disabling (ESC) completely in Challenger R/T classic 2013 - Dodge Challenger Forum: Challenger & SRT8 Forums
New Member Introductions If you are new to the site please create a thread in here to say hi. We encourage all of the members who are 'lurking' and reading about the Dodge Challenger to post in this section at least once!
post #1 of 14 (permalink) Old 08-29-2013, 02:57 AM Thread Starter
Hwy Khalil's Avatar
Hi Guys,
I would like to inquire about the Challenger R/T classic 2013, and some of its tricks, things that I tried recently is disabling Electronic Stability Control (ESC) completely which need to use some of the hidden dodge tricks, below you'll find some of it that I already tried:
- The engine is running, the car in Park gear (P), and then press and hold ESC button (located at bottom of temperature control ) for 10 seconds.
- The engine is running, the car in Park gear (P), and then press ESC button (located at bottom of temperature control control) only once and (ESC OFF) will illuminate , and then drive the car at 25 kilometers or bit more, and turn the smart key (like if I want to run the car) for 10 seconds.
Unfortunately, both methods illuminate only (ESC OFF) as in the picture
but not this one
Where both signs present in the dash of the car. Please advise me about how to close and disable this system completely without resorting to the fuse box or change any electrical part, note that the methods mentioned above were used in the previous models.
Thank you very much.
Hwy Khalil is offline
post #2 of 14 (permalink) Old 08-29-2013, 03:52 AM
Sportbikerxx's Avatar
Send a message via Yahoo to Sportbikerxx
Welcome from Md!
2011 Toxic Orange Challenger SRT8
Sportbikerxx is offline
The Following User Says Thank You to Sportbikerxx For This Useful Post:
Hwy Khalil (08-29-2013)
post #3 of 14 (permalink) Old 08-29-2013, 06:20 AM
Originally Posted by Hwy Khalil View Post
Hi Guys,
but not this one
As far as I know, if you didn't get the Super Trak Pak with your car, you can't turn it completely off. The first method you mentioned is how to turn it off with a STP equipped car (although it's only 5 seconds, not 10).
DevilDogge is offline
post #4 of 14 (permalink) Old 08-29-2013, 08:29 AM Thread Starter
Hwy Khalil's Avatar
well, I've heard about the Super Trak Pak before and actually I made a quick search, and I found about it in http://www.sequentialtaillights.com/:
Tip 28: With the "Super Track Pak" on the R/T J or R/T Classic, no "key trick" is needed to get full off ESP.
While in PARK, press and hold ESP off button until the system chimes.
My challenger is R/T classic 2013, so it would great if you can tell how can I make sure that I got this "Super Track Pak" in my car. many thanks DevilDogge.
post #5 of 14 (permalink) Old 08-29-2013, 08:33 AM
There's a few ways. It'll be on your window sticker. You can look under your car and see if you have the yellow Bilstein shocks, but if you tried holding the traction control button in while you were parked for 10 seconds, and a chime and notification in the gauge cluster didn't pop up after 5 seconds, then you probably don't have it.
I'm not sure if there's another option out there for non-STP cars to fully disable it.
post #6 of 14 (permalink) Old 09-03-2013, 05:44 PM
GreatAmerican's Avatar
Feedback Score: 9 reviews
Welcome aboard!
Max Power: 652 rwhp Max Torque: 635 ft-lbs Boost: 15 psi
Performance Mods:
Techco 3.0L SC, Techco Strut Tower Brace, DiabloSport Custom CMR Tune, HHP/BES Stage 2 Heads, HHP/BES Camshaft, Kooks Long Tube Headers, Corsa Cat-Back Exhaust, Hawk Performance Brake Pads, Hurst Shifter
GreatAmerican is online now
post #7 of 14 (permalink) Old 09-03-2013, 06:17 PM
1970FJ6T/A's Avatar
Welcome to CT from Michigan
1970FJ6T/A is offline
The Following User Says Thank You to 1970FJ6T/A For This Useful Post:
Hwy Khalil (09-08-2013)
post #8 of 14 (permalink) Old 09-03-2013, 06:24 PM
RWL11's Avatar
Doubled Up.
This thread is posted twice!?
RWL11
PDX, OR
2016 R/T Scat Pack, A8
Belle II
Drake All-Satin Fuel Door with Billet Tech Fuel Door Insert, EZ Pull Trunk Straps, Razor's Edge Front Strut Bar, Mopar Bright Pedal kit, Splash Guards, Door Sills & Hellcat Airbox with aFe Power Dynamic Air Tube and D.I.P.S., Tint & Clear Bra by Tommy's. DD XML2 Fogs. Billet Tech Engine Bay Dress Up Kit. Hurst Quad Tips. Silver Leaf Stripes by Mitch Kim. DRL's:ON! (Usually)
"there are many like it - but this one is mine"
RWL11 is offline
post #9 of 14 (permalink) Old 09-03-2013, 07:24 PM
judgeschambers's Avatar
Another way to find out your options are:
1-The Dodge.com owners link. Once registered, enter your vin and it will show the details. I just did this over the weekend and it took 24 hrs before all my cars service and ordered options began to show. The site loads veerrrry slooow. Under the Learn & Use tab there's a tab for Equipment. There it shows mine has the STP option.
https://www.moparownerconnect.com/oc...nersLogin.aspx
2-Vin window sticker lookup. This is a 50/50 shot. Some Vin's show the window sticker and some don't. Mine, does not. Many I looked up did when shopper for my R/T.
Use your VIN number to get Chrysler Window Sticker
Hope this helps.
2012 Tungsten R/T Classic, 6-speed, package 27M w/STP.
1970 Pontiac Grand Prix, 455 HO, 11.90's @ 116 mph in qtr.
judgeschambers is offline
The Following User Says Thank You to judgeschambers For This Useful Post:
post #10 of 14 (permalink) Old 09-07-2013, 01:56 AM
elie's Avatar
Welcome to CT from Abu Dhabi
2012 Dodge Challenger SRT8
1st 2012 Challenger SRT8 in Abu Dhabi
Mopar T handle shifter - Parking Sensors
GardX Paint & Leather Protection - Vcool tinting
elie is offline
The Following User Says Thank You to elie For This Useful Post:
  Dodge Challenger Forum: Challenger & SRT8 Forums > New Member Introductions & Site Assistance > New Member Introductions
2012 Challenger information thread ResumeSpeed General Challenger Discussion 651 07-31-2015 01:20 PM
new 2013 Challenger Classic Wheels pipopo Dodge Challenger R/T Specific 130 07-08-2015 09:35 PM
2013 Challenger R/T and SLP Loudmouth I, anyone? MMDeveloper Performance Modifications 0 04-03-2013 04:59 PM
Review: 2012 392 vs 2013 R/T Classic StealthChallenger General Challenger Discussion 55 01-29-2013 02:24 PM
