharged Challenger SRT8 hits the dyno!
Originally Posted by G. Craig View Post
The compression ratio on the SRT 6.1 HEMI is 10.3:1 which is fine for naturally aspirated engines. In a nut shell high compression ratio when mixed with high boost levels can results in detonation and ultimately broken pistons. I predict there is going to be a lot of cracked and broken pistons and/or blown head gaskets as enthusiasts try to push the boost levels higher and higher. If a supercharger or turbo set-up is part of the game plan than owners should rebuild the engines with lower compression, forged aluminum pistons @ 9.1:1 or less, designed for use in boosted applications along with replacing the powered metal rods with good quality forged steel rods.
The SRT 6.1 HEMI appears to be well thought out and engineered for high performance duty.
o The basic, deep-skirted engine block structure was redesigned with reinforced bulkheads to handle higher loads.
o Cylinders are honed with torque plates to ensure a truer bore, to reduce friction and increase power.
o Oil squirters, aimed at the underside of each piston, are added to aid piston cooling for engine durability. (I am especially impressed with this feature, it could allow for a higher AFR during boost without fear of burning pistons.)
o The SRT 6.1-liter HEMI’s crankshaft is forged from micro-alloy steel and rotates in tri-metal main bearings for high-load capability. The crankshaft damper is retuned for higher engine speeds.
o A billet steel, high-strength camshaft features more overlap and lift for better performance.
o The hollow exhaust valve stems are filled with sodium to dissipate heat efficiently.
The Mopar enthusiasts have plenty to be excited about, SRT is engineering some good stuff and Dodge is building it.
Your a moron these are mopars not ford piston throwers or gasket blowers buddy. Put a charger on there and add a water meth injection and better gas and it will run all day no problems considering you dont go above 9psi and its properly tuned with a good af ratio. This aint no 306 ferd . Its a srt hemi and she is gonna run fine without building the engine with low compression. Since your so smart why dont you ask mr john force "mr ford" what compression he runs his blown 426 hemi powered ford at?
  #12 (permalink)
Old 11-11-2008, 10:02 AM
Points: 6, Level: 1
Points: 6, Level: 1 Points: 6, Level: 1 Points: 6, Level: 1
Activity: 0%
Very interesting thread
I will be buying one of these beasts very soon and all this info on these forums good and bad is great.
Looking forward to being here more.
I'll post more once I buy it !!
  #13 (permalink)
Old 11-12-2008, 08:45 AM
Points: 1,091, Level: 12
Points: 1,091, Level: 12 Points: 1,091, Level: 12 Points: 1,091, Level: 12
Activity: 20%
Activity: 20% Activity: 20% Activity: 20%
I know from the SEMA show the Vortech Charged HURST Challenger is 585+ hp on the motor and still retains a warranty!. Its in the tune and what's "relative" the motor can sustain
  #14 (permalink)
Old 11-12-2008, 09:59 AM
Kobaal's Avatar
Points: 615, Level: 9
Points: 615, Level: 9 Points: 615, Level: 9 Points: 615, Level: 9
Activity: 53%
Activity: 53% Activity: 53% Activity: 53%
Photos: (1)
So much for that warranty huh? Thats awesome.
Sound Group II / uConnect GPS / Trak Pack / 20" Rims / Heavy Duty Brake Kit /
Mopar CAI / SRT Hood Scoops / Gas Strut Hood Shocks / Billet Tech Catch Can /
Skip Shift Eliminator / HID Lights / 3.92 Rear Axle
  #15 (permalink)
Old 11-21-2008, 04:56 PM
Points: 181, Level: 3
Points: 181, Level: 3 Points: 181, Level: 3 Points: 181, Level: 3
Activity: 18%
Activity: 18% Activity: 18% Activity: 18%
Can anyone tell me what the SRT8's HP and Tq numbers at the wheels?
  #16 (permalink)
Old 11-21-2008, 05:53 PM
Points: 1,443, Level: 15
Points: 1,443, Level: 15 Points: 1,443, Level: 15 Points: 1,443, Level: 15
Activity: 10%
Activity: 10% Activity: 10% Activity: 10%
I think a supercharged r/t would beat up a cobra but an SRT 8 thats just an all out A$$ kicking!
vB code is On
HTML code is On
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
