ESP/BAS + MR.Squiggles light won't go off. - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 33 (permalink) Old 01-16-2009, 02:22 PM Thread Starter
Hey folks just got my car back and the paint is awesome. Anyway, when I started the car at the paint shop I noticed the ESP/BAS light was on.. which was wierd..
I drove it a few miles and then stopped and restarted and the lights went out, and then came back on again...
Has this happened to anyone else?
1970383 is offline
post #2 of 33 (permalink) Old 01-16-2009, 02:36 PM
Kobaal's Avatar
Re: ESP/BAS + MR.Squiggles light won't go off.
Only when I do the "key trick" to disable ESP and Traction Control... Sounds fishy...
Kobaal is offline
post #3 of 33 (permalink) Old 01-16-2009, 05:26 PM Thread Starter
It must have just been a glitch, hasn't come back on.. I have my fingers crossed.
1970383 is offline
post #4 of 33 (permalink) Old 01-17-2009, 11:16 AM
lupoman's Avatar
Probably just a hiccup from the paint shop disconnecting the battery terminal during paint.
2009 Challenger R/T 6speed. Too many Mods to list, check the links below.
lupoman is offline
post #5 of 33 (permalink) Old 01-17-2009, 12:10 PM
page 287 in the manual - to syncronize ESP/BAS
Synchronizing ESP
The Malfunction Indicator Light for the ESP is
combined with BAS indicator. If the power
supply is interrupted (battery disconnected or
discharged), the ESP/BAS Malfunction Indicator
Light may illuminate with the engine running. If this
should occur, turn the steering wheel completely to the
left and then to the right. The ESP/BAS Malfunction
Indicator Light should go out. However, if the light
remains on, have the ESP and BAS checked at your
authorized dealer as soon as possible.
Dealer may have disconnected the battery...this procedure is the same as 'Benz. Turn wheel completely lock to lock with engine running to re-set the system.
2016 392 Hemi Scat Pack Shaker 23Y pkg (6 speed MT) ordered 8/28/15, born 10/23/15, home 11/20/15
Hal H is online now
Blackout (11-30-2012)
post #6 of 33 (permalink) Old 01-17-2009, 12:24 PM Thread Starter
Awesome info. You guys and gals are the best.
1970383 is offline
post #7 of 33 (permalink) Old 01-17-2009, 12:27 PM
Hey 1970383
Mine did the same thing when I disconnected the battery to reset the PCM and TCM, I called the dealer and they want me to bring it in on monday, but the light went out own its own, (didnt know about the wheel back and forth trick) thanks "HAL H" for that info I'll try it next time it happens,
HAL H, you wrote "page 287 in the manual - to syncronize ESP/BAS" are you referring to the owners manual?
Scruggsy
3 cudas past is offline
post #8 of 33 (permalink) Old 01-17-2009, 12:37 PM
Scruggsy
Yes, that's correct - in the owner's manual. I have a .pdf version I uploaded from Dodge.com so that I can look this up and copy+paste when questions arise.
Another thing that can also trigger a ESP/BAS warning is the brake pedal switch if it goes bad (was a common thing on 'Benz cars - cheap switch to replace) if the steering wheel re-synch doesn't do the trick. That would be covered under your 36mos/36k mile warranty.
One other possibility is if a ABS wheel sensor (or cable connector) goes bad, but that has been pretty rare. Unless something thrashed around inside the wheel well and damaged the ABS cable going from the body to the backside of the wheel hub - those can be easily replaced too.
Hal H is online now
post #9 of 33 (permalink) Old 12-09-2010, 11:18 AM
....I just had my BAS/ESP light illuminate along with the traction control icon while in traffic this morning. The car has 8k miles and no modifications. I also didn't do anything recently (i.e. disconnect the battery) that I would think may have attributed to this event. The lights stayed on for the rest of my commute. Once I restarted the car, everything was normal.
Just for some background... I have also had intermittent occurrences of the "Key FOB Not Detected" issue and the stalling issue (happened 3 times.....it's an auto). Are there any other triggers other than what you mentioned above? You think it's possibly the brake switch as you mentioned? ....thanks Hal.
Kean is offline
post #10 of 33 (permalink) Old 12-09-2010, 02:54 PM
I have the exact same issue with my 2010 R/T whenever I disconnect the battery. You just have to reset the BAS/ESP as explained above.
Jay6spdRT is offline
Check Engine Light -Reading Codes 2012 Challenger Perfracer General Challenger Discussion 12 04-09-2016 08:38 PM
How To Diagnose/Fix Trunk Light Circuit ChuckR How-To, DIY and Tips & Tricks 20 04-06-2016 08:15 PM
Head light emitting brownish light?? Sycosis Challenger Issues & Problems 6 09-25-2012 07:20 PM
Help with HID conversion Dellhoney General Challenger Discussion 26 09-03-2012 12:34 PM
Laboratory for Engineering (LFE) Signal Light Restoration BioHzrd Off-Topic Discussion 13 07-01-2012 04:38 PM
