SE Supercharger Instillation and Results - Dodge Challenger Forum: Challenger & SRT8 Forums
Go Back   Dodge Challenger Forum: Challenger & SRT8 Forums > Model Specific Discussion > Dodge Challenger SE/SXT Specific
Old 07-11-2009, 03:46 PM
Matrix's Avatar
SE Supercharger Installation and Results
I worked with Modern Muscle and their Vortech supercharger package over the last several weeks. The results are excellent, but there was a bit of debugging, not with the Vortech, but with the PCM computer mapping.
Yes, under my new carbon fiber hood and nose badge lies a supercharged 3.5L Challenger SE.
Here is the front view of the Vortech installation. The coolant tank had to be fabricated to allow room for the blower and air intake. The anti surge valve is the unit with the small filter on it. The mounting is fabricated by MM in their shop. The fuel injectors were changed to allow for more fuel. I believe the SRT injectors were used. A different MAP sensor was needed too.
This is a view from the side where you can see the inverted cone air intake for the Vortech. Eventually I should get the air intake routed to the cold air box, but that is very low priority now.
Here is how the process went. After the supercharger was installed at MM it had to go on the dyno to get a proper tune of air/fuel/timing. We had Vortech determine the pulley size so the boost would be 6-8 psi.
The air-fuel-timing map takes about 3-4 hours on the dyno and many runs up to various rpm points. Basically this is all computer mapping that eventually gets burned in the Predator.
It was in the high eighties and very humid, not ideal conditions.
Here are some of the dyno readings after the tune was set.
RPM Torque Hp
4000 232 180
4500 237 202
4750 235 210
5000 230 220
6500 210 260
The max boost was 6 psi.
Depending upon how hot the air was and adding extra cooling fans you could raise or lower the number by 10 hp. We had some PCM glitch on the dyno that would sometimes kill the RPM around 5700 in third (1-1). Running in second allowed the high end tuning to be checked and see that the curves were amazingly linear.
Off the dyno and on the street:
Initially I developed some idle issues. The PCM didn't want to (or couldn't) learn and this caused the idle to lope low and die. If the air was on the PCM used a different mapping and the condition didn't occur. Justin at MM immediately reprogrammed the idle map and this was fixed.
The most annoying issue was a MIL code that indicated the crankshaft position sensor couldn't be learned. Fortunately I had the service manual CD and after about two hours I discovered that code was only activated in the de-acceleration mode and upon reflection of driving that was exactly what happened. I visited MM and Justin immediately concluded that with the fuel totally cut to the injectors the engine went out of range of the fixed band. So we disabled that feature and all issues were gone.
One might think city milage would be affected, but it actually went up a little. I guess because I don't need to use the accelerator as much.
I have run the car in all conditions: full acceleration, gentle acceleration, stop and go, highway cruise and it is very smooth and fast. I find that I don't use much accelerator movement as I don't need it, but if I use it the car really moves. What full throttle did previously, I can accomplish with 1/2 throttle and no strain. The 42RLE behaves fine and shifts very smoothly.
It was never an issue, however, I am in the RWHp specs (300 RWHp) for the transmission. Modern Muscle was fantastic and gave me excellent service.
I am very pleased with this system, and if I need a little more boost, I just get a smaller pulley. But the next work will be some minor suspension adjusting.
Brilliant Black 2010 R/T with Track Pack and Tremec 6 Speed, Custom 8.5 x 20" Old Style wheels and Yokahama 255/40 tires as a start. More to come.
Vortech Supercharged 2009 SE with JBA headers, custom exhaust, Peddars suspension, 3.90/1 rear end complete and sold.
Old 07-11-2009, 03:53 PM
340GTS's Avatar
Photos: (6)
Looks pretty cool. Nice mod. Had to be pretty pricey.
What is the weight difference between the 3.5 engine/tranny combo and the 5.7 engine & tranny?
Old 07-11-2009, 03:56 PM
Photos: (3)
Is that air filter right over the exhaust maifolds sucking in HOT,HOT air?
Old 07-11-2009, 03:59 PM
340GTS's Avatar
Photos: (6)
Has to be pulling very hot air...that whole mod took alot of time,effort and money but confuses me.
Old 07-11-2009, 04:29 PM
Matrix's Avatar
No, it is not right over the ceramic coated headers, they are more toward the rear and down. But it certainly pulls hot air if you aren't moving.
This is just a plumbing fix that I'll get around to and guaranteed to raise some Hp.
Old 07-11-2009, 04:32 PM
340GTS's Avatar
Photos: (6)
Yeah..hot air ruins the gains you worked hard for.
I see a loss w/ my Mopar CAI when it is hot.
Keep up the good work!
Photos: (3)
Glad to hear it as I'm also gona have to do some intake plumbing as well. I want to get the coldest air possible even though its got a inner cooler.btw, were did you get the hood.
Old 07-11-2009, 04:54 PM
Matrix's Avatar
I got the Seibon hood on eBay for a best offer. This guy has lots of carbon fiber stuff mostly for imports.
I haven't decided yet on the path to cool air. I'll think about it as there is no hurry. This is an interesting project for me. I am not in any way doing a cost/benefit analysis. I am just having fun.
Old 07-11-2009, 05:29 PM
Chromer's Avatar
Nice job. Great story and picks. Let everyone know how the suspension tuning goes and what adjustments you make....
Sounds like you're having a great time. Thanks for posting.
SRT8 6-Speed 5% VLT tint all around-skip shift eliminator-DRL's on
6-spd stock xhaust system w/bottle mufflers-sounds soo melodious
Old 07-11-2009, 07:02 PM
S/S Dodge's Avatar
Photos: (25)
Feedback Score: 3 reviews
it's really nice, but i would like to see an intercooler/aftercooler in there. when GM added the intercooler to the '86-'87 grand nationals, that's when they came to life. the '84-'85 GN's didn't compare to the intercooler ones.
Tony...
