392 IAT (long) sensor virtually cured my heat soak issue - Page 4 - Dodge Challenger Forum: Challenger & SRT8 Forums
  #31 (permalink)
Old 11-17-2011, 04:22 PM
rayzazoo's Avatar
Feedback Score: 4 reviews
Originally Posted by randycat99 View Post
Thank the Mopar spirits for the RT gray plug!
Also, thank you to rayzazoo for setting me straight about the plug, and not just selling me a cable after asking for one.
For those still needing a black to grey converter, I do have 4 left. I think this will be my last batch. PM me if you're interested.
2012 "Cora" Challenger SRT8 392 - 12.847 @ 109.89 mph
2015 Challenger SRT 6.2L SC Hemi - Spring Fest 2014
Torred '10 SRT8 - 12.604 @ 112.11 mph / 12.817 @ 110.05 mph
Torred '09 R/T - 13.291 @ 103.67 mph
  #32 (permalink)
Old 11-17-2011, 04:36 PM
=Route 66='s Avatar
So if I have a 2010 SRT8, it's safe to say I have a black plug?
  #33 (permalink)
Old 11-17-2011, 04:47 PM
cruiserdan's Avatar
My 09 SRT is black.
1970 Challenger R/T SE, 440 Magnum, E5 red, black top, black bumblebee. 2009 Challenger SRT8, 6speed, sunroof, nav, MP Corsa, K&N CAI, one of those clear blue tuner thingys, a nasty door ding, bald rear tires, hops like a bunny , stripe-delete, PR3 cop-attracting-red and some Land Cruisers.
  #34 (permalink)
Old 11-17-2011, 05:52 PM
rayzazoo's Avatar
Yup, more than likely. The grey plug connectors were found mostly on 09 R/Ts and the 2011+ models when they redesigned the air box.
It's an easy check. The black connectors (usually on SRT 08-10 and some 09-10 R/Ts) is in the middle. The grey connectors (on some 09 R/Ts and all 2011+ MY) is on the far right. If you have the middle one, then the plug and play converter cable is necessary in order to use the new long IAT sensor. If not, and you already have the grey, you can go to your dealer parts and pick up the new long IAT sensor for $6.
  #35 (permalink)
Old 11-17-2011, 05:58 PM
Dadstoy's Avatar
subscribing so I can read this in the morning
Sent from my keyboard, typed in by me the old fashion way.
John
best run 12.283@114.18mph - 100% factory stock on factory tires.
best 60' 1.841 - 100% stock on factory tires
411.7 RWHP / 443.5 RW Torque on a Dyno Com dyno. Zoomer cat back and Speedlogix CAI
Current:
2011 392 SRT Challenger
2004 5.7 Dodge Rumblebee 4x4
2001 5.9 Dodge Ram quad cab 4x4
  #36 (permalink)
Old 11-17-2011, 06:31 PM
rayzazoo's Avatar
It's mentioned in the first post, but also another thread for more background information on this to add to your morning read.
Mystery Grey IAT Sensor Connector - SOLVED!
  #37 (permalink)
Old 05-11-2012, 03:58 PM
OmahaRumble's Avatar
Feedback Score: 8 reviews
Originally Posted by Crush View Post
Thanks to the posts put up by mikeyChallenger Heat soak eats 20+ lb/ft of torque! and rayzazoo Mystery Grey IAT Sensor Connector - SOLVED!
My car is a dog in 85+ degree weather, esp with the A/C on, so I was really excited about trying the new 392 IAT sensor PN 05149279AB. It was $3.50 and plugged right into my gray connector and into my RoboFab air tube. Today was the real test as I go home for lunch, the car heat soaks, and I drive back in 90+ degree humid temps. The new sensor really made a difference I could feel. This is in the stock mounting location. Eventually I'll get the extension cable and relocate to the air box.
Thanks for the research guys as the heat soaking was one of my biggest complaints about the car. I can't wait to see if cooler weather performance is better as well.
(I wanted to put something with a "heat soak" subject in this section for exposure.)
Wait a minute, you just bought the regular 392 IAT sensor and it plugs into both the grey plug and the intake tube? I'm confused. Why does Rayazzo have these specially made adapters? Do you have to splice the wires and do it that way, or is it a direct plug into the grey plug (on 09 10 RTs.) Thank you. I am very much interested in this mod.
-= 2010 Dodge Challenger R/T Classic =- in Brilliant Black. Super Track Pack, sunroof, leather, 3.92 gear, 6 speed.
MODS:
Zoomers catback exhaust
AFE Stage II cold air intake
Fastman ported throttle body
Diablo CMR tune by Johan
Mopar splash guards
SRT8
6.1 chin spoiler
SLP skip shift eliminator
BT catch can
3M 20% window tint
functional hood scoops
  #38 (permalink)
Old 05-11-2012, 04:48 PM
BrUiRcNeR's Avatar
Feedback Score: 2 reviews
I don't have a modified intake and the 392 IAT Sensor plugged right into the stock connector and mounting location on my '10 R/T.
The adapters he makes can solve issues with a different connector, the need for a longer wire to relocate the sensor further from the stock location (some CAI's I assume), or both.
For the price I figured I had nothing to lose.
-Randy
2010 R/T Auto
The Challenger doesn't say something about me...
...it says something TO me!!
  #39 (permalink)
Old 05-11-2012, 06:10 PM
The 5.7s appeared to come equipped with the gray IAT connector from '09 on up.
The '08-'10 SRT 6.1s had the black connector and the newer design (long) 392 IAT sensor wouldn't mate to the black connector, so it was necessary to fabricate an adapter that allow the new IAT sensor to be installed.
It seems the 6.1s were really prone to heatsoak and they'd pull timing and lose some top end / mid range power.
  #40 (permalink)
Old 05-12-2012, 07:32 PM
Thank you for the clarification. So since I have the grey plug (I have a '10 R/T), I can just buy the 392 sensor from the dealership and plug and play? Very nice, I will have to stop by Baxter next week and get me one of those. Would love to battle against heat soak.
How about a 392 timeslip sticky Dadstoy Track Talk 271 05-09-2013 11:10 AM
