| General Discussion This section contains general discussion about the new Dodge Challenger concept. If it does not fit into a more specific area, it probably belongs in here. (Dodge Challenger General Discussion) |
'09 Challenger R/T : All Related Specs ,Equipment & Info In Here
For 2009 the R/T model will offer the all-new 5.7L VCT Hemi with MDS (5-speed) and without MDS (6-speed). Both the R/T and SRT8 will offer an optional six-speed TREMEC manual transmission. Production of the 2009 models is set to start early, in June of 2008. Vehicles are expected to start arriving to dealers in late June/July. During the 2009 and later model years Dodge will most likely offer some special edition Challenger models similar to what has been done with other vehicles in the past.
The 5.7L Hemi engine is set for an upgrade, which is why the R/T Challengers will not arrive until the 2009 model year. Chrysler will have variable cam timing in place on these new-generation 5.7 engines, neatly leapfrogging most variable-valve timing systems. In addition to VVT and expanded MDS operating range, the HEMI’s fuel economy (~4%) and performance improvements (~10%) result from an increased compression ratio, an active intake manifold with long runners for low-end torque and short runners for high-rpm power, improved cylinder head port flow efficiency, and reduced restriction exhaust and induction systems. To raise the reliability and durability of the HEMI engine, other updates are crankshaft structural upgrades, a dual-mass crankshaft damper, floating pin piston design, valve spring design and oil pump capacity increase for VVT. The 2009 Dodge Ram will get 380 hp and 404 lb-ft of torque from the new Hemi and the Challenger numbers are expected be somewhat similar. The expanded Multiple Displacement System (MDS) will be included in the new 5.7 that is offered in R/T automatic transmission models, while 6-speed manual R/T models will feature the same engine without MDS. A 6.4 liter version, with an estimated 500 or more hp, is still expected to be offered in a future model of the Challenger, possibly debuting in the 2010 model year. Additional features of the 2009 R/T will include a rear body-color spoiler, 4-wheel anti-lock heavy-duty brakes, anti-spin rear differential, chrome pedals, dual rear exhaust, heated front seats, illuminated cupholders and map pockets, power heated mirrors, instrument cluster display screen, performance steering and suspension and 20”x8” chrome-clad wheels. R/T models will have a 19-gal. fuel tank, vs the 18.5 tank on the base models. All 2009 Challenger models will feature, as Standard equipment, front and side air bags, air conditioning, body-color door handles and fascias, cell phone storage, cruise control, a floor console with sliding armrest, functional hood scoops, non-adjustable pedals, power mirrors, power windows (1-touch down), rear wheel drive, rear window radio antenna, 3-point rear center seatbelts, satin/chrome grilles, Sentry Key anti-theft system and a tilt-telescoping steering wheel. None of the Challenger models will feature a spare tire, a “service kit” will be offered instead. Other features and options on the 2009 Challenger will include Remote Start, MyGIG Infotainments systems with and without navigation, Sirius Satellite radio, foglamps, and a power sunroof. Base models will have a Tire Pressure warning light while other models will have a Tire Pressure display. 2009 colors will include but not be limited to, Bright Silver, Brilliant Black, High-Performance Red, HEMI Orange, Dark Titanium Metallic and Stone White. Additional colors are still to be determined. For the interior, Dark Slate Gray will be offered on all models. Other interior color choices are unknown at this time. 2009 Drivetrain Specs : R/T 5.7 V8 VCT with MDS 5-speed Automatic - Axle Ratio : 2.82 - Hill Start Assist : No - Trak Pak : No - Wheels : 18 X 7.5 (Optional 20 X 8) - Tires : P235 / 55R / 18 ASP (Optional P245 / 45R / 20 ASP) R/T 5.7 V8 VCT w/out MDS 6-speed-Manual - Axle Ratio : 3.73 with Limited Slip - Hill Start Assist : Yes - Trak Pak : Yes - Wheels : Same as R/T Automatic - Tires Same as R/T Automatic with no spare tires on any models (and no run-flats), tire service kits will be included. Look for chrome fuel filler doors on the R/T and SRT models. Manual transmission versions of the 2009 Challenger R/T and SRT models will have Hill Start Assist; it helps the driver when starting a vehicle from a stop on a hill by maintaining the same level of brake pressure the driver applied for a short period of time after the foot has been removed from the brake pedal. The system will release the brake pedal in proportion to the amount of throttle applied. If the throttle is not applied within a short period of time after the foot has been removed from the brake pedal, Hill Start Assist will release brake pressure. Trivia: Stutz had Hill Start Assist (they called it the Noback) in 1929. Challenger convertible models are rumored to be added in the 2010 model year, with production possibly starting in the first half of 2009, several months earlier than the 2010 non-convertible models. Convertibles will be offered in the base and R/T models only. Finally, the 2011 or 2012 Challenger will most likely include the upcoming 4.0 liter Phoenix engine, replacing the 3.5 liter. This explains the front seat belt mounts, which are normally bolted to the bottom of the B post, then travel up the B post at which point you grab it and place over your chest. In the Challenger, seat belts are set up convertible-style; there is a small bar at the bottom of the B post which the seat belt is attached to. This allows it to slide back and forth to help with getting it out of the way when getting in the back. Then the seat belt travels through a loop at the top of the seats like in a convertible. You grab the seat belt from the top of the seat and then place across you chest. This may indicate that someone is thinking ahead to making a convertible. Last edited by SIX-PAK : 02-10-2008 at 09:15 PM. |
Re: '09 Challenger R/T Gathered Specs / Equipment & Info Related
Now as to what I want to see from either Mopar or the aftermarket in the '09 R/T additionally heheh to make this perfect IMO :
1) The/or similar to the Concept steering wheel 2) Wrap-around Console my biggest pet-peeve missing (plz take out cup holders) 3) Pistol Grip similar or better than Concept (true to '70's shape but in metal matching accents) 4) The Concept's Rippled Retro Leather Seats 5) Reconfiguration of the front lighting assembly : ... have only the HID Lo's in the outer lamps only ... have the inner lamps match in color when lit ... have the flasher in the bottom bumper and used as RDLs (Running daytime Lights) exactly like the '70 model ![]() PS , I will , if they don't for : 4) Go to a custom shop and have them build me Rippled Retro Leather Seats 5) Since the outer beam is a Hi/Lo HID and I want matching illumination - I would buy another HID Hi/Lo set and swap them with the inner lamp housing completely (hopefully circumference allows) , and have my DRL wiring + flashers moved to the lower bumper lights ![]() Now I just can't wait to see if the R/T will get a different hood (hope not) with its functional Air Traps like the SRT8 , and some different type of graphics (again I'm not sure what would look good on this specific body architecture which is very differently sized on the flank compared to the '70's original body) I might in the end go with the more expensive SRT8 6-speed-manual for the hood / striping !?? If any of you obtain NEW Information (compared to above) on the '09+ Challenger R/T 's (Automatic and/or Manual) , please post here in this specific thread exactly created for this model . Last edited by SIX-PAK : 02-10-2008 at 07:37 PM. Reason: added pics |
A couple of interesting, and logical restrictions:
SRT will NOT be offered in a Convertible, which makes sense. No Trak Pack with 5.7 Hemi and 5-speed Automatic. Only with a Manual. Anybody notice (or know) whether the SRT8 will get a Track Pack option? Also, will it be offered with the Manual as well as the Automatic? Also, will the '09 6.1 Litre get VVT and a HP boost? I believe it will. LJB ![]() PS: Maybe the Red might be the color choice....no....Black....I mean....Hemi Orange. |
Originally Posted by M3SMG02
You can find some of your SRT8 questions answered in my 2 other posts in another non-R/T thread : Anticipated Quarter mile times? |
No VVT, (no MDS either) same hp, same engine, might be a slight difference between auto and manual models.
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Challenger SRT8 Specs | Rambit | General Discussion | 3 | 02-10-2008 12:15 PM |
| Neat Challenger info.. | TurboAWD | General Discussion | 1 | 08-17-2007 03:16 PM |
| GM revives Camaro muscle car (add all Camaro related posts here) | Mr.DJ | Off-Topic Discussion | 41 | 09-13-2006 07:55 AM |
| Dealer Info r/e the Challenger | XJameson | Off-Topic Discussion | 0 | 07-15-2006 03:01 PM |
| The Official 'Challenger' Specs Are Here! | Mr.DJ | Dodge Challenger News | 34 | 02-05-2006 05:38 AM |
