Old 01-27-2007, 09:49 AM
Cuda340's Avatar
Points: 10,500, Level: 44
Points: 10,500, Level: 44 Points: 10,500, Level: 44 Points: 10,500, Level: 44
Activity: 41%
Activity: 41% Activity: 41% Activity: 41%
Photos: (4)
Wink DCX Security System
A while back, I posted a thread about the Ravelco security device. I had read many scare stories about how car thieves use decoders to bypass factory security systems. I had a car stolen in front of my house and don't want it to happen to my new Challenger!
In Chargerforums.com, a similar issue was discussed. Lucky for us, it seems like Daimler-Chrysler has the best factory system on the market and there may be no need for a supplemental security system. (Note: GM's "Pass-Key" is one of the worst).
Here is a quote from the Chargerforums site explaining how the DCX system works:
Ah, its even more clever than that. See, the security module queries for the code. And its not the same code every time. That chip actually generates a new code every time. The security module knows the math formula that the key chip uses, and so it can tell its a good one. Meaning that its one of the keys that it "recognizes".
" The security module solves a math problem, using the code and some other stuff, the VIN is a part of it, solves it, sends the raw data off to the engine computer, which does all this over again, and sends its answers back to the security module. Which then compares its answers to the PCMs, and if anything does not match, your done, shut down. You get three tires, if that third one fails, it takes a Starscan and a call to DCX for a code to reset the system.
For you geeks, its a 32 bit PKI style system, made by TI. Ford runs the same basic system, but only the security module does the check, then sends a simple signal to the engine computer, which can be faked. Too bad for Ford owners."
vB code is On
Should DCX use MDS system for HP & Mileage Dodgedude General Discussion 37 03-24-2007 03:17 PM
Will the new Challenger's ECM be based on a "Speed Density" type system Wild Monkey General Discussion 5 01-26-2006 07:16 PM
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
