Old 05-12-2008, 05:39 PM
Venthos's Avatar
Points: 4,700, Level: 28
Points: 4,700, Level: 28 Points: 4,700, Level: 28 Points: 4,700, Level: 28
Activity: 88%
Activity: 88% Activity: 88% Activity: 88%
Confirmed? No LSD '08, Yes LSD '09 R/T Manual and SRT8 Auto/Manual?
Just came across this now. It could very well be old news and since it's not an official spec sheet I guess it can only be taken as speculation at best. But I believe there was a lot of curiosity and debate about what years/trims were getting LSD and such. Many of you may already know this or this may not be a true confirmation, but I hadn't seen this and thought it was interesting.
Per AutoWeek's interviews: Inside the Dodge Challenger SRT8 - AutoWeek Magazine
Quoted from: Peter Gladysz, senior manager of SRT Powertrain
Originally Posted by Peter Gladysz
"For 2009, the Challenger will have the option of a six-speed manual gearbox and a limited-slip differential. The gearbox basically shares its heritage with the Viper, but we do change ratios in it, just because the engine size and the car weight are considerably different.
"It will share the same twin-disc clutch package as the Viper. That's for long-term durability, and also it gives the car kind of a smartness in shifter quality and clutch quality. Gone are the days when it takes two arms and two legs to push the clutch down on these high-torque cars. The twin-disc clutch basically allows that to be almost effortless.
"The '08 car doesn't have a true limited-slip; it has what we call brake-lock differential. It's an electronic version of a limited-slip. It works by slowing one wheel down to match the other wheel. But it doesn't really instantaneously put all of the power to the ground.
"So, on the '09, the limited-slip will make the car faster in autocross, really any kind of road-racing activity. Getrag is the manufacturer, but we're going back to buzzwords of the '60s and '70s, and it'll be called a Track-Loc.
"That will be on the 5.7 and the 6.1 manuals and on all of the SRT automatics. It's a very good package. It puts the power to the ground very effectively. It allows the owner of the car to really enjoy the experience.
"This car has a rear axle that's actually produced by Mercedes; it's the primary rear axle in all of their performance cars, with 215-millimeter ring gear. But for 2009, the ring gear goes up from 215 millimeters to 226 millimeters.
"You'd say, well, that's not a lot, but in torque durability, it goes up by the square, so the capability goes up quite a bit. And we get the limited-slip with it.
"The axle ratio in all of the automatics is 3.06:1, but for the manuals, we're going to have two ratios. On the 6.1, there will only be a 3.91 ratio, and on the 5.7, there'll be two packages, a 3.73 and a 3.91. The 3.91 gets different tires as well.
Old 05-12-2008, 05:45 PM
SRTpusher's Avatar
Supporting Vendor
Points: 3,016, Level: 22
Points: 3,016, Level: 22 Points: 3,016, Level: 22 Points: 3,016, Level: 22
Activity: 2%
Activity: 2% Activity: 2% Activity: 2%
Re: Confirmed? No LSD '08, Yes LSD '09 R/T Manual and SRT8 Auto/Manual?
I just placed and order for an automatic and the anti-spin shows on the SRT-8 as standard equipment.
Old 05-12-2008, 05:48 PM
Venthos's Avatar
Activity: 88%
Do you per chance have the full option list?
Old 05-12-2008, 05:50 PM
Supporting Vendor
Points: 871, Level: 11
Points: 871, Level: 11 Points: 871, Level: 11 Points: 871, Level: 11
Activity: 0%
2009 Challengers below MSRP
That has the available options to order. I will post up the full equipment list in a little while
Old 05-12-2008, 06:07 PM
SRTpusher's Avatar
Supporting Vendor
Activity: 2%
Which Champion Jeep are you with?
Old 05-12-2008, 06:52 PM
Kelsey73's Avatar
Points: 1,931, Level: 17
Points: 1,931, Level: 17 Points: 1,931, Level: 17 Points: 1,931, Level: 17
Activity: 7%
Activity: 7% Activity: 7% Activity: 7%
I guess that finally settles it. Oh well just gives me a good reason to buy an 09 too!
2007 White Shelby GT
2008 Hemi Orange Challenger SRT8
Old 05-12-2008, 07:25 PM
NOTSURE's Avatar
Points: 7,600, Level: 37
Points: 7,600, Level: 37 Points: 7,600, Level: 37 Points: 7,600, Level: 37
Activity: 100%
Kelsey, go 09 you wont have regrets you deserve what you want dont settle....
I had a feeling the 08 wasnt lsd.
Im sending you a pm asap on some info I have for your eyes only..
Keep on Keepin on!
2009 srt8 black-soon to be in my garage
Currently pay plates yearly on:
2000 C5 (400hp)
2005 Maserati CambrioCorsa spyder(wifes)
2005 Magnum RT awd
2007 Camry Hybrid 50th Anniversary Edition(wifes company car)
vB code is On
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
