Dead Battery charging tips? - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 19 (permalink) Old 07-29-2009, 09:50 PM Thread Starter
RTguy09's Avatar
I awoke today with a dead battery. I'm guessing I have to crawl through the back seat to get to the manual release for the trunk.
I do have a auto battery charger, and have used it on my truck few times, but I know the battery in my R/T is a little different. Is it even safe to do so? Or a different setting the charger needs to be on?
Always good advice from my comrads on this site. Please share some knowledge with me so I may keep myself and my Challenger R/T safe.
Thanks in advance!
RTguy09 is offline
post #2 of 19 (permalink) Old 07-29-2009, 10:24 PM
Zoomin's Avatar
Connect your charger to the terminals in the engine compartment, and you should be able to pop the trunk.
2014 Shaker 869/2000
Zoomin is offline
post #3 of 19 (permalink) Old 07-29-2009, 11:16 PM Thread Starter
RTguy09's Avatar
The battery charger has a 75 amp "quick start" switch on it, I've used it on my Expedition with success. Can I use that through the front engine compartment posts?
RTguy09 is offline
post #4 of 19 (permalink) Old 07-30-2009, 02:00 AM
mokeman3's Avatar
The battery in you R/T is not different in any way. All flooded lead acid batteries are the same, and your auto charger will work perfect.
So what killed your battery ?
MM3
mokeman3 is offline
post #5 of 19 (permalink) Old 07-30-2009, 06:38 AM
A "battery tender" from Deltran is the only way to maintain a proper charge over a long period of storage. We use them on everything from stand by generators to ATVs, Harleys, cars, trucks and have never experienced a dead battery....only if you have a good battery to begin with. My R/T battery failed the first day it was defective replaced by dealer and fine now.
flaharleyguy is offline
post #6 of 19 (permalink) Old 07-30-2009, 07:38 PM
MoparRick's Avatar
As Mokeman3 said, just recharge in auto mode on the charger. Avoid the "Boost" setting unless you really need to get up and go. Just a nice overnight re-charge is all that's needed. The Boost setting send a lot of current into the system and that's never a good idea.
Slow and sure is best...IMHO..
Orange, 09 SRT, Loaded 6 speed
MoparRick is offline
post #7 of 19 (permalink) Old 02-05-2010, 10:28 AM
HI All
I have a 08 srt8 up here in Toronto. Since I purchased the car, june 08, I have had problems with hard starting. It cranks once or twice then evenually starts? the dealer has replaced the starter, and a left fuel pump? and now, since it is winter up here and the car is put away for the winter, everytime I try and start it ( about every 2 weeks ) the battery is dead. Any ideas? Could the problem have been the battery all along?
thanks guys
f4teen is offline
post #8 of 19 (permalink) Old 02-05-2010, 11:50 AM
Feedback Score: 3 reviews
Originally Posted by f4teen View Post
HI All
thanks guys
Sounds like a bad battery or you have something drawing too much parasitic battery current when the car is shut off.
I tested the parasitic current on my 09 SRT and it was only 30mA. This would take at least a couple of months to drain a good battery.
Look for the problem and also get yourself a Battery Tender.
waumo is offline
post #9 of 19 (permalink) Old 02-12-2010, 11:28 AM
dead battery
HI all
I did get myself a battery tender, but after 24 hours of charging the battery tender indicated that the battery was defective and should be replaced!
Now, being Income tax time, I was going over my invoices for my vehicles, and came across the sheet from the dealer ( last time serviced before putting away for winter ) a note from the lube person, that the electronic battery test indicated that the battery was very WEAK! You think that since the car was in for a hard starting problem, that maybe someone should have looked at the battery.... apparently not. I called the dealership and told them what I had found, and they replied " I guess we owe you a new battery" So I guess I will have to wait until spring to start the car again.
I did learn 2 things, one about battery tenders... great little machines
two, actually read the paperwork I get from the dealer.....
thanks for the help
f4teen is offline
post #10 of 19 (permalink) Old 02-12-2010, 12:10 PM
How are you going to start the car in the spring to get it to the dealer? Before I risked having it towed to the dealer, I put a new battery in it myself.
nyca is offline
Arrghh! Dead Battery! Slosh Challenger Issues & Problems 26 07-23-2014 04:58 PM
Dead Battery?? Frito Challenger Issues & Problems 29 10-08-2013 11:35 AM
Battery dead after 24 hours SwissSRT Challenger Issues & Problems 14 09-15-2013 03:29 PM
exhaust tips achurt Bolt On's 2 08-26-2012 12:43 AM
Strut Tower Brace Ridge Runner Dodge Challenger R/T Specific 9 06-29-2012 11:24 AM
