This Audio build is on a 2013 Challenger RT 392 Stoker. As you can see this Challenger has been built from the ground up with all major upgrades. The audio system is getting complete audio overhaul in stages. We are going to start in the trunk area since they needed a system in the trunk area that is fairly easy to remove on track days. But still have good balance between performance output and sound quality. Provide a custom look that seamlessly blends in with the styling cues of the car. Since I'm using higher quality equipment that's efficient, 1100 watts rms for the entire system is plenty of power for great sound.
Current Equipment that will be removed
- Rockford Fosgate Prime 1,200-Watt Class-D 1-Channel Amplifier runs 2 12" rockford subs
- Rockford Fosgate R250X4 Prime 4-Channel Amplifier Run interior Rockford speakers
Upgraded equipment
- Custom 12" stealth removable Enclosure with color LED/Acrylic trim accents
- 12" Arc Audio Arc series 12D4 V3 Subwoofer
- Custom Stealth removable Amp Rack with color LED and Acrylic trim accents
- Arc Audio XDi v2 1100.5 5 channel amplifier 150w x 4 500w x 1
The 392 Stroker pictures
Track day shoes
Upgraded equipment
Track day shoes
