WIN
If you choose to keep your existing WIN, then skip this step. However to program new FOBIKS to your current WIN, you will need to know your PIN number. You should have gotten a card with your car when you purchased it that has your PIN number on it. It is probably with your owners manual. That will have a 4 digit PIN. It is possible that you did not get it though, as I did not with my car, but don't despair, the dealership can look up this number and get it based on your VIN number. The dealership uses the number when getting security access to the WIN to program new FOBIKS.
If you choose to go with a new WIN, then it will be a virgin WIN, and the PIN will be 0000, always.
PEM
Install the PEM. Remove your glove box, and look around under there. he harness connector for the PEM is under the dash, up behind the glove compartment area. If you are unable to locate the connector, don't despair, I will explain later where to connect if you have no connector (As in the SE).
LF Antennas
The Keyless Go uses 2 LF antennas. 1 is located near the PEM, behind the glove box area. There should be a harness connector there. The other goes under the back seat. There should be another connector there as well.
OK. That's it for installation, it should be pretty easy to do, and it won't take too long.
My Next post will be how to activate the system and program the new FOBIKS.
That needs to be done with the StarScan tool, or star mobile. With the StarMobile tool, the tech can come right to your house and do this. It will take about 15 minutes to do this either way. Not all dealerships have the StarMobile, so call first and see if they can do it. All they have to do is connect to your OBDII connector, then set you up.
Step 3: Activate the system and program the KG FOBIKS.
All the next steps need to be performed using a StarSCAN or StarMobile tool. This just connects to the vehicles OBDII port. Any dealership with this tool can perform this, however, bear in mind that this system is very new, and most dealerships do not have much experience with it yet, so it might be a good idea to bring these instructions with you to make sure they complete all the necessary steps. If done properly, it will only take about 10 kinutes to do this.
OK. Now everything should be installed, but the car does not yet know that the PEM is there. Until it knows that the PEM is installed, it won't know to route CAN messages to and from it, and it won't even see it.
1. SET the TPIM to see the PEM.
With the StartScan or StartMobile connected to the vehicle, At the main screen, select the ECU View button.
The next screen will show all the ECU's in the vehicle.
Select the TIPMCGW ECU.
Next, Select the TIPMCGW with the green checkmark next to it.
Next select the button Read/Write Data.
Select the row Programmed ECUs: Cabin Network.
Scroll down to PEM, and change it from Not Set to SET. This will enable the PEM in the vehicle.
(Note: as long as you are at this point, you can also enable Remote Start if your vehicle does not have that option set as well. Just hit the back button and go back to Read/Write Items. Select the row Vehicle Config 1, and then scroll down to the row Remote Start Present, and change that value from Not Set to SET. Go Back again, and select the row TIPM Configurable Inputs. Select the row Reconfig Input#4 (B10) and change that value from Not Present to HoodAjar - Analog. That's it. The vehicle will now work with remote start once you install the hood switch, which you can get from MOPAR for around $19)
Now the vehicle will see the PEM.
2. Program New FOBIKs to the WIN.
With the StarScan or StarMobile, go to the Select ECU screen again.
Select the ECU called WCM. Now select the row with the green checkmark.
At this screen , ECU Overview - WCM, select the button called More Options.
Next select the Button, Onboard Routines. This will bring up a list of special routines for the WIN.
Next the tech needs to click the button called Session Control, Select Extended Diagnostics Session, then click Start. (A Sparkplug Icon will appear next to Tester Present, No response required. Close the window.
Next click the button ECU Unlock, select the number 3, then click Unlock. Close that window.
(Note: Once you have unlocked the WIN with security level 3, you will have 60 secods to complete the programming procedure, and then the security access will turn off. For this reason, you will usually have to repeat this process for each FOB to be programmed)
Now that you have gained security access, If you have installed a new WIN, the new WIN will learn the vehicle configuration from the TIPM.
Now select the row PIN and click the Start buitton. Click on Edit Item and enter your PIN. (0000 if a virgin WIN). then click OK. Then click Start to send the PIN to the WIN.
(Optional: If you intend to replace ALL FOBIKS, at this point select the row ERASE Programmed Keys/FOBS, then select Start. Once the erase is complete, the cluster will chime.)
Click the row Programming Mode, then click Start. A window will open, select the row, Entry Option then Edit Item. Select PROGRAM KEY, then click OK.
Insert the virgin FOBIK into the WIN, turn it to the RUN position. The SKIM light on the IP will go from solid to off and the cluster will chime once the WIN has learned the FOBIK.
If more than 60 seconds have passed, you will need to go back through the procedure again to start programming mode again. (Unlock ECU, Enter PIN, Enter programming mode.)
Do this until all your new FOBIKS have been programmed to the WIN (8 FOBIKS max)
With the StarScan or StarMobile tool, go to the Select ECU screen and select PEM.
Select the row with the green checkmark.
Next screen, select the More Options button.
Next screen, select the Onboard Routines button.
Next screen, select the Session Control button, select Extended Diagnostic Session then click Start. (A sparkplug icon will appear next to Tester present, no response required), Close window.
Next select the button ECU Unlock. Select the number 3, then click the button Unlock.
The PEM is now unlocked and security access has been granted. The PEM will automatically learn the vehicle configuration.
Leave the PEM in security access mode to perform the next step.
4. Transfer the FOBIK information from the WIN to the PEM.
With the StarScan or StarMobile tool, Go back to the Select ECU screen.
Select the row WCM.
Next select the WCM with the green checkmark next to it.
Next screen select the Onboard Routines button.
Once again, select session control, Select EXTENDED DIAGNOSTIC SESSION, and then click START. (A spark plug ICON will appear next to TESTER PRESENT, No Response Required.) Close that window.
Next select the ECU Unlock button, and select 3, then Unlock. Under Onboard routines, select the row PIN, and then click the button START. Click on the PIN row, then click the button EDIT ITEM, enter your PIN then click OK (Almost forgot, The PIN you enter here will be 0000, because this is a virgin PEM. If it had been installed at the factory, it would be the same as the PIN in the WIN). Click START to send the PIN to the WIN.
Now, under Onboard Routines, select the row called Transfer Secret Key and Key IDs (Passive Entry Module). Then click Start.
Once that routine completes. you are done!
Now the system should be working.
That should be all there is to it.
Keep in mind that this is for the 8 cylinder Challengers. This procedure and parts will also work for other platforms as well, such as the Chrysler 300, Dodge RAM, Jeep Cherokee, etc.
To perform this on the Challenger SE (As I did) you will not have wire harness connectors, so you will have to make your own (Not Hard to do) and also as I stated earlier, The win only send a signal to start the 8 Cylinder models. To get it to send the proper signal to the 6 cylinder, you would need to Flash the WIN with a new flash file for that. It is not available to dealers, however if they had the file, they could load it into the StarScan or StarMobile and make it work.
If anyone has any questions, feel free to ask.
I hope this helps anyone inetrested in adding Keyless Go and Remote Start to their vehicles. It can be done, and the cost really shoudln't be that much, It really depends on how much you can get the parts for. The dealership should only have to charge you for time for theb reprogramming, and like I said, it really should't take any more than about 15 minutes to do all the programming.
Im going to have to go to the parts house and have them look up the parts. I called the dealer and he told me the part numbers have changed that they are no longer valid.
Sugar Land, Texas
2009 RT 6 speed
K&N CAI
Zex 75 shot (125 soon)
My GIG with Uconnect
Smoked tail lamps and side markers
Tinted Glass
Polished Hood Pins
Skip shift Eliminator
Hotchkis Springs
Next Mods:
Heads and Cam
Long Tube Headers
Diablo
Stroker Kit
Prochargers super charger
I'm pretty sure that remote start can be added to the manual transmission vehicle, using the same methods as above, howver it is not usually recommended to install into a manual tranny car, as if the car slips into gear, or is in gear when you activate the remote start, it will move.
That may be true. I'm sorry that the numbers I posted may not be the most current, as the WIN has changed part numbers 6-7 times in the past 9 months, and the FOBIKS a few times as well. Several of the revision changes are actually due to a software change in the WIN, and all the revisions will work for this. There was actually an H29 recall to flash the older WINs which actually brings them up to the current version.
We make so many kits here, I really know them better by our part numbers, not chryslers.
As far as cost goes, I guess it depends on how much you are able to do yourself.
I installed it for nothing, but I have access to all the right tools.
I am not sure how much each of these items would cost through MOPAR, but like everything else, they have a pretty good markup.
For example, Chrysler buys the FOBIKS from us at about $7 each, then MOPAR sells them I believe around $70 each.
I suppose if you did the labor yourself (Installing the modules) then it would just cost the price of the items, and the 10 minutes it would take a service tech to turn on each item.
If you could get access to a chrysler tool, or the CDA software, then even the programming part you could do yourself. You have to make a few changes to the TIPM in the vehicle so it knows that a PEM has been installed, and then just program the PEM and WIN with the right FOBIKS. It's not that hard to do with the right tools. And with the RT and SRT8, the proper harness connectors should already be there.
With the SE, which is what I have, there are no connectors, so I had to jack into the CAN B at the HVAC controls. No big deal though and easy to get to.
Maybe if anyone is interested, I will do an instruction write up detailing just what is needed to make it work. All in all it's not that hard and it is nice not to have to put the key in anymore. Just hop in, press a button and go!
Wow. I just looked up the FOBIK part number at MOPAR (which is 68044078AA for the 4 button KG FOB , no remote start button) and they sell it for $96.20!
