» Sponsors
» Sponsors
Go Back   Dodge Challenger Forum: Challenger & SRT8 Forums > Dodge Challenger News & Polls > SRT Engineering Chat Session
SRT Engineering Chat Session This section contains the SRT Engineering Team Chat Sessions. Only the Administration team can start new threads in this section. Topics will be closed when chat sessions are not scheduled.
Closed Thread
  #101 (permalink)
Old 11-04-2009, 05:28 PM
Since it sounds like there was a stage 2 in some form, why not get a little money back for the R&D time by selling it? Or would it need a lot more testing to be "market ready"? A couple threads on Dodge Caliber & Caliber SRT4 Forums clearly show interest for it.
  #102 (permalink)
Old 11-04-2009, 05:29 PM
Originally Posted by SRTengineers View Post
Nope, the CAN system needs to be reconfigured to recognize the module.
By reconfigured, do you mean set up with StarScan or is it just not possible to do?
08 SRT Grand Cherokee Red Rock Crystal: SRT option 1&2, Sunroof, VES - Installed mods: Mopar Hitch n harness, bWoody 4" CAI, K&N Drycharger, Diablo Predator & CMR tune by JB, Kooks headers & hi-flow cats, Mopar/Corsa cat back, LipschitzWrath rear fog light harness, BT Catch can, Murf's O2 fix, AEM UEGO, Power Bond underdrive pulley, Jet 180 t-stat, Addco Sway Bars & Delosh hood graphic.
M.I.S. Aug. 28, 2009
Booked for M.I.S. again Aug. 28, 2010
  #103 (permalink)
Old 11-04-2009, 05:30 PM
Originally Posted by eddiefig View Post
Rear shaft was out and they replaced it. Problem didn't change the slightest. Other shaft was fine. Could it be the rear? How do I get them to replace stuff for the process of elimination? They seem to be blowing me off. Is it true that some Jeeps were dropped off by you guys at a place called OLSEN AUTO in Rahway, NJ? Said they were all SRTs. Guy told me that a few Jeeps were dropped off his way all with Michigan plates to solve vibration issues stating he was "the man to go to".
Not sure who Olsen Auto is, so can't really tell you if he is the go to guy.... The dealership should be able to follow the service procedure for indexing the driveshaft which would help them system balance the driveline and possibly resolve your issue.
  #104 (permalink)
Originally Posted by Alikazam View Post
Well how would that work when a stock shaft (the actual inner joint) snaps with a hard launch on sllicks? (4500-5000 rpm clutch release) If i upgraded both sides, wouldn't that maintain reduced hop? I'm running a full slick as well to eliminate poor traction. Did you have the shaft diameter? I know there are a few after market companies out there that make "1000 hp axles" but I was looking for info to see if something more "in between" could be made for this application. Thanks again!
The Right hand bar is 30 mm and the left hand bar is 40 mm diameter..
  #105 (permalink)
Old 11-04-2009, 05:31 PM
Originally Posted by CHLNGME1 View Post
Thanks for answering my question about the winter tires on the GC ,but you answered in TECH TALK.Im just a dumb, go fast guy. so now im more confused than before.
Go with the same size tire all the way around.....
  #106 (permalink)
is there any plans for a convertible
  #107 (permalink)
Old 11-04-2009, 05:32 PM
Not to say I drive too slow, but at times the 1-4 shift crap is for the birds. Is there a way to turn it off without buying an aftermarket item or flashing the computer?
2nd, Is there anyway to view the CEL codes from the drive information center in the dash without a scan tool?
09 Silver SRT8 6Spd
  #108 (permalink)
Old 11-04-2009, 05:33 PM
"NOPE, my fur will get messed up"
  #109 (permalink)
bluesrt's Avatar
hi srt- on my 08 viper when slow into a right turn say pulling in a driveway,my power steering makes a small grunt- hot or cold, thought it would break-in but after 3k miles still does it- i know its not hurting anything,just thought you may know something to cure it. right turn only at slow speeds
2010 srt8 b5 blue auto hard loaded-
  #110 (permalink)
Old 11-04-2009, 05:35 PM
"Nope, and Nope"
Closed Thread
vB code is On
