Want to swap in factory NAV. - Dodge Challenger Forum: Challenger & SRT8 Forums
Go Back   Dodge Challenger Forum: Challenger & SRT8 Forums > General, Performance, and Technical > Audio, Video and other Car Electronics
Audio, Video and other Car Electronics Anything that pertains to the interior electronics modifications such as stereos, A/V, lighting...not exclusive to the Challenger please feel free to share
Old 11-21-2012, 02:46 AM
electricmarquis's Avatar
Send a message via AIM to electricmarquis Send a message via Skype™ to electricmarquis
I have a 2010 srt8 with the factory 430 (REN) radio. Can I switch to the 430N (RHB) with out any issues? Do I have to run a NAV antenna or does it share the connection with the sirius radio? I want navigation and I heard the Garmin based one was better than the one on the 730 radios.
2010 Challenger SRT8
2012 Toyota Camry SE
2011 Subaru Outback
Bring back Pontiac and the T/A!!!!
Old 11-21-2012, 07:48 AM
Do what you want but for the cost of the 430N you would be better served by a stand alone Garmin GPS (take your pick). Otherwise it is a direct plug-n-play except for the nav antenna requirement. I've read on the forums that it works when left under the dash. I've also seen the PN listed but I do not have it. It is reported that 2011+ use the sat radio antenna for nav. If you go with a 730N it is more work because of the built-in Uconnect.
SteveB
2011 Bright White SS/T-Rallye
Old 11-21-2012, 08:18 AM
I have 430 REN and bluetooth and uconnect. I just wanted the built in GPS. I will look for a used one floating around for a good price. I just wanted to be able to swap in and out in a few mins using factory plugs.
So there is no factory radio option that lets me just swap and gain GPS?
Old 11-21-2012, 08:30 AM
Go Goody's Avatar
Take a look at the escort unit with radar detection built into GPS...two birds..one stone
08 SRT8 #6077, InTune, AFE CAI, 180 TT, Catch Can, Cabin Air Filter, Speedlogix Strut Brace, Best time of 12.85@109.66
Old 11-21-2012, 04:37 PM
Yes, the RBH 430N is a direct replacement for your REN. You would need to search the forum for the best way to handle the GPS antenna. The information is out there. I have seen Low Speed Bus RBH radios as low as $750 and high as $1800. Your REN might be worth $200-$300 to someone wishing to upgrade an RES. Your bluetooth & Uconnect will operate the same as before the swap. I went from an RES to an RBZ and did not need to do anything special for my Uconnect to continue working.
Old 11-22-2012, 06:13 AM
So I would need to get the 430N (RHB) and a GPS antenna? I was told the gps antenna is installed under the dash and its no big deal to put it in. Is this correct? I have also been told if you have sirius radio you dont need to install the GPS antenna because it uses the same one for nav.
Old 11-22-2012, 06:50 AM
R/T_6Speed's Avatar
Photos: (6)
I can vouch for what BW said, the aftermarket antenna's working fine under the dash. Unless you are just wanting to keep a factory style radio look I would at least consider some of the aftermarket alternatives. I bought the cheap factory radio, pulled it and put in a Kenwood Excelon DvD/NAV/BUC/BT/iPod/USB etc. Love the handsfree blue tooth and the NAV on the Kenwood's is Garmin.
'10 R/T 6 Speed // Magnuson Supercharged @ 8lbs // Hurst //
Areoforce duals // 0ther warranty voiding parts //
Old 11-22-2012, 06:58 AM
bwbike's Avatar
Photos: (15)
Feedback Score: 3 reviews
. . . I was told the gps antenna is installed under the dash and its no big deal to put it in. Is this correct? . . .
The factory GPS antenna is indeed under the dash; you need to remove the upper dash to access. Directions are on here somewhere.
R/T 27F, 6-Speed Tremec
Mods: Skip Shift Eliminator, Hood Struts, Functional Hood Scoops, RPI Designs Mud Flaps, Cabin Air Filter
Old 11-22-2012, 08:03 AM
LETSJET's Avatar
Photos: (2)
I would sure to see a detailed post on swapping out a base radio to a high end unit with all the components required.
2010 HEMI ORANGE R/T auto
Mopar hood struts
Billet Technology MOPAR nose badge
Mopar Dodge wheel caps
DRL's enabled
Mopar Chrome shifter T-handle
Corsa Xtreme Exhaust
MOPAR cold air intake
Richard Petty Tower Strut Brace
Mopar Bight Pedal kit
2010 FURIOUS FUCHSIA R/T Classic 6 speed
Mopar hood struts
Billet Technology HEMI nose badge
DRL's enabled
Skip Shift eliminator
Blastin Bob's Resonator Eliminators,(awesome!)
K & N drop in air filter
2011 Dodge Ram 1500 Quad SLT
Old 11-22-2012, 05:00 PM
R/T_6Speed's Avatar
Photos: (6)
This is about the best thread I've ever seen on replacing the head unit in a Challenger...
How-to: GPS Radio Install
2013 Challenger Factory Headlights to HID projector headlights Factory 2013DodgeChallengerRT(DC) New Member Introductions 113 06-11-2013 09:03 AM
Upgrade from factory radio to nav radio element012 Audio, Video and other Car Electronics 11 09-22-2012 07:47 PM
2010 to 2012 Mygig Radio Swap - Is this possible? bradisonn Dodge Challenger R/T Specific 7 08-24-2012 11:16 AM
2012 Challenger with Factory T/A Hood zerofeel Dodge Challenger R/T Specific 9 08-02-2012 10:22 PM
