Modern Muscle 3.5 Supercharger Kit Pictures - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 9 (permalink) Old 01-25-2009, 02:11 PM Thread Starter
Matrix's Avatar
I met up with the folks from Modern Muscle at the World of Wheels show in Chicago. They had four of their cars there and the basic supercharger kit for the Challenger SE. I took several pictures including one of their production kits on a 5.7 Charger. The SE parts are are machined out of aircraft quality aluminum (6061-T6) and are very robust. This kit will last and not throw belts.
I intend to do this upgrade (at around 4-5 psi boost) as soon as I can. The pictures could be better, but I had to hold the camera above and shoot down.
However, you can see the mounting bracket, replacement coolant tank, supercharger and the boost tube with the boost relief valve. The green charger is a 5.7 L, but you can see the work quality.
ID:	4414   Click image for larger version
ID:	4415   Click image for larger version
Matrix is offline
post #2 of 9 (permalink) Old 03-17-2009, 08:51 AM
Send a message via Yahoo to motoman172
Interesting
So what is the cost of this kit for the 3.5?
Any mods need to be done to existing motor besides running 91+ octane?
motoman172 is offline
post #3 of 9 (permalink) Old 03-17-2009, 12:19 PM
5psi?? Come on man get some boost going! I can't wait until I can get one of my own though.
MECP Advanced Autotech
Audio Mods:
Alarm: Viper 5902
Head Unit: AppRadio 2
Front Stage (Fully Active):
Tweeters: Image Dynamics CD1-Pro Mini Horns
Amplifier: Kicker IX500.4 Bridged
Mid-Bass: Sundown Audio Neo 8"
Processing: JBL MS-8
the727kid is offline
post #4 of 9 (permalink) Old 03-17-2009, 12:47 PM Thread Starter
Matrix's Avatar
You guys dug up an old thread. Modern Muscle has had several postings since I put up those pictures. Check out the thread on their initial 1/4 mile runs and visit their web site. They are a supporting vendor and good people. Call them up our send them an email.
Brilliant Black 2010 R/T with Track Pack and Tremec 6 Speed, Custom 8.5 x 20" Old Style wheels and Yokahama 255/40 tires as a start. More to come.
Vortech Supercharged 2009 SE with JBA headers, custom exhaust, Peddars suspension, 3.90/1 rear end complete and sold.
Matrix is offline
post #5 of 9 (permalink) Old 03-17-2009, 06:57 PM
oldman's Avatar
AFAIK, they are now in the low 14s. I wonder if the 4 speed auto in the Challenger can take it? I'm assuming the MM supercharger is a 5 speed auto Nag1 equipped car.
When the genie of forced induction gets unleashed on 4 valve variable timed engines, the numbers will keep falling.
Now Challenger SEs will need the 5 speed auto LSD refit kit... I guess it would be a Challenger SC !
oldman is offline
post #6 of 9 (permalink) Old 03-17-2009, 07:58 PM Thread Starter
Matrix's Avatar
I saw the Charger when it was in Chicago land and it does have the 5 speed.
We start to get into an interesting game with the way the gear ratios are set on the NAG1 3.5l 5 speed and rear axel ratio. It makes it a good overall more flexible performer, but not necessarily the best in the 1/4 mile. It becomes one of those "what do you want" issues.
Modern Muscle never got out of third gear in their runs, perhaps with a higher rear end they will, but not necessarily.
Our 42RLE 4 speed third gear is 1/1 with a 3.64/1 differential which is a better 1/4 mile combination, but not the best based on the HP/torque curves for our 6500 rpm engine. It can handle the torque from a blower (especially a centrifugal blower) but I wouldn't want to put on big wheels and reduce the 3.64/1. I suspect that we can easily run a 3.90/1 without sacrificing much in mpg and increase our drivability especially city wise. Our 1/4 mile times would clearly improve. I have a ring & pinion set ordered that "should" fit our differential. Wheel speed is transmitted from the ABS so no PCM mapping should be required. Notice all the "shoulds". I am going to gamble and if it works I'll post what I did. If it doesn't I'll tell everybody what not to try and I will be out a few bucks.
Matrix is offline
post #7 of 9 (permalink) Old 03-17-2009, 08:11 PM
oldman's Avatar
do only the 09 SRTs (09 R/T manuals too) have an aluminum rear center housing?
Also any idea how strong the 4 speed is? I was looking at the car today and note the V6 sits WAY in front, my Camaro has the LS1 2/3 in back of the front axle. IMO this should make dropping the trans a whole lot easier...
oldman is offline
post #8 of 9 (permalink) Old 03-17-2009, 09:58 PM Thread Starter
Matrix's Avatar
I don't know the answer to your first question. However, your second question concerning the strength of the 42RLE is one I have been concerned with myself. I did a lot of poking & prodding people and the web concerning this transmission. It was originally developed for front wheel drive then re-engineered for rear wheel drive. It has (at least from my sources) a good reliability record, but that is normal driving and we likely aren't "normal" drivers. Our transmission technically is a 42RLE VLP with the VLP standing for variable line pressure. Having the VLP makes it a very efficient machine (or so they say) and its a long discussion, but it has a more complex torque converter tied into the PCM. I have not found any after market higher stall speed torque converters for this transmission. I hope there is one.
In any event increasing the ring & pinion gear ratio decreases transmission load and stress. The centrifugal supercharger increases its boost as RPM increases so the 42RLE wouldn't get slammed trying to get the car moving.
I feel pretty safe about it, but time and experience will tell the story.
Matrix is offline
post #9 of 9 (permalink) Old 03-18-2009, 09:29 PM
buckwheat's Avatar
Vortech looks great!!!!!!!!!!!
Buckwheat
BW
2009 Dodge Challenger SRT 9.20et 150 mph
449 Aluminum Hemi
Arrington Apache Heads
Kenne Bell 4.2LC KB 148mm Throttle Body
Big Azz Cam Motion Camshaft
Triumph Performance Wheels (Street Cruising)
Bogart Racing Wheels/Double Bead Locks with 28x10's
DTP On The Keyboard
Sons of Confederate Veterans Louisiana Division
2015 Dodge Hellcat SRT aka White Trash
2015 Jeep Grand Cherokee SRT
2015 Dodge Challenger Hellcat SRT NMCA Street Outlaw 94mm Turbo
buckwheat is offline
Speedlogix Fog Light Kit 09-14 Challenger 3.5, 3.6 SRT8U Speedlogix 36 01-21-2015 04:46 PM
m112 Eaton Supercharger for 3.5 v6 theereverand Dodge Challenger SE/SXT Specific 15 08-04-2012 09:07 AM
85mm through BBK or 87mm Venturi type Modern Muscle JDGA80 6.4L / 392ci (2011 - ?) 8 07-10-2012 01:47 PM
Will Modern Muscle hold its weight in the future? DMT General Challenger Discussion 20 06-27-2012 11:58 AM
