Audio, Video and other Car ElectronicsAnything that pertains to the interior electronics modifications such as stereos, A/V, lighting...not exclusive to the Challenger please feel free to share
I would ditch the plastic 6x9 holder and go with traditional speaker rings. Better baffle and better seal.
whats wrong with what i bought? Am i missing something here?
I have some second skin left over which i was going to use on the ring, both sides, i also have foam thats used for speaker mounting that creates a seal that i can be used in lieu or in conjunction. I just dont want everything to be so thick that the woofer hits the grill on the door.
"The Black Beauty"
2012 Challenger R/T Black with Super Trak Pak with 5-Speed
Zed Audio Leviathan III Amplifier (on its way)
Sundown Audio Components
Pioneer DEH-80PRS Deck
remember what my mdf ring looked like in the rear deck? I am getting the dremel hopefully mid-week i could attempt an mdf baffle with that, the circle attachment comes with it. None the less, i got a few things that i can try. I want to see how rigid the ring is once mounted to the driver
Its weird, the mounting hardware that came witht he drives have these little V clips..not sure how they are supposed to be used.
I have a PC router with the perfect circle jig which does 2" diameter cut out to 30" cuts. i bought this 10 years ago when I built a lot of fiberglass subwoofer enclosuers were I routed many different size rings. also I have metal rings ranging in 8" to 15" which cover 85% of subwoofers on the market.
here are the rings i use for test fit for subs and making circles
so that bench is made up of a 4x8 sheet zipped down the middle to give you a 2 2x8 sheets of 3/4 ply made with 2x4 studs.....i had 2 of those in my basement, i did doubleupped 2x4's was built like tank! I put beaverboard on top, did for a great smoothe surface.
I got my dremel today and i botched my first ring....go figure Not bad but i just carved away a lot more material then i really had to, i thought it needed it so it wasn't my skill of the tool, just retarded gauging. Ugg. The mounts are pretty flimsy, i am kind of disappointed. I think i might just use the rings as a guide to produce new rings. I dont think a perfect circle would cover the hole in the door right?
