2011 Fluids and Capacities - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 2 (permalink) Old 07-20-2011, 06:40 AM Thread Starter
2011 Dodge Challenger Fluid Capacities/Specifications
ENGINE
* Engine Coolant
3.6L Engine
MOPAR® Antifreeze/Coolant 5 Year/100,000 Mile Formula HOAT (Hybrid Organic Additive Technology)
1 Gallon - 5066386AA
10.4 Quarts
9.9 Liters
5.7L Engine
14.7 Quarts
13.9 Liters
6.4L Engine
15.2 Quarts
14.4 Liters
* System fill capacity includes heater and coolant recovery bottle filled to MAX level.
Engine Oil with Filter
3.6L Engines
MOPAR® API Certified SAE 5W-30 engine oil, meeting the requirements of Chrysler Group LLC Material Standard MS-6395.
1 Quart - 4761838AB
6 Quarts
5.6 Liters
1 Gallon- 4761844AB
5.7L Engines
MOPAR® API Certified SAE 5W-20 engine oil, meeting the requirements of Chrysler Group LLC Material Standard MS-6395.
1 Quart - 4761872MA
7 Quarts
6.6 Liters
1 Gallon - 4761851AF
6.4L Engine
MOPAR® API Certified SAE 5W-40 engine oil, meeting the requirements of Chrysler Group LLC Material Standard MS-10725.
1 Quart - 05127394AB
7 Quarts
6.6 Liters
Engine Oil Filter
3.6L Engines
MOPAR® Engine Oil Filter 68079744AA
5.7L and 6.4L Engines
MOPAR® Engine Oil Filter 04884899AB
Fuel (approximate)
3.6L Engine
87 Octane Acceptable - 89 Octane Recommended
19 Gallons
72 Liters
** 5.7L Engine
19 Gallons
72 Liters
6.4L Engine
91 Octane Only or higher
19 Gallons
72 Liters
** For best performance and maximum protection under all types of operating conditions, vehicles equipped with a 5.7L engine and a manual transmission, 91 Octane Premium Unleaded fuel is preferred.
A/C Refrigerant System
R-134a 82300101AB
1.56 Pounds
709 Grams
SPARK PLUGS
3.6L Engine
Champion® SP149125AD (RER8ZWYCB4)
0.040 in
1.00 mm
5.7L Engine
NGK® Yttrium 05149177AB (LZFR5C-11G)
0.040 in
1.00 mm
6.4L Engine
NGK® Single Platinum
05149212AC (LZTR6AP11EG)
0.040 in
1.00 mm
TRANSMISSION
NAG 1 - Service Fill
MOPAR® ATF+4 Automatic Transmission Fluid
1 Quart - 05013457AA
5.3 Quarts
5.0 Liters
1 Gallon - 05013458AA
* NAG 1 - Overhaul Fill
8.1 Quarts
7.7 Liters
Manual
** TREMEC TR6060
* Dry fill capacity. Depending on type and size of internal cooler, length and inside diameter of cooler lines, or use of an auxiliary cooler, these figures may vary. Refer to the appropriate service information for the correct procedures.
** Approximate dry fill or fill to bottom edge of fill plug hole.
CHASSIS
Axles (Rear)
198mm RII Rear Axle
MOPAR® Synthetic Gear Lubricant SAE 75W-140
1 Quart - 04874469
1.5 Quarts
1.4 Liters
215MM RII Rear Axle
1 Quart - 05010320AA
1.3 Quarts
1.2 Liters
* 226mm RII Rear Axle
MOPAR® Synthetic Gear Lubricant SAE 75W-90
1.4 Quarts
1.3 Liters
* Limited-Slip Rear Axles require the addition of 118 ml (4 oz.) MOPAR® Limited Slip Additive
Chassis Systems
** Brake Master Cylinder
MOPAR® Brake Fluid DOT 3, SAE J1703.
12 oz. Bottle - 04318080AB
32 oz. Bottle - 04318081AB
*** Power Steering Reservoir (Belt Driven Pump)
MOPAR® Power Steering Fluid +4
**** Electro Hydraulic Power Steering (EHPS) Reservoir
Hydraulic Power Steering Fluid meeting MS-11655
1 Quart - 68088485AA or 05127381AB
** If MOPAR® Brake Fluid DOT 3 is not available, then MOPAR® Brake and Clutch Fluid DOT 4 (P/N 04549625AC), is acceptable.
*** If MOPAR® Power Steering Fluid +4 is not available, then MOPAR® ATF +4 Automatic Transmission Fluid (P/N 05166226AA), is acceptable.
****There is an Electro Hydraulic Power Steering (EHPS) pump on Non-SRT vehicles which requires a different power steering fluid. Do not mix power steering fluid types. Damage may result to the power steering pump and system if any other fluid is used. The EHPS system uses fluid which meets material specification MS-11655 or equivalent. The mechanical power steering pump systems on SRT vehicles require the use of Power Steering Fluid +4, which meets material specification MS-9602 or equivalent. Do not overfill.
sitedrifter is offline
The Following User Says Thank You to sitedrifter For This Useful Post:
RockanRoll (01-18-2014)
post #2 of 2 (permalink) Old 07-20-2011, 07:28 AM
carbcounter2012's Avatar
goodinfo thanks
carbcounter2012 is offline
Gear in this thread - Powered by O'Reilly Auto Parts
User Tag List
