Old 02-09-2008, 07:31 PM
Points: 311, Level: 6
Points: 311, Level: 6 Points: 311, Level: 6 Points: 311, Level: 6
Activity: 0%
Anticipated Quarter mile times?
Anybody have any roughly accurate numbers? My Charger SRT8 with the 3.0 rear end will run a 13.2-13.4s @ 106. What will this new rear end yield? Will it even make a difference? I would assume so!
Old 02-10-2008, 08:10 AM
Points: 454, Level: 7
Points: 454, Level: 7 Points: 454, Level: 7 Points: 454, Level: 7
Activity: 0%
Re: Anticipated Quarter mile times?
Unless you're magazine-racing, quarter miles times are really driver-dependent. Otherwise, the Charger's times are a good benchmark plus or minus a few tenths, at least until a magazine gets their hands on one.
Old 02-10-2008, 01:05 PM
Points: 715, Level: 10
Points: 715, Level: 10 Points: 715, Level: 10 Points: 715, Level: 10
Activity: 0%
This could help...
MyMopar.com
probably a little off though.
Old 02-10-2008, 02:06 PM
Points: 2,277, Level: 19
Points: 2,277, Level: 19 Points: 2,277, Level: 19 Points: 2,277, Level: 19
Activity: 0%
What's the Gearing on the Challenger vs the Charger. Assuming both in SRT8 Trim, if the gearing is identical, then, I would assume similar performance. They both weight about the same, and same Engine & Trans.
What are the Gear Ratios and Diff Ratio on the Challenger?
LJB
Old 02-10-2008, 02:08 PM
Activity: 0%
...plus another thing. The Charger has a longer wheelbase, which (theoretically) could plant it's torque more effectively than the Challenger, assuming similar Drivetrains.
LJB
Old 02-10-2008, 02:14 PM
Points: 352, Level: 6
Points: 352, Level: 6 Points: 352, Level: 6 Points: 352, Level: 6
Activity: 0%
This is Hayabusa from SRT forums. I couldnt use that to log in. Is this a different server? If it is someone else already has the name so if anyone is posting under hayabusa it is not me:
By the way that quarter mile calculator is way off. If it were correct I would be running 10.83 in the quarter instead of 11.49. This one is much more accurate and I have checked it with tons of different cars. With the proper tires, gears, tranny, and of course driver it is usually accurate within less than 2 tenths 1/4 Mile ET Calculator
Memphisblue /Hayabusa
Old 02-10-2008, 05:08 PM
Activity: 0%
Yeah, if they have the same 3.0x rear end then obviously it will be identical performance. I thought the challenger had a 3.93 or close to?
Old 02-10-2008, 06:18 PM
SIX-PAK's Avatar
Points: 2,125, Level: 18
Points: 2,125, Level: 18 Points: 2,125, Level: 18 Points: 2,125, Level: 18
Activity: 0%
The 2008 SRT8 6.1 Hemi 5-speed-Automatic sports 3.06 LS (Limited Slip) Axle Ratio without Trak Pak
The 2009 SRT8 6.1 Hemi 6-speed Manual will sport a 3.92 LS with Trak Pak
The 2009 R/T 5.7 Hemi 5-speed Automatic will sport a 2.82 w/out Trak Pak
the 2009 R/T 5.7 Hemi 6-speed-Manual will sport a 3.73 LS with Trak Pak
Old 02-10-2008, 06:21 PM
SIX-PAK's Avatar
Activity: 0%
0-60 in 4.9 seconds
Five seats
Zero to 100 mph and back in under 17 seconds
Quarter-mile times 13.3 seconds
60-0 braking of 110 feet
Skid pad performance of 0.88 g (or .9g as reported in the launch ceremony)
A five-speed automatic (no manual transmission yet)
vB code is On
1/4 Mile Calculator Cuda340 General Discussion 1 07-26-2007 09:14 PM
Dust to Dust, Cost Per Mile BJoe Off-Topic Discussion 0 04-14-2006 05:22 PM
Remove "Challenger" From the Rear Quarter Panel. M3SMG02 General Discussion 9 02-01-2006 07:58 PM
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
