Traction Control turning off in the middle of driving. - Dodge Challenger Forum: Challenger & SRT8 Forums
Go Back   Dodge Challenger Forum: Challenger & SRT8 Forums > Model Specific Discussion > Dodge Challenger R/T Specific
Old 12-16-2012, 07:46 PM
MoparSpeed's Avatar
Send a message via Skype™ to MoparSpeed
Something I've noticed after I installed my Diablosport 93 CAI tune is that my traction control will randomly turn itself off while I'm in the middle of driving. Both traction lights will come on meaning the one with the little car and ESP BAS.
Anyone else had a problem like this? I've look but can't find anything on it.
Some side notes:
Traction Control is Enabled on my tune
This will happen without me touching the ESP OFF button.
It's a pretty rare occurrence but has happened a few times.
2009 Brilliant Black R/T
1987 Camaro IROC-Z
1966 Chevy C10 Fleetside
1/4 mile: 13.08 @107.40 mph w/2.04 60' on RSA's
-Mopar CAI - BT Catch Can - Diablosport Intune 93 CAI Tune - Jet 180* Thermostat - 392 IAT sensor
-Eibach Sportline Springs - Painted Calipers - McGard Lugs
-Amber Fogs - LED Tag Light - LED reverse lights - Red LED map lights - Tinted Side Markers
Old 12-16-2012, 08:35 PM
Photos: (1)
Send a message via AIM to SuBXeRo
thats a scarey thought, did you call diablo? its one thing to do it and being fully aware and its another to think its on and its not.
"The Black Beauty"
2012 Challenger R/T Black with Super Trak Pak with 5-Speed
Zed Audio Leviathan III Amplifier (on its way)
Sundown Audio Components
Pioneer DEH-80PRS Deck
Old 12-16-2012, 08:46 PM
MoparSpeed's Avatar
It still chimes when it turns out, but I can see how someone could miss it (radio), in bad rain this would be pretty dangerous. I let my father drive my car and I bet he wouldn't notice if it was off.
I should try and contact diablo, I'm just not sure if it was caused by their tune or not, but I only noticed it after it was installed
JW if anyone has had this issue without a tune.
Old 12-16-2012, 09:13 PM
Photos: (1)
well, if its the only change since.....its probably the tune. Something possibly didn't take right during the flash...it is a computer and computers are imperfect as they are made by man. id suggest reverting it back to stock and then attempting a reflash. If it persists, i'd remove the tune until you talk to diablo unless you do it tomorrow or something. If the ecu is turning it on at will...who knows what else could be funky.
Old 12-18-2012, 06:54 AM
Pull the OBD codes, see if a wheel sensor is on it's way out.
Old 12-18-2012, 08:04 AM
Gator Brah's Avatar
easiest thing to try would be to restore your factory tune and then try and write this one again. something got fubared in the process
Old 12-22-2012, 04:39 PM
MoparSpeed's Avatar
Alright, I reset to factory tune, then re-installed the Diablo Tune. I made sure traction was enabled. Also pulled the #2 fuse to make sure everything is reset. We'll see if it works.
Old 12-25-2012, 07:01 AM
I've swapped tunes a dozen times, and on one occasion,I was left with a check engine light .Just repeated the tune cycle and it went away. Computers are known to do strange things, pretty sure that's why they invented the term "computer glitsch"
In the order I installed them K&N drop-in,suitcase replaced with two magnaflow double offset 2.5" in and out, Jet 180* thermostat. Predator 93cai tune, clean air tube, resonator delete , Fastman ported throttle body..Dyno 8-17 ,102.18* F,, 334 rwhp. torque 359 ft.lbs.A/F 12.6 , SRT8 suspension up grade, Hood struts Best 1/8th mile 2.01 60 ft.,8.49@83.78, DA 88 Only 1/4 mile 2.11 60 ft.1/8th 8.71@82.77 1/4mi.13.41@ 105.49
Old 12-26-2012, 04:12 PM
MoparSpeed's Avatar
Ok, the problem seems to be fixed, but I've noticed a significant lack of power after re-installing the tune. The car seems much slower now. I used the same tune, with the same parameters as before, but now the tires won't squeak in second gear like they did before.
Anyone had a problem like this?
Old 12-26-2012, 05:16 PM
Gator Brah's Avatar
i have not heard of that before. since you have had a couple of tunes that dont seem to be 100% correct id try updating the tuner. updates are available on the diablo website. you will have to return the car to stock tune, flash the update too the device and then reapply the tune to your ride.
traction control on or off? SRT8KIWI Track Talk 16 05-23-2013 11:04 PM
ABS, Traction off light, and ESP/BAS lights are on? tommasom General Challenger Discussion 20 05-07-2013 02:14 PM
traction control firedog220 Dodge Challenger R/T Specific 14 02-21-2013 02:22 PM
Traction control delay? a6t9vette Dodge Challenger R/T Specific 6 09-08-2012 11:45 AM
SRT Driving Experience Cuda340 General Challenger Discussion 0 02-16-2007 05:02 AM
